For about a week I am trying to get projects running on Eclipse with mixed results.
Sometime I can compile and debug with no issues and then suddenly, I get the "ninja: build stopped: subcommand failed" message at the end of a compile and from there, my project will not generate the .bin or .elf file anymore.
Even if I delete this project from the drive, as long as I re-create an empty project with the same name, I get the the same error message and .bin/.elf files are not generated.
I tried deleting the ".metadata" folder with no changes.
My only way around this is to re-create a project with a different name.
It works for a while and then after doing some code changes and a few successful compiles, I get again the ninja error message. Reverting the code do not do anything.
But making a new project using the same code but a slightly different name does work for a while.
My project file path do not have space.
I had "." in the file name and I replace it with "_" with no changes.
Making the project name longer of shorter doesn't seem to change anything.
It seems to me that at some point a setting changes in my project and that Eclipse or the IDF toolchain associate those changes to the project name and save this somewhere. I have not been able to find where this association is saved.
Any idea if there is a file I could flush so that I don't need to change project name all the time?
Or does anybody knows why I get a "ninja: build stopped: subcommand failed" error message?
Thanks for any help.
Eclipse ninja: build stopped: subcommand failed
Re: Eclipse ninja: build stopped: subcommand failed
Can you post the messages of such a compile here? The 'ninja failed' message tends to be caused by an error earlier (sometimes much earlier) in the compile process.
See below the end of the compile log as there is a 60 000 character limitation on the forum. Let me know if you need more log.
I see now that there are 2 other error messages in the compile log. Not sure what they mean...
FAILED: esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_seal_curve25519xchacha20poly1305.c.obj
and
ccache: error: Failed to create temporary file for esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_seal_curve25519xchacha20poly1305.c.obj: No such file or directory
Thanks!
[811/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DCONFIGURED -DHAVE_WEAK_SYMBOLS -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DNATIVE_LITTLE_ENDIAN -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -Iconfig -IC:/esp-idf/components/libsodium/libsodium/src/libsodium/include -IC:/esp-idf/components/libsodium/port_include -IC:/esp-idf/components/libsodium/libsodium/src/libsodium/include/sodium -IC:/esp-idf/components/libsodium/port_include/sodium -IC:/esp-idf/components/libsodium/port -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -Wno-unused-function -MD -MT esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_seal_curve25519xchacha20poly1305.c.obj -MF esp-idf\libsodium\CMakeFiles\__idf_libsodium.dir\libsodium\src\libsodium\crypto_box\curve25519xchacha20poly1305\box_seal_curve25519xchacha20poly1305.c.obj.d -o esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_seal_curve25519xchacha20poly1305.c.obj -c C:/esp-idf/components/libsodium/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_seal_curve25519xchacha20poly1305.c
[812/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DCONFIGURED -DHAVE_WEAK_SYMBOLS -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DNATIVE_LITTLE_ENDIAN -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -Iconfig -IC:/esp-idf/components/libsodium/libsodium/src/libsodium/include -IC:/esp-idf/components/libsodium/port_include -IC:/esp-idf/components/libsodium/libsodium/src/libsodium/include/sodium -IC:/esp-idf/components/libsodium/port_include/sodium -IC:/esp-idf/components/libsodium/port -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -Wno-unused-function -MD -MT esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xsalsa20poly1305/box_curve25519xsalsa20poly1305.c.obj -MF esp-idf\libsodium\CMakeFiles\__idf_libsodium.dir\libsodium\src\libsodium\crypto_box\curve25519xsalsa20poly1305\box_curve25519xsalsa20poly1305.c.obj.d -o esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xsalsa20poly1305/box_curve25519xsalsa20poly1305.c.obj -c C:/esp-idf/components/libsodium/libsodium/src/libsodium/crypto_box/curve25519xsalsa20poly1305/box_curve25519xsalsa20poly1305.c
