hi everyone one ,
i want use LVGL library for my screnn TFT touch i found in first time this code https://github.com/lvgl/lv_port_esp32
all work good but this code use more then 88% (bcs library use 2 buffer 80KB) from DRAM so if i use it in my code i will have ESP_ERR_NO_MEM when i try to use wifi.
so i dont know if i can use this library or i can use solution-esp-iot its mentionned i can operate with the minimum memory (80 KB Flash,10 KB RAM)
https://github.com/espressif/esp-iot-so ... uide_en.md
https://github.com/espressif/esp-iot-solution
best regard !
compiling exemple lvgl solution-esp-iot in my project esp idf
Users browsing this forum: Bing [Bot] and 102 guests
