touch_pad_t - is it a type of variable?
gennady.sterlin
Postby gennady.sterlin » Thu Oct 22, 2020 9:13 am
I am a beginner, so my question is very simple:
What is "touch_pad_t"?
Is this a special type of variable?
If so, where is this type stored? Is it stored in RTC_memory to survive in a sleep mode?
Thank anyone in advance for help.
Gennady
Re: touch_pad_t - is it a type of variable?
Postby ESP_Sprite » Fri Oct 23, 2020 2:03 am
It's a simple enum, nothing special about it. From components/hal/include/hal/touch_sensor_types.h:
/** Touch pad channel */
typedef enum {
    TOUCH_PAD_NUM0 = 0, /*!< Touch pad channel 0 is GPIO4(ESP32) */
    TOUCH_PAD_NUM1,     /*!< Touch pad channel 1 is GPIO0(ESP32) / GPIO1(ESP32-S2) */
    TOUCH_PAD_NUM2,     /*!< Touch pad channel 2 is GPIO2(ESP32) / GPIO2(ESP32-S2) */
    TOUCH_PAD_NUM3,     /*!< Touch pad channel 3 is GPIO15(ESP32) / GPIO3(ESP32-S2) */
    TOUCH_PAD_MAX,
} touch_pad_t;
gennady.sterlin
Postby gennady.sterlin » Fri Oct 23, 2020 3:30 pm
Hi ESP_Sprite,
Thank you very mush for your help.
Where can I find file components/hal/include/hal/touch_sensor_types.h ?
Looking forward to your response
gennady.sterlin
Postby rudi ;-) » Fri Oct 23, 2020 6:58 pm
you find it in the folder you exactly named in your from github installed/downloaded esp-idf
or if you not have on your desk also online at github.com
cause it is github
you can find github on internet likewise
https://github.com
cause it is espressif stuff we are talking about
you can find the repo stuff from espressif at github under espressif account likewise
https://github.com/espressif
cause the development things are in the esp-idf repo
you can find the SDK Repo from espressif's esp-idf likewise
https://github.com/espressif/esp-idf
cause you are searching for the file components/hal/include/hal/touch_sensor_types.h
you can find this file exactly same folder in the espressif esp-idf github repo likewise
( will not found )
https://github.com/espressif/esp-idf/co ... or_types.h
(so use blob as link here )
https://github.com/espressif/esp-idf/bl ... or_types.h
( or use RAW as link here)
https://raw.githubusercontent.com/espre ... or_types.h
its in the esp.idf repo likewise
esp-idf/components/hal/include/hal/touch_sensor_types.h
regards
Users browsing this forum: Baidu [Spider] and 32 guests
