How add gpio (or adc) event to audio_event_iface_listen?
HepoH3
Postby HepoH3 » Thu Nov 26, 2020 7:15 am
Hi there!
I want to create sorta music box. The idea is when you open the box, the board start to playing the melody, and when you close the box, the board stops playing. Currently I just reproduced the play_mp3_control example, and really don't now how to put the things into the motion. As far as I understand, the example already listen for all peripheral events, so I tried to add PERIPH_ID_GPIO_ISR just to check that it will react to the gpio level change, but apparantly, I do something wrong. Can anyone help me?
/* Play mp3 file by audio pipeline
   with possibility to start, stop, pause and resume playback
   as well as adjust volume
#include <string.h>
#include "freertos/task.h"
#include "esp_log.h"
#include "audio_element.h"
#include "audio_pipeline.h"
#include "audio_event_iface.h"
#include "audio_mem.h"
#include "audio_common.h"
#include "i2s_stream.h"
#include "mp3_decoder.h"
#include "esp_peripherals.h"
#include "periph_touch.h"
#include "periph_adc_button.h"
#include "periph_button.h"
#include "board.h"
#include "driver/gpio.h"
static const char *TAG = "PLAY_MP3_FLASH";
   To embed it in the app binary, the mp3 file is named
   in the component.mk COMPONENT_EMBED_TXTFILES variable.
extern const uint8_t adf_music_mp3_start[] asm("_binary_adf_music_mp3_start");
extern const uint8_t adf_music_mp3_end[] asm("_binary_adf_music_mp3_end");
static int adf_music_mp3_pos;
static audio_pipeline_handle_t pipeline;
int mp3_music_read_cb(audio_element_handle_t el, char *buf, int len, TickType_t wait_time, void *ctx)
    int read_size = adf_music_mp3_end - adf_music_mp3_start - adf_music_mp3_pos;
    if (len < read_size)
        read_size = len;
    else
        adf_music_mp3_pos = adf_music_mp3_start;
        audio_pipeline_pause(pipeline);
    memcpy(buf, adf_music_mp3_start + adf_music_mp3_pos, read_size);
    adf_music_mp3_pos += read_size;
    return read_size;
void app_main(void)
    gpio_config_t io_conf;
    //interrupt of rising edge
    io_conf.intr_type = GPIO_PIN_INTR_POSEDGE;
    //bit mask of the pins, use GPIO4/5 here
    io_conf.pin_bit_mask = 1ULL<<(GPIO_NUM_21);
    //set as input mode
    io_conf.mode = GPIO_MODE_INPUT;
    //enable pull-up mode
    io_conf.pull_up_en = 1;
    gpio_config(&io_conf);
    audio_element_handle_t i2s_stream_writer, mp3_decoder;
    esp_log_level_set("*", ESP_LOG_WARN);
    esp_log_level_set(TAG, ESP_LOG_INFO);
    ESP_LOGI(TAG, "[ 1 ] Start audio codec chip");
    audio_board_handle_t board_handle = audio_board_init();
    audio_hal_ctrl_codec(board_handle->audio_hal, AUDIO_HAL_CODEC_MODE_BOTH, AUDIO_HAL_CTRL_START);
    int player_volume;
    audio_hal_get_volume(board_handle->audio_hal, &player_volume);
    ESP_LOGI(TAG, "[ 2 ] Create audio pipeline, add all elements to pipeline, and subscribe pipeline event");
    audio_pipeline_cfg_t pipeline_cfg = DEFAULT_AUDIO_PIPELINE_CONFIG();
    pipeline = audio_pipeline_init(&pipeline_cfg);
    mem_assert(pipeline);
    ESP_LOGI(TAG, "[2.1] Create mp3 decoder to decode mp3 file and set custom read callback");
    mp3_decoder_cfg_t mp3_cfg = DEFAULT_MP3_DECODER_CONFIG();
    mp3_decoder = mp3_decoder_init(&mp3_cfg);
    audio_element_set_read_cb(mp3_decoder, mp3_music_read_cb, NULL);
    ESP_LOGI(TAG, "[2.2] Create i2s stream to write data to codec chip");
    i2s_stream_cfg_t i2s_cfg = I2S_STREAM_CFG_DEFAULT();
    i2s_cfg.type = AUDIO_STREAM_WRITER;
    i2s_stream_writer = i2s_stream_init(&i2s_cfg);
    ESP_LOGI(TAG, "[2.3] Register all elements to audio pipeline");
    audio_pipeline_register(pipeline, mp3_decoder, "mp3");
    audio_pipeline_register(pipeline, i2s_stream_writer, "i2s");
    ESP_LOGI(TAG, "[2.4] Link it together [mp3_music_read_cb]-->mp3_decoder-->i2s_stream-->[codec_chip]");
    const char *link_tag[2] = {"mp3", "i2s"};
    audio_pipeline_link(pipeline, &link_tag[0], 2);
    ESP_LOGI(TAG, "[ 3 ] Initialize peripherals");
    esp_periph_config_t periph_cfg = DEFAULT_ESP_PERIPH_SET_CONFIG();
    esp_periph_set_handle_t set = esp_periph_set_init(&periph_cfg);
    ESP_LOGI(TAG, "[3.1] Initialize keys on board");
    audio_board_key_init(set);
    ESP_LOGI(TAG, "[ 4 ] Set up  event listener");
    audio_event_iface_cfg_t evt_cfg = AUDIO_EVENT_IFACE_DEFAULT_CFG();
