I need a free running hardware timer, which counts until an edge signal on a GPIO occurs. I want to capture the counter in this moment, to take a timestamp.
After studying the ESP32 hardware manual i am not sure what would be the most straight forward hardware based way to realize this: using pulse counter? watchdog timer? ... ?
Any help/tips on this would be appreciated, thanks.
ESP32 hardware timer with input pin for interrupt?
Re: ESP32 hardware timer with input pin for interrupt?
What are the ways you have come up with and the issues you gave with those ways?
In case you need to measure the speed of the Digital Input,
You can set up a hardware counter to count the input and a timer interrupt to read the hardware counter and calculate the speed.
This is the code for hardware counter on ESP32 , I used this code with ESP32 hardware is a industrial controller with ESP32, NORVI IIOT.
extern "C" {
#include "soc/pcnt_struct.h"
#include "driver/pcnt.h"
byte pulsePin = 13;
int flowcountint=0;
int16_t flowCounter = 0;
int16_t Pulses = 0;
int16_t x;
volatile uint32_t us_time, us_time_diff;
volatile byte state = LOW;
volatile byte state2 = LOW;
volatile byte state_tmr = 0;
volatile byte value_ready = 0;
#define PCNT_TEST_UNIT PCNT_UNIT_0
#define PCNT_H_LIM_VAL 32767
#define PCNT_L_LIM_VAL -1
void setup() {
pinMode(pulsePin,INPUT);
Serial.begin(115200);
Serial.println("");
init_counter();
void loop() {
readPcntCounter_0();
// pcnt_counter_clear(PCNT_TEST_UNIT);
// pcnt_counter_resume(PCNT_TEST_UNIT);
delay(500);
//initialize counter for flow0
void init_counter() {
pcnt_config_t pcnt_config = {
pulsePin, // Pulse input gpio_num, if you want to use gpio16, pulse_gpio_num = 16, a negative value will be ignored
PCNT_PIN_NOT_USED, // Control signal input gpio_num, a negative value will be ignored
PCNT_MODE_KEEP, // PCNT low control mode
PCNT_MODE_KEEP, // PCNT high control mode
PCNT_COUNT_INC, // PCNT positive edge count mode
PCNT_COUNT_DIS, // PCNT negative edge count mode
PCNT_H_LIM_VAL, // Maximum counter value
PCNT_L_LIM_VAL, // Minimum counter value
PCNT_TEST_UNIT, // PCNT unit number
PCNT_CHANNEL_0, // the PCNT channel
if(pcnt_unit_config(&pcnt_config) == ESP_OK) //init unit
Serial.println("Config Unit_0 = ESP_OK");
pcnt_filter_enable(PCNT_TEST_UNIT);
pcnt_set_filter_value(PCNT_TEST_UNIT,500);
pcnt_intr_disable(PCNT_TEST_UNIT);
pcnt_event_disable(PCNT_TEST_UNIT, PCNT_EVT_L_LIM);
pcnt_event_disable(PCNT_TEST_UNIT, PCNT_EVT_H_LIM);
pcnt_event_disable(PCNT_TEST_UNIT, PCNT_EVT_THRES_0);
pcnt_event_disable(PCNT_TEST_UNIT, PCNT_EVT_THRES_1);
pcnt_event_disable(PCNT_TEST_UNIT, PCNT_EVT_ZERO);
pcnt_counter_pause(PCNT_TEST_UNIT);
pcnt_intr_enable(PCNT_TEST_UNIT);
void readPcntCounter_0() {
if(pcnt_get_counter_value(PCNT_TEST_UNIT, &flowCounter) == ESP_OK)
flowcountint = (int) flowCounter;
Serial.println("Count value");
delay(10);
Serial.print("flowCounter = ");
Serial.println(flowCounter);
Users browsing this forum: Bing [Bot] and 83 guests
