ESP32-DevKitC V4 Error compiling (any sketch) for board ESP32-WROOM-DA Module
Posted: Wed May 25, 2022 12:36 pm
by esp32-user13
Using the latest Arduino IDE and using the latest board package ESP32 from Espressif (both 2.0.3 and 2.0.3-RC1) gives the following error.
Arduino: 1.8.19 (Windows 10), Board: "ESP32-WROOM-DA Module, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 512000, Core 1, Core 1, Verbose"
exec: "C:\\Users\\homeuser\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3-RC1/tools/gen_esp32part.exe": file does not exist
Error compiling for board ESP32-WROOM-DA Module.
I have resinstalled the Arduino IDE several times. And reinstalled as Administrator. But none helped.
When the ESP32 boards package version 2.0.2 is installed then we no longer have this board available: ESP32-WROOM-DA
Questions:
>> What is causing the compilation to fail with the latest ESP32 module installed (version 2.0.3 and version 2.0.3 RC1)?
Verbose output:
With "Show verbose output during compilation", part of the output is below and the FULL verbose output is in the attached .txt file.
Verbose output:
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\homeuser\AppData\Local\Temp\arduino_cache_770027\core\core_e0deb384e9ab9d92506f082a9dd0d63a.a
Linking everything together...
"C:\\Users\\homeuser\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\\Users\\home.user\\AppData\\Local\\Temp\\arduino_build_45481/sketch_may25a.ino.map" "-LC:\\Users\\home.user\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3-RC1/tools/sdk/esp32/lib" "-LC:\\Users\\home.user\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3-RC1/tools/sdk/esp32/ld" "-LC:\\Users\\home.user\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3-RC1/tools/sdk/esp32/qspi_qspi" -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=5 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group "C:\\Users\\home.user\\AppData\\Local\\Temp\\arduino_build_45481\\sketch\\sketch_may25a.ino.cpp.o" "C:\\Users\\home.user\\AppData\\Local\\Temp\\arduino_cache_770027\\core\\core_e0deb384e9ab9d92506f082a9dd0d63a.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lbutton -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lqrcode -lws2812_led -lesp-dsp -lesp-sr -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lesp_rainmaker -lesp_local_ctrl -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -lrmaker_common -lmqtt -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lwakenet -lmultinet -lesp_audio_processor -lesp_audio_front_end -lesp-sr -lwakenet -lmultinet -lesp_audio_processor -lesp_audio_front_end -ljson -lspiffs -ldl_lib -lc_speech_features -lhilexin_wn5 -lhilexin_wn5X2 -lhilexin_wn5X3 -lnihaoxiaozhi_wn5 -lnihaoxiaozhi_wn5X2 -lnihaoxiaozhi_wn5X3 -lnihaoxiaoxin_wn5X3 -lcustomized_word_wn5 -lmultinet2_ch -lesp_tts_chinese -lvoice_set_xiaole -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o "C:\\Users\\home.user\\AppData\\Local\\Temp\\arduino_build_45481/sketch_may25a.ino.elf"
"C:\\Users\\home.user\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\3.3.0/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\home.user\\AppData\\Local\\Temp\\arduino_build_45481/sketch_may25a.ino.bin" "C:\\Users\\home.user\\AppData\\Local\\Temp\\arduino_build_45481/sketch_may25a.ino.elf"
esptool.py v3.3
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
"C:\\Users\\home.user\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3-RC1/tools/gen_esp32part.exe" -q "C:\\Users\\home.user\\AppData\\Local\\Temp\\arduino_build_45481/partitions.csv" "C:\\Users\\home.user\\AppData\\Local\\Temp\\arduino_build_45481/sketch_may25a.ino.partitions.bin"
exec: "C:\\Users\\home.user\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3-RC1/tools/gen_esp32part.exe": file does not exist
