A2dp sink volume control?
sdourmashkin
Re: A2dp sink volume control?
Postby sdourmashkin » Wed Aug 26, 2020 9:45 pm
Thanks so much for sharing! You were right, the issue had to do with the fact that the volume data is 8 MSB (instead of 16). Your fix worked, although we also have to change the code to only parse through one byte at a time (numBytesShifted = 1). Here's the volume change function with that fix:
//the following code changes the volume
uint8_t *volume_control_changeVolume(uint8_t *data, uint8_t *outputData, size_t size, uint8_t volume) {
    const int numBytesShifted = 1;
    int16_t pcmData;
    bool isNegative;
    memcpy(outputData, data, size);
    size_t h = 0;
    for (h = 0; h < size; h += numBytesShifted) {
        pcmData = data[h];
        isNegative = pcmData & 0x80;
        if (isNegative)
            pcmData = (~pcmData) + 0x1;
        pcmData = pcmData >> (8 - volume);
        if (isNegative)
        outputData[h] = pcmData;
    return outputData;
There's a big jump from master_volume = 8 --> 7. I'm assuming that has to do with the data only being 8-bit though.
Setting .communication_format = I2S_COMM_FORMAT_I2S_MSB didn't seem to make a difference. Let me know if you think otherwise.
Thanks again!
- Steven
mooalot
Postby mooalot » Thu Aug 27, 2020 1:22 pm
Whoops, I must've forgot to change numBytesShifted = 1 in my fix!
Now that I think about it, I dont think setting the format to MSB does anything because its only 8 bits.
You're right about the volume change as well, 8 bits doesn't allow for much change using log base 2. Im sure there are other ways to change the volume, but this was the way I used.
Glad to help.
Goodluck!
Users browsing this forum: No registered users and 57 guests