[813/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DCONFIGURED -DHAVE_WEAK_SYMBOLS -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DNATIVE_LITTLE_ENDIAN -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -Iconfig -IC:/esp-idf/components/libsodium/libsodium/src/libsodium/include -IC:/esp-idf/components/libsodium/port_include -IC:/esp-idf/components/libsodium/libsodium/src/libsodium/include/sodium -IC:/esp-idf/components/libsodium/port_include/sodium -IC:/esp-idf/components/libsodium/port -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -Wno-unused-function -MD -MT esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_curve25519xchacha20poly1305.c.obj -MF esp-idf\libsodium\CMakeFiles\__idf_libsodium.dir\libsodium\src\libsodium\crypto_box\curve25519xchacha20poly1305\box_curve25519xchacha20poly1305.c.obj.d -o esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_curve25519xchacha20poly1305.c.obj -c C:/esp-idf/components/libsodium/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_curve25519xchacha20poly1305.c
FAILED: esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_curve25519xchacha20poly1305.c.obj
ccache: error: Failed to create temporary file for esp-idf\libsodium\CMakeFiles\__idf_libsodium.dir\libsodium\src\libsodium\crypto_box\curve25519xchacha20poly1305\box_curve25519xchacha20poly1305.c.obj.d: No such file or directory
[814/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DCONFIGURED -DHAVE_WEAK_SYMBOLS -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DNATIVE_LITTLE_ENDIAN -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -Iconfig -IC:/esp-idf/components/libsodium/libsodium/src/libsodium/include -IC:/esp-idf/components/libsodium/port_include -IC:/esp-idf/components/libsodium/libsodium/src/libsodium/include/sodium -IC:/esp-idf/components/libsodium/port_include/sodium -IC:/esp-idf/components/libsodium/port -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -Wno-unused-function -MD -MT esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/crypto_box_seal.c.obj -MF esp-idf\libsodium\CMakeFiles\__idf_libsodium.dir\libsodium\src\libsodium\crypto_box\crypto_box_seal.c.obj.d -o esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/crypto_box_seal.c.obj -c C:/esp-idf/components/libsodium/libsodium/src/libsodium/crypto_box/crypto_box_seal.c
[815/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -Iconfig -IC:/esp-idf/components/cbor/port/include -IC:/esp-idf/components/cbor/tinycbor/src -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -Wno-discarded-qualifiers -Wno-maybe-uninitialized -MD -MT esp-idf/cbor/CMakeFiles/__idf_cbor.dir/tinycbor/src/cborerrorstrings.c.obj -MF esp-idf\cbor\CMakeFiles\__idf_cbor.dir\tinycbor\src\cborerrorstrings.c.obj.d -o esp-idf/cbor/CMakeFiles/__idf_cbor.dir/tinycbor/src/cborerrorstrings.c.obj -c C:/esp-idf/components/cbor/tinycbor/src/cborerrorstrings.c
[816/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -Iconfig -IC:/esp-idf/components/cbor/port/include -IC:/esp-idf/components/cbor/tinycbor/src -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -Wno-discarded-qualifiers -Wno-maybe-uninitialized -MD -MT esp-idf/cbor/CMakeFiles/__idf_cbor.dir/tinycbor/src/cborparser_dup_string.c.obj -MF esp-idf\cbor\CMakeFiles\__idf_cbor.dir\tinycbor\src\cborparser_dup_string.c.obj.d -o esp-idf/cbor/CMakeFiles/__idf_cbor.dir/tinycbor/src/cborparser_dup_string.c.obj -c C:/esp-idf/components/cbor/tinycbor/src/cborparser_dup_string.c
