Hi all,
I have a requirement like set/reset the gpio pin based on the condition, which is in timer interrupt of time 10ms and in parallel I'm receiving data from uart interrupt and that data I'm writing it to internal flash using spi_flash_write() API function. when spi_flash_write() function is called, I'm getting an error "Cache disabled but cached memory region accessed". Can anyone help me to solve this problem?.
Any help can be appreciated.
Guru Meditation Error: Core 0 panic'ed (Cache disabled but cached memory region accessed)
Re: Guru Meditation Error: Core 0 panic'ed (Cache disabled but cached memory region accessed)
hiningappa BS wrote: ↑Mon Sep 30, 2019 12:13 pmHi all,
you use timer and writing data to internal flash ( SPIFFS? )
you use in arduino ? IDF ?
perhabs this helps:
https://esp32.com/viewtopic.php?t=10928#p44759
viewtopic.php?t=7684
https://github.com/espressif/arduino-esp32/issues/1907
https://github.com/espressif/esp-idf/issues/1299
https://github.com/espressif/arduino-esp32/issues/2686
rudi
rudi ;-) wrote: ↑Mon Sep 30, 2019 6:39 pmhiningappa BS wrote: ↑Mon Sep 30, 2019 12:13 pmHi all,
perhabs this helps:
rudi
Hi
thanks for the reply.
I'm using internal flash(spi_flash_write/read/erase API's).
I'm using ESP-IDF 5.2 version.
Users browsing this forum: Google [Bot] and 102 guests
