Silent Relay connected to esp-wroom-32
matt@mashfield.com
Postby matt@mashfield.com » Wed Nov 15, 2017 10:05 pm
Newbee enthusiast here - hope my questions not lame
I have a doit esp-wroom-32 dev board and I am playing with relays.
my code is simple:
  digitalWrite(5,HIGH);
  delay(10);
  pinMode(5,OUTPUT);
  delay(1000);
  digitalWrite(5,LOW);
  delay(1000);
I have a 4 channel Tongling relay (i'm only interested in 1 channel at the present)
when i run my code the LED on the relay blinks as expected but I don't hear the relay switch/toggle -it's normally audible I assume.
I am powering my esp-32 dev board from my laptop USB - could it be that this doesn't supply enough umph to switch the relay?
please excuse my ignorance as I'm new to this hardware
regards
Matt
ESP_Sprite
Re: Silent Relay connected to esp-wroom-32
Postby ESP_Sprite » Thu Nov 16, 2017 3:59 pm
Have you tried sticking a multimeter (in continuity-test mode) in the contacts for the relay? That should clear up if the relay actually switches. Also, do you have a link to the relay board? Most of them will have some kind of transistor that enables them to be switched from a microcontroller, but if the relay board has no such thing, you may need to add that externally.
Users browsing this forum: Google [Bot] and 83 guests
