ESP32 DevKitJ (aka ESP-WROVER-KIT) - are some GPIO being pulled up to +5V??
Posted: Thu Jan 19, 2017 10:18 am
by MartyMacGyver
I've been poring over the schematic for the LCD kit, and I notice that many of the GPIO I/O expansion connector lines have 10K resistors pulling them up to +5V:
https://dl.espressif.com/dl/schematics/ ... _SCH-2.pdf
But when I look at the board, it *appears* these are all unpopulated (I see solder bumps but no resistors or solder bridging them). In addition, there are 0 ohm "resistors" that appear to be present (not sure why both are in the design).
Why is this, and are the GPIO pins in question actually being pulled up externally at all by any of the remaining external components? Or was that just a late design change (because pulling up ESP32 lines to 5V appears to be a bad idea)?
(edited title to clarify the correct name of the ESP-WROVER-KIT)
Re: ESP32 DevKitJ (aka ESP32-WROVER-KIT) - are some GPIO being pulled up to +5V??
Posted: Fri Jan 20, 2017 1:42 am
by ESP_Sprite
It was an optional idea the engineers had for some internal testing thing; I don't think we ever used it and iirc the new version of the kit won't have them anymore
Posted: Fri Jan 20, 2017 9:16 am
by MartyMacGyver
New version, as in newer than what's currently shipping, possibly with the ESP32-WROVER on it? Cool!
I see pads but no resistors, so it looks electrically sound (no 5V pullups!) which was my main concern. Thanks for the info!
Posted: Fri Jan 20, 2017 10:56 am
by ESP_krzychb
On https://dl.espressif.com/dl/schematics/ ... _SCH-2.pdf schematic +5V GPIO pull up resistors are marked as "10K(1%)(NC)" and in green font.
There are couple of other resistors (including 0 oHm) marked with NC and green.
They are not not connected / not populated on my board as well.
Posted: Fri Jan 20, 2017 11:42 pm
by MartyMacGyver
Ah! That makes sense, though I'm not sure why they're on there at all (perhaps the green elements mark late design changes). I'll watch out for that in the future.
Posted: Sat Jan 21, 2017 1:45 am
by ESP_Sprite
In general, NC parts and 0-ohm resistor links are included when you're not sure what the level on the line needs to be, or if you want to have the option to repurpose the design without needing to spin a new PCB or manually solder bodge wires. You're right on the green bits; the black board you have is effectively the 2nd version; the 1st rev (iirc) was a limited batch of internal-only boards.