[817/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -Iconfig -IC:/esp-idf/components/freemodbus/common/include -IC:/esp-idf/components/freemodbus/common -IC:/esp-idf/components/freemodbus/port -IC:/esp-idf/components/freemodbus/modbus -IC:/esp-idf/components/freemodbus/modbus/ascii -IC:/esp-idf/components/freemodbus/modbus/functions -IC:/esp-idf/components/freemodbus/modbus/rtu -IC:/esp-idf/components/freemodbus/modbus/tcp -IC:/esp-idf/components/freemodbus/modbus/include -IC:/esp-idf/components/freemodbus/serial_slave/port -IC:/esp-idf/components/freemodbus/serial_slave/modbus_controller -IC:/esp-idf/components/freemodbus/serial_master/port -IC:/esp-idf/components/freemodbus/serial_master/modbus_controller -IC:/esp-idf/components/freemodbus/tcp_slave/port -IC:/esp-idf/components/freemodbus/tcp_slave/modbus_controller -IC:/esp-idf/components/freemodbus/tcp_master/port -IC:/esp-idf/components/freemodbus/tcp_master/modbus_controller -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -MD -MT esp-idf/freemodbus/CMakeFiles/__idf_freemodbus.dir/modbus/functions/mbfuncdisc.c.obj -MF esp-idf\freemodbus\CMakeFiles\__idf_freemodbus.dir\modbus\functions\mbfuncdisc.c.obj.d -o esp-idf/freemodbus/CMakeFiles/__idf_freemodbus.dir/modbus/functions/mbfuncdisc.c.obj -c C:/esp-idf/components/freemodbus/modbus/functions/mbfuncdisc.c
[818/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DWITH_POSIX -Iconfig -IC:/esp-idf/components/coap/port/include -IC:/esp-idf/components/coap/port/include/coap -IC:/esp-idf/components/coap/libcoap/include -IC:/esp-idf/components/coap/libcoap/include/coap2 -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -MD -MT esp-idf/coap/CMakeFiles/__idf_coap.dir/libcoap/src/coap_hashkey.c.obj -MF esp-idf\coap\CMakeFiles\__idf_coap.dir\libcoap\src\coap_hashkey.c.obj.d -o esp-idf/coap/CMakeFiles/__idf_coap.dir/libcoap/src/coap_hashkey.c.obj -c C:/esp-idf/components/coap/libcoap/src/coap_hashkey.c
[819/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DWITH_POSIX -Iconfig -IC:/esp-idf/components/coap/port/include -IC:/esp-idf/components/coap/port/include/coap -IC:/esp-idf/components/coap/libcoap/include -IC:/esp-idf/components/coap/libcoap/include/coap2 -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -MD -MT esp-idf/coap/CMakeFiles/__idf_coap.dir/libcoap/src/net.c.obj -MF esp-idf\coap\CMakeFiles\__idf_coap.dir\libcoap\src\net.c.obj.d -o esp-idf/coap/CMakeFiles/__idf_coap.dir/libcoap/src/net.c.obj -c C:/esp-idf/components/coap/libcoap/src/net.c
[820/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -Iconfig -IC:/esp-idf/components/esp_hid/include -IC:/esp-idf/components/esp_hid/private -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/nvs_flash/include -IC:/esp-idf/components/spi_flash/include -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -MD -MT esp-idf/esp_hid/CMakeFiles/__idf_esp_hid.dir/src/esp_hid_common.c.obj -MF esp-idf\esp_hid\CMakeFiles\__idf_esp_hid.dir\src\esp_hid_common.c.obj.d -o esp-idf/esp_hid/CMakeFiles/__idf_esp_hid.dir/src/esp_hid_common.c.obj -c C:/esp-idf/components/esp_hid/src/esp_hid_common.c
[821/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DCONFIGURED -DHAVE_WEAK_SYMBOLS -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DNATIVE_LITTLE_ENDIAN -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -Iconfig -IC:/esp-idf/components/libsodium/libsodium/src/libsodium/include -IC:/esp-idf/components/libsodium/port_include -IC:/esp-idf/components/libsodium/libsodium/src/libsodium/include/sodium -IC:/esp-idf/components/libsodium/port_include/sodium -IC:/esp-idf/components/libsodium/port -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/mbedtls/port/include -IC:/esp-idf/components/mbedtls/mbedtls/include -IC:/esp-idf/components/mbedtls/esp_crt_bundle/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -Wno-unused-function -MD -MT esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/crypto_box_easy.c.obj -MF esp-idf\libsodium\CMakeFiles\__idf_libsodium.dir\libsodium\src\libsodium\crypto_box\crypto_box_easy.c.obj.d -o esp-idf/libsodium/CMakeFiles/__idf_libsodium.dir/libsodium/src/libsodium/crypto_box/crypto_box_easy.c.obj -c C:/esp-idf/components/libsodium/libsodium/src/libsodium/crypto_box/crypto_box_easy.c
