any way to permanently disable the wifi?
Posted: Thu Sep 20, 2018 7:05 pm
by joeynoodles
Is there any way to permanently disable the wifi on the ESP32? I've had a few projects working well with the ESP32, so I'd like to keep using it, but for certain projects for security concerns I'd like to disable the wifi so that there's no way to turn it back on ever. Is this possible?
Re: any way to permanently disable the wifi?
Posted: Fri Sep 21, 2018 12:50 am
by username
Posted: Fri Sep 21, 2018 1:18 pm
by fly135
Wifi is disabled by default. You have to enable it. There are security measures you can take to prevent anyone else from programming your device. Maybe that's what you need to consider looking at.
John A
Posted: Fri Sep 21, 2018 9:33 pm
by joeynoodles
Thanks guys. I was wondering though if there's a hardware change, or anything that results in no turning back, for disabling the wifi. The software may eventually require upgrading, so I'm not thinking about pursuing a way permanently disabling programming altogether right now. Thanks for suggesting though.
Posted: Fri Sep 21, 2018 10:41 pm
by fly135
My brief statement did not mean to imply that you couldn't update the firmware. Simply that there are measures that prevent others from modifying or reverse engineering the data/software on your device. That is what the company I work for intends to do before production. Someone will correct me if I'm wrong here, but as I understand it the ESP32 has the ability to decrypt data and code from flash in realtime as it's executed.
John A
