flash read err, 1000 on ESP32 Wroom Develpment Board
lalitahuja33
Postby lalitahuja33 » Tue Oct 27, 2020 2:19 pm
I'm getting this error on my esp32 wroom dev borad
ets_main.c 371
ets Jun  8 2016 00:22:57
the code is uploaded successfully I get this on the serial monitor and when I press the boot button the below error comes and it stops.
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
And it just stops there. It looks like esp is not able to read the flash memory. It is possible that the read-write cycle of flash memory has been used completely?
When I googled it, most of the people were having this problem because of GPIO0 pin not having a 10k pull-up resistor on esp chip. But I'm using a dev board and the boot button which is connected to GPIO0 has a 10k internal pull-up resistor.
And nothing is connected to the dev board. I uploaded the "sntp" code from esp-idf and got the same result. And also uploaded the WiFi scan code from Arduino IDE but got the same errors. It's strange because it was working fine the who;e day but suddenly stated giving this error.
Re: flash read err, 1000 on ESP32 Wroom Develpment Board
Postby ESP_Sprite » Wed Oct 28, 2020 8:23 am
Hard to say. Are you sure you don't have anything connected to the GPIOs the flash is connected to? (GPIO6-11)
lalitahuja33
Postby lalitahuja33 » Thu Oct 29, 2020 9:21 am
@ESP_Sprite Nothing is connected to any of the GPIOs of the ESP32 dev board. I think somehow the eFuse is set and the board got bricked. I can't upload code to it. So I have started using a new dev board.
Users browsing this forum: Majestic-12 [Bot] and 258 guests
