JTAG Debugging
ELESSUK
JTAG Debugging
Postby ELESSUK » Sat Feb 10, 2018 11:14 pm
I am trying to get JTAG debugging working with esp-idf using an ESP-Wrover-Kit and Ubuntu 17.10.
I have the correct JTAG links set on JP8.
The project I am trying to debug is the hello_world example in the examples directory. I have modified hello_world_main.c to count down from 100 with a delay of 2.5secs:
for (int i = 100; i >= 0; i--)
        printf("Restarting program in %d seconds...\n", i);
        vTaskDelay(2500 / portTICK_PERIOD_MS);
    printf("Restarting now.\n");
    fflush(stdout);
    esp_restart();
It builds ok and runs ok.
I then run openocd with:
bin/openocd -s share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
and get the following:
Open On-Chip Debugger 0.10.0-dev-ga859564 (2017-07-24-16:16)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
force hard breakpoints
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).
I have created a gdbinit file with:
 target remote :3333
 mon reset halt
 thb app_main
 x $a1=0
 c
When I try to connect gdb with:
xtensa-esp32-elf-gdb -x gdbinit build/hello-world.elf
It seems to crash and needs to be powered off before I can restart the application. The reset button doesn't work, I just get a POWERON_RESET message followed by lots of RTCWDT_RTC_RESET messages:
I get the following in the terminal window:
Restarting program in 90 seconds...
Restarting program in 89 seconds...
ets Jun  8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x3e (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
The following in the openOCD window:
none separate
Info : Target halted. PRO_CPU: PC=0x400D1AEA (active)    APP_CPU: PC=0x00000000
esp32: target state: halted
Info : Use core0 of target 'esp32'
Info : Target halted. PRO_CPU: PC=0x40091D07 (active)    APP_CPU: PC=0x400D1AEA
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
Info : Set current thread to 0x00000000, old= 0x00000000
Info : Target halted. PRO_CPU: PC=0x5000004B (active)    APP_CPU: PC=0x00000000
Info : esp32: Core was reset (pwrstat=0x1F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x40000400 (active)    APP_CPU: PC=0x40000400
And the following in the gdb window:
~/esp/hello_world$ xtensa-esp32-elf-gdb -x gdbinit build/hello-world.elf
GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-build_pc-linux-gnu --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from build/hello-world.elf...done.
0x400d1aea in esp_vApplicationIdleHook ()
    at /home/elessuk/esp/esp-idf/components/esp32/./freertos_hooks.c:62
62	    asm("waiti 0");
JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Hardware assisted breakpoint 1 at 0x400d1f94: file /home/elessuk/esp/hello_world/main/./hello_world_main.c, line 27.
0x0:	0x00000000
Any suggestions as to what is happening or what I am doing wrong?
Thanks in advance
Elessuk
aboaboit
Re: JTAG Debugging
Postby aboaboit » Tue Jul 17, 2018 1:37 pm
Assuming you still have the problem, try lowering the adapter_speed value in your adapter/ board config: I had recurring resets in the breakpoint unit and setting it to 5000 fixed it. It might work even with higher values, I haven't tested yet.
ESP_igrr
Re: JTAG Debugging
Postby ESP_igrr » Tue Jul 17, 2018 1:49 pm
Does your Wrover-KIT come with WROOM or WROVER module? If it's WROVER (like most ESP-WROVER-KITs) then you need to specify config file esp32-wrover.cfg.
If your WROVER-KIT uses WROOM module, then you may be seeing https://github.com/espressif/openocd-esp32/issues/38.
Users browsing this forum: No registered users and 119 guests