[822/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-g++.exe -Iconfig -IC:/esp-idf/components/wear_levelling/include -IC:/esp-idf/components/wear_levelling/private_include -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -IC:/esp-idf/components/spi_flash/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu++11 -fno-exceptions -fno-rtti -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -MD -MT esp-idf/wear_levelling/CMakeFiles/__idf_wear_levelling.dir/WL_Flash.cpp.obj -MF esp-idf\wear_levelling\CMakeFiles\__idf_wear_levelling.dir\WL_Flash.cpp.obj.d -o esp-idf/wear_levelling/CMakeFiles/__idf_wear_levelling.dir/WL_Flash.cpp.obj -c C:/esp-idf/components/wear_levelling/WL_Flash.cpp
[823/969] ccache C:\Users\franc\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -Iconfig -IC:/esp-idf/components/freemodbus/common/include -IC:/esp-idf/components/freemodbus/common -IC:/esp-idf/components/freemodbus/port -IC:/esp-idf/components/freemodbus/modbus -IC:/esp-idf/components/freemodbus/modbus/ascii -IC:/esp-idf/components/freemodbus/modbus/functions -IC:/esp-idf/components/freemodbus/modbus/rtu -IC:/esp-idf/components/freemodbus/modbus/tcp -IC:/esp-idf/components/freemodbus/modbus/include -IC:/esp-idf/components/freemodbus/serial_slave/port -IC:/esp-idf/components/freemodbus/serial_slave/modbus_controller -IC:/esp-idf/components/freemodbus/serial_master/port -IC:/esp-idf/components/freemodbus/serial_master/modbus_controller -IC:/esp-idf/components/freemodbus/tcp_slave/port -IC:/esp-idf/components/freemodbus/tcp_slave/modbus_controller -IC:/esp-idf/components/freemodbus/tcp_master/port -IC:/esp-idf/components/freemodbus/tcp_master/modbus_controller -IC:/esp-idf/components/newlib/platform_include -IC:/esp-idf/components/freertos/include -IC:/esp-idf/components/freertos/port/xtensa/include -IC:/esp-idf/components/esp_hw_support/include -IC:/esp-idf/components/esp_hw_support/port/esp32/. -IC:/esp-idf/components/heap/include -IC:/esp-idf/components/log/include -IC:/esp-idf/components/lwip/include/apps -IC:/esp-idf/components/lwip/include/apps/sntp -IC:/esp-idf/components/lwip/lwip/src/include -IC:/esp-idf/components/lwip/port/esp32/include -IC:/esp-idf/components/lwip/port/esp32/include/arch -IC:/esp-idf/components/soc/include -IC:/esp-idf/components/soc/esp32/. -IC:/esp-idf/components/soc/esp32/include -IC:/esp-idf/components/hal/esp32/include -IC:/esp-idf/components/hal/include -IC:/esp-idf/components/esp_rom/include -IC:/esp-idf/components/esp_rom/esp32 -IC:/esp-idf/components/esp_rom/include/esp32 -IC:/esp-idf/components/esp_common/include -IC:/esp-idf/components/esp_system/include -IC:/esp-idf/components/esp32/include -IC:/esp-idf/components/driver/include -IC:/esp-idf/components/driver/esp32/include -IC:/esp-idf/components/esp_ringbuf/include -IC:/esp-idf/components/efuse/include -IC:/esp-idf/components/efuse/esp32/include -IC:/esp-idf/components/xtensa/include -IC:/esp-idf/components/xtensa/esp32/include -IC:/esp-idf/components/espcoredump/include -IC:/esp-idf/components/esp_timer/include -IC:/esp-idf/components/esp_ipc/include -IC:/esp-idf/components/esp_pm/include -IC:/esp-idf/components/vfs/include -IC:/esp-idf/components/esp_wifi/include -IC:/esp-idf/components/esp_wifi/esp32/include -IC:/esp-idf/components/esp_event/include -IC:/esp-idf/components/esp_netif/include -IC:/esp-idf/components/esp_eth/include -IC:/esp-idf/components/tcpip_adapter/include -IC:/esp-idf/components/app_trace/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -std=gnu99 -Wno-old-style-declaration -D_GNU_SOURCE -DIDF_VER=\"v4.3.2\" -DESP_PLATFORM -MD -MT esp-idf/freemodbus/CMakeFiles/__idf_freemodbus.dir/common/esp_modbus_master.c.obj -MF esp-idf\freemodbus\CMakeFiles\__idf_freemodbus.dir\common\esp_modbus_master.c.obj.d -o esp-idf/freemodbus/CMakeFiles/__idf_freemodbus.dir/common/esp_modbus_master.c.obj -c C:/esp-idf/components/freemodbus/common/esp_modbus_master.c
[824/969] cmd.exe /C "cd /D Z:\Electro\WIP\RadSenseTouch\2-Software\2-Firmware\ESP\CtrlComm-101643R1.0\build\bootloader && C:\Users\franc\.espressif\tools\cmake\3.16.4\bin\cmake.exe --build ."
