Data type/format in ESP-IDF A2DP-SINK demo
user4_esp32
Postby user4_esp32 » Sun Jun 23, 2019 11:50 pm
In the Bluetooth A2DP sink demo data callback at https://github.com/espressif/esp-idf/bl ... .c#L70-L77:
void bt_app_a2d_data_cb(const uint8_t *data, uint32_t len)
    size_t bytes_written;
    i2s_write(0, data, len, &bytes_written, portMAX_DELAY);
    if (++s_pkt_cnt % 100 == 0) {
        ESP_LOGI(BT_AV_TAG, "Audio packet count %u", s_pkt_cnt);
In what specific format and order are the bytes pointed to by *data? Specifically:
1. Signed or unsigned?
2. little-endian or big-endian?
3. most significant byte first, or least significant byte first?
4. Channel format 2 channel: 16-bit right channel data followed by 16-bit left channel data?
I saw another post where BuddyCasino mentioned the (I2S) format should be MSB first (big-endian) two's complement (signed) integer (https://www.esp32.com/viewtopic.php?t=1756&start=20)
My goal: instead of writing the bytes to I2S, I want to convert/cast them into a pulse code modulation format as:
-Unsigned 16 bit integer (uint16_t)
-big-endian
-Most significant byte first
-Monochannel
Thanks.
Jakobsen
Re: Data type/format in ESP-IDF A2DP-SINK demo
Postby Jakobsen » Mon Jun 24, 2019 6:26 am
Hi
Data out for bluetooth sink demo si :
Signed 16 bits, big-edian, 2 channel
data[..] = { left[7:0], left[15:8], right[7:0], right[15:8],left[7:0], ... }
Regards Jakobsen
Analog Digital IC designer / DevOps @ Merus Audio, Copenhagen, Denmark.
We do novel and best in class Audio amplifiers for consumer products.
Programmed assembler for C-64 back in 1980's, learned some electronics - hacking since then
user4_esp32
Postby user4_esp32 » Fri Jun 28, 2019 4:28 pm
Thanks very much, Jakobsen!
Would you happen to know if there is a way to set/force the esp-idf bluetooth module to output mono-channel in the bt_app_a2d_data_cb( ) callback instead of dual channel? Or a way to force the bluetooth source device to output mono-channel?
Jakobsen
Postby Jakobsen » Mon Jul 01, 2019 7:11 am
No i am not aware if that is possible.
In the call back function you need to do a simple stereo to mono mixer or just pick left or right channel.
But i under stand you concern on saving bandwidth from the source if you can move this process to the source it self.
Take a look at this post https://www.cnx-software.com/2019/06/21 ... ality-aptx that will be a good starting point to dive done to the bluetooth stack and find what you are looking for.
/Jakobsen
Users browsing this forum: ESP_Angus and 36 guests