    audio_event_iface_handle_t evt = audio_event_iface_init(&evt_cfg);
    ESP_LOGI(TAG, "[4.1] Listening event from all elements of pipeline");
    audio_pipeline_set_listener(pipeline, evt);
    ESP_LOGI(TAG, "[4.2] Listening event from peripherals");
    audio_event_iface_set_listener(esp_periph_set_get_event_iface(set), evt);
    ESP_LOGW(TAG, "[ 5 ] Tap touch buttons to control music player:");
    ESP_LOGW(TAG, "      [Play] to start, pause and resume, [Set] to stop.");
    ESP_LOGW(TAG, "      [Vol-] or [Vol+] to adjust volume.");
    while (1)
        audio_event_iface_msg_t msg;
        esp_err_t ret = audio_event_iface_listen(evt, &msg, portMAX_DELAY);
        if (ret != ESP_OK)
            ESP_LOGE(TAG, "[ * ] Event interface error : %d", ret);
            continue;
        if (msg.source_type == AUDIO_ELEMENT_TYPE_ELEMENT && msg.source == (void *)mp3_decoder && msg.cmd == AEL_MSG_CMD_REPORT_MUSIC_INFO)
            audio_element_info_t music_info = {0};
            audio_element_getinfo(mp3_decoder, &music_info);
            ESP_LOGI(TAG, "[ * ] Receive music info from mp3 decoder, sample_rates=%d, bits=%d, ch=%d",
                     music_info.sample_rates, music_info.bits, music_info.channels);
            audio_element_setinfo(i2s_stream_writer, &music_info);
            i2s_stream_set_clk(i2s_stream_writer, music_info.sample_rates, music_info.bits, music_info.channels);
            continue;
        if ((msg.source_type == PERIPH_ID_GPIO_ISR) || ((msg.source_type == PERIPH_ID_TOUCH || msg.source_type == PERIPH_ID_BUTTON || msg.source_type == PERIPH_ID_ADC_BTN) && (msg.cmd == PERIPH_TOUCH_TAP || msg.cmd == PERIPH_BUTTON_PRESSED || msg.cmd == PERIPH_ADC_BUTTON_PRESSED)))
            if(msg.source_type == PERIPH_ID_GPIO_ISR)
                ESP_LOGI(TAG, "[ * ] Yyyyyaaaaaay!");
            if ((int)msg.data == get_input_play_id())
                ESP_LOGI(TAG, "[ * ] [Play] touch tap event");
                audio_element_state_t el_state = audio_element_get_state(i2s_stream_writer);
                switch (el_state)
                case AEL_STATE_INIT:
                    ESP_LOGI(TAG, "[ * ] Starting audio pipeline");
                    audio_pipeline_run(pipeline);
                case AEL_STATE_RUNNING:
                    ESP_LOGI(TAG, "[ * ] Pausing audio pipeline");
                case AEL_STATE_PAUSED:
                    ESP_LOGI(TAG, "[ * ] Resuming audio pipeline");
                    audio_pipeline_resume(pipeline);
                case AEL_STATE_FINISHED:
                    ESP_LOGI(TAG, "[ * ] Rewinding audio pipeline");
                    audio_pipeline_stop(pipeline);
                    audio_pipeline_wait_for_stop(pipeline);
                    adf_music_mp3_pos = 0;
                default:
                    ESP_LOGI(TAG, "[ * ] Not supported state %d", el_state);
            else if ((int)msg.data == get_input_set_id())
                ESP_LOGI(TAG, "[ * ] [Set] touch tap event");
                ESP_LOGI(TAG, "[ * ] Stopping audio pipeline");
            else if ((int)msg.data == get_input_volup_id())
                ESP_LOGI(TAG, "[ * ] [Vol+] touch tap event");
                player_volume += 10;
                if (player_volume > 100)
                    player_volume = 100;
                audio_hal_set_volume(board_handle->audio_hal, player_volume);
                ESP_LOGI(TAG, "[ * ] Volume set to %d %%", player_volume);
            else if ((int)msg.data == get_input_voldown_id())
                ESP_LOGI(TAG, "[ * ] [Vol-] touch tap event");
                player_volume -= 10;
                if (player_volume < 0)
                    player_volume = 0;
    ESP_LOGI(TAG, "[ 6 ] Stop audio_pipeline");
    audio_pipeline_terminate(pipeline);
    audio_pipeline_unregister(pipeline, mp3_decoder);
    audio_pipeline_unregister(pipeline, i2s_stream_writer);
    /* Terminate the pipeline before removing the listener */
    audio_pipeline_remove_listener(pipeline);
    /* Make sure audio_pipeline_remove_listener is called before destroying event_iface */
    audio_event_iface_destroy(evt);
    /* Release all resources */
    audio_pipeline_deinit(pipeline);
    audio_element_deinit(i2s_stream_writer);
    audio_element_deinit(mp3_decoder);
Users browsing this forum: No registered users and 56 guests
