WiFi - Static IP fails to connect wifi
mistergreen
Postby mistergreen » Tue Feb 06, 2018 3:06 pm
Here's a typical Wifi config code.
IPAddress ip(192,168,1,129);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(8, 8, 8, 8); //optional
IPAddress secondaryDNS(8, 8, 4, 4); //optional
if (!WiFi.config(ip, gateway, subnet, primaryDNS, secondaryDNS)) {
    Serial.println("STA Failed to configure");
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
WiFi.status() won't connect. It's shows a '6' - disconnect.
If I get rid of WiFi.config(), going with the localIP, Wifi can connect. So I can't do a static IP it looks like.
rcholewa@interia.pl
Re: WiFi - Static IP fails to connect wifi
Postby rcholewa@interia.pl » Sat Feb 10, 2018 5:03 pm
I've got the same problem :(
tele_player
Postby tele_player » Sun Feb 11, 2018 7:06 pm
It's working here.
I just added the lines above (IPAddress and WiFi.config() ) to a working WiFi HTTP server sketch, and device is properly operating with static IP. To further verify, I used various IP addresses which were definitely never assigned by my DHCP server.
What might be different? Router (Asus RT-N53) DHCP Server (Raspberry Pi Zero W running pihole), Arduino library version, ESP SDK version?
mistergreen
Postby mistergreen » Mon Feb 12, 2018 12:31 am
I have the latest Arduino Core. What do you have?
I checked on GitHub and you can hack the WiFi library to make it work but I'll wait for an official commit.
tele_player
Postby tele_player » Mon Feb 12, 2018 7:31 am
It’s been a while since I installed the esp32 Arduino core, I don’t know how to check the version.
robademar
Postby robademar » Tue Feb 13, 2018 5:42 pm
I've the same problem. I downloaded again yesterday from git the libraries and ran in verbose mode. I added a println of the status code after attempting to get the ip address confirmed. I have othe devices (pc,phones, etc) with fix address in my network.
Arduino IDE 1.8.5
this is the code I used:
     Example of connection using Static IP
     by Evandro Luis Copercini
     Public domain - 2017
#include <WiFi.h>
//#include <debug.h>
const char* ssid     = "Vodafone-roberto";
const char* password = "xxxxxxxxxxxxxx";
const char* host     = "corriere.it";
const char* url      = "/index.html";
IPAddress local_IP(192, 168, 1, 2);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 0, 0);
void setup()
  Serial.begin(115200);
  if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
    delay(500);
    Serial.print(".");
    Serial.println (WiFi.status());
  Serial.println("");
  Serial.println("WiFi connected!");
  Serial.print("IP address: ");
  Serial.print("ESP Mac Address: ");
  Serial.println(WiFi.macAddress());
  Serial.print("Subnet Mask: ");
  Serial.println(WiFi.subnetMask());
  Serial.print("Gateway IP: ");
  Serial.println(WiFi.gatewayIP());
  Serial.print("DNS: ");
  Serial.println(WiFi.dnsIP());
void loop()
  delay(5000);
  Serial.print("connecting to ");
  Serial.println(host);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  const int httpPort = 80;
  if (!client.connect(host, httpPort)) {
    Serial.println("connection failed");
    return;
  Serial.print("Requesting URL: ");
  Serial.println(url);
  // This will send the request to the server
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  unsigned long timeout = millis();
  while (client.available() == 0) {
    if (millis() - timeout > 5000) {
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
  // Read all the lines of the reply from server and print them to Serial
  while (client.available()) {
    String line = client.readStringUntil('\r');
    Serial.print(line);
  Serial.println();
  Serial.println("closing connection");
and this is the printout
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:956
load:0x40078000,len:0
load:0x40078000,len:13076
entry 0x40078a58
[D][WiFiGeneric.cpp:293] _eventCallback(): Event: 2 - STA_START
Connecting to Vodafone-roberto
.6
[D][WiFiGeneric.cpp:293] _eventCallback(): Event: 7 - STA_GOT_IP
.6
.6
.6
.6
.6
tele_player
Postby tele_player » Wed Feb 14, 2018 4:47 pm
So, it appears to be a bug in SDK or Arduino core, introduced in newer code than I have installed.
mistergreen
Postby mistergreen » Fri Feb 16, 2018 2:52 pm
Yes, wifi.status() = 6 means disconnect. So it's constantly disconnecting.
Users browsing this forum: No registered users and 20 guests
