Task watchdog got triggered with WiFi and Bluetooth in the same time
fly135
Re: Task watchdog got triggered with WiFi and Bluetooth in the same time
Postby fly135 » Fri Sep 21, 2018 9:01 pm
BTW, it bears noting that when recommending people to enable WD panic, also advise to think about the time period. Doing something as standard as OTA will cause your app to crash if you leave it at the default.
John A
davdav
Postby davdav » Tue Sep 25, 2018 7:32 am
Hi @fly135
But it's starting to look like I'm going to need to set up the IDF watchdog to handle this is wifi task hanging disables esp_restart. I'm not convinced it does though. The reason being that when the wifi task hung in my app it appeared that the APP core was still working.
I confirm that APP core is correclty running.Moreover "esp_restart" doesn't work when
Task watchdog got triggered. The following tasks did not reset the watchdog in time:
 - IDLE (CPU 0)
Tasks currently running:
CPU 0: wifi
CPU 1: IDLE
starts appearing. What I observe is that some tasks are "killed" (for example a task which reads from UART) but others are working (for a example a task which controls I2C). I do not pinmed any task to a specific core, so what I'm guessing is that esp_restart stop the task on a core but the other is stuck due to "wifi" exception.
In my case the Task watchdog triggered started in this way
I (6068961) wifi: bcn_timout,ap_probe_send_start
I (6071465) wifi: ap_probe_send over, resett wifi status to disassoc
I (6071465) wifi: state: run -> init (100)
I (6071466) wifi: pm stop, total sleep time: 2811620671 us / 6072922354 us
I (6071471) wifi: n:7 0, o:7 2, ap:255 255, sta:7 2, prof:1
 - IDLE (CPU 0)
CPU 0: wifi
CPU 1: IDLE
And available heap was around 43000bytes so I don't think it's a problem of RAM. I'm working on esp-v3.1 release (22da5f) BUT esp32/lib component is updated to latest commit (05aa0f4).
davdav
Postby davdav » Tue Sep 25, 2018 8:20 am
I would like also to reference this issue on github which is related to this topic.
https://github.com/espressif/esp-idf/issues/2370
Users browsing this forum: Bing [Bot] and 18 guests