[1/87] Generating project_elf_src_esp32.c
[2/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/soc_include_legacy_warn.c.obj
[3/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/interrupts.c.obj
[4/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/ledc_periph.c.obj
[5/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/lldesc.c.obj
[6/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/adc_periph.c.obj
[7/87] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mpu_hal.c.obj
[8/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/dac_periph.c.obj
[9/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/pcnt_periph.c.obj
[10/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/gpio_periph.c.obj
[11/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/i2c_periph.c.obj
[12/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/i2s_periph.c.obj
[13/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/memory_layout_utils.c.obj
[14/87] Building C object CMakeFiles/bootloader.elf.dir/project_elf_src_esp32.c.obj
[15/87] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/wdt_hal_iram.c.obj
[16/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/soc_memory_layout.c.obj
[17/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sigmadelta_periph.c.obj
[18/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdmmc_periph.c.obj
[19/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/timer_periph.c.obj
[20/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rmt_periph.c.obj
[21/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_io_periph.c.obj
[22/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/spi_periph.c.obj
[23/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdio_slave_periph.c.obj
[24/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/touch_sensor_periph.c.obj
[25/87] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/uart_periph.c.obj
[26/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_mem.c.obj
[27/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random.c.obj
[28/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_partitions.c.obj
[29/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_init.c.obj
[30/87] Building C object esp-idf/spi_flash/CMakeFiles/__idf_spi_flash.dir/esp32/spi_flash_rom_patch.c.obj
[31/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_qio_mode.c.obj
[32/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random_esp32.c.obj
[33/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_encrypt.c.obj
[34/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash_config_esp32.c.obj
[35/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common_loader.c.obj
[36/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/secure_boot.c.obj
[37/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common.c.obj
[38/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_utility.c.obj
[39/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp_image_format.c.obj
[40/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash.c.obj
[41/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console_loader.c.obj
[42/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_efuse_esp32.c.obj
[43/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_soc.c.obj
[44/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_loader.c.obj
[45/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_init.c.obj
[46/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_panic.c.obj
[47/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_sha.c.obj
[48/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console.c.obj
[49/87] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32/esp_efuse_table.c.obj
[50/87] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp32/esp_efuse_fields.c.obj
[51/87] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp32/esp_efuse_api.c.obj
[52/87] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp32/esp_efuse_utility.c.obj
[53/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/flash_encrypt.c.obj
[54/87] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_esp32.c.obj
[55/87] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/compare_set.c.obj
[56/87] Building C object esp-idf/micro-ecc/CMakeFiles/__idf_micro-ecc.dir/uECC_verify_antifault.c.obj
[57/87] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api.c.obj
[58/87] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_fields.c.obj
[59/87] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/cpu_util.c.obj
[60/87] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_crc.c.obj
[61/87] Building ASM object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_longjmp.S.obj
[62/87] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_pm.c.obj
[63/87] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_utility.c.obj
[64/87] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_init.c.obj
[65/87] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_clk_init.c.obj
[66/87] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_sys.c.obj
[67/87] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_uart.c.obj
[68/87] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_time.c.obj
[69/87] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_wdt.c.obj
[70/87] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log.c.obj
[71/87] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_noos.c.obj
[72/87] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/bootloader_start.c.obj
[73/87] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_sleep.c.obj
[74/87] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_buffers.c.obj
[75/87] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32/rtc_clk.c.obj
[76/87] Linking C static library esp-idf\log\liblog.a
[77/87] Linking C static library esp-idf\esp_rom\libesp_rom.a
[78/87] Linking C static library esp-idf\esp_hw_support\libesp_hw_support.a
[79/87] Linking C static library esp-idf\efuse\libefuse.a
[80/87] Linking C static library esp-idf\bootloader_support\libbootloader_support.a
[81/87] Linking C static library esp-idf\spi_flash\libspi_flash.a
[82/87] Linking C static library esp-idf\micro-ecc\libmicro-ecc.a
[83/87] Linking C static library esp-idf\soc\libsoc.a
[84/87] Linking C static library esp-idf\hal\libhal.a
[85/87] Linking C static library esp-idf\main\libmain.a
[86/87] Linking C executable bootloader.elf
[87/87] Generating binary image from built executable
esptool.py v3.2-dev
Merged 1 ELF section
Generated Z:/Electro/WIP/RadSenseTouch/2-Software/2-Firmware/ESP/CtrlComm-101643R1.0/build/bootloader/bootloader.bin
Build complete (0 errors, 0 warnings): Z:\Electro\WIP\RadSenseTouch\2-Software\2-Firmware\ESP\CtrlComm-101643R1.0\build
Total time taken to build the project: 21,581 ms
and
Thanks!
esptool.py v3.2-dev
That ccache error clarifies things... and the base directory plus the path of the specific file the error is on come dangerously close to the Windows 260 char path size limit. I think this topic is related; you could try and see if any of the solutions there work for you.
Yes, that was it!
I have moved my workspace folder to get a shorter path, and sure enough, it is stable now.
The thing that surprises me is that when the workspace path is too long, I am able to compile and debug for a while until suddenly it is no more possible. It may be happening when I include an header file which is outside the workspace, not sure yet.
But one thing is sure, ones it stop working, there is no way back unless I recreate a project with a different name (same character length, same path).
Anyway, I will also try some of the solutions from the post you mentioned.
The 260 characters limit may become an issue for me as some of the code I use is shared with other projects and is in other folders.
Thanks for the help.
Users browsing this forum: No registered users and 131 guests
