ESP_LOG giving a panic error
oliverbru
Postby oliverbru » Thu Sep 26, 2019 8:59 am
#include "freertos/task.h"
#include "esp_system.h"
#include "driver/gpio.h"
#include "esp_log.h"
#include "sdkconfig.h"
#define BLINK_GPIO_GREEN 25
#define BUTTON GPIO_NUM_36
#define ESP_INTR_FLAG_DEFAULT 0
void blink_task(void *pvParameter)
    while (1)
        ESP_LOGI("test", "Restarting now.");
static void IRAM_ATTR gpio_isr_handler()
    gpio_set_level(BLINK_GPIO_GREEN, 1);
void app_main()
    gpio_pad_select_gpio(BLINK_GPIO_GREEN);
    gpio_set_direction(BLINK_GPIO_GREEN, GPIO_MODE_OUTPUT);
    gpio_config_t btn_config;
    btn_config.intr_type = GPIO_INTR_HIGH_LEVEL;
    btn_config.mode = GPIO_MODE_INPUT;               //Set as Input
    btn_config.pin_bit_mask = (1ULL << GPIO_NUM_36); //Bitmask
    btn_config.pull_up_en = GPIO_PULLUP_DISABLE;     //Disable pullup
    btn_config.pull_down_en = GPIO_PULLDOWN_DISABLE; //Disable pulldown
    gpio_config(&btn_config);
    //install gpio isr service
    gpio_install_isr_service(ESP_INTR_FLAG_DEFAULT);
    //hook isr handler for specific gpio pin
    gpio_isr_handler_add(BUTTON, gpio_isr_handler, NULL);
    xTaskCreate(&blink_task, "blink_task", configMINIMAL_STACK_SIZE, NULL, 1, NULL);
This code works fine if I do not use this line in my blind_task function
But if I use it, I have a panic error.
I do not understand.
Thanks I am using ESP-IDF 3.3 on with VSCode on windows and a ESP WROOM 32 devkit
ESP_Dazz
Re: ESP_LOG giving a panic error
Postby ESP_Dazz » Thu Sep 26, 2019 9:09 am
Try increasing your stack size (e.g. 4096).
oliverbru
Postby oliverbru » Thu Sep 26, 2019 9:19 am
It is working.
Thanks a lot :-)
oliverbru
Postby oliverbru » Thu Sep 26, 2019 9:28 am
It works.
Thanks[
oliverbru
Postby oliverbru » Thu Sep 26, 2019 2:18 pm
    ESP_LOGI("test", "PRESSED !");
It gives the same panic error :-(
PS : I am newbie.
gunar.kroeger
Postby gunar.kroeger » Thu Sep 26, 2019 7:05 pm
you can't call logging library from inside an interrupt. For debugging, try to toggle a LED or another gpio.
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
KanyeKanye
Postby KanyeKanye » Thu Sep 26, 2019 9:20 pm
Pins GPI36, GPI39, GPI34, GPI35 have no internal pull resistors (and if even they would, you disabled them).
When floating, lots of interrupts is triggered what cause karnel panic.
For logging use:
ets_printf("ISR");
oliverbru
Postby oliverbru » Fri Sep 27, 2019 8:53 am
To all,
Thanks a lot for your comments and help.
Olivier
Users browsing this forum: No registered users and 109 guests
