ble_mesh_fast_prov_server fast provision fail
Posted: Thu Apr 16, 2020 6:23 am
by iamkkk
您好
我有4片 ESP32-wroom-32U 並使用 ble_mesh_fast_prov_server example的bin
app使用EspBLEMesh v1.0.0
從app_ble.png的步驟5到步驟6時,該device connect 無法enable 。請見 Screenshot_20200416-140825.png
此device connect 無法enable 的log
I (702) system_api: read default base MAC address from EFUSE
I (892) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 2
W (892) phy_init: saving new calibration data because of checksum failure, mode(0)
I (2842) FAST_PROV_SERVER_DEMO: ESP_BLE_MESH_PROV_REGISTER_COMP_EVT, err_code: 0
I (2852) FAST_PROV_SERVER_DEMO: ESP_BLE_MESH_NODE_PROV_ENABLE_COMP_EVT, err_code: 0
I (2852) FAST_PROV_SERVER_DEMO: BLE Mesh Fast Prov Node initialized
I (299922) FAST_PROV_SERVER_DEMO: ESP_BLE_MESH_NODE_PROV_LINK_OPEN_EVT, bearer: PB-GATT
E (300292) BT_BTM: BTM_BleScan scan not active
E (300292) BLE_MESH: bt_le_scan_stop, Invalid status 6
E (300292) BLE_MESH: stopping scan failed (err -1)
I (300322) FAST_PROV_SERVER_DEMO: ESP_BLE_MESH_NODE_PROV_LINK_CLOSE_EVT, bearer: PB-GATT
I (300322) FAST_PROV_SERVER_DEMO: ESP_BLE_MESH_NODE_PROV_COMPLETE_EVT
I (300322) FAST_PROV_SERVER_DEMO: net_idx: 0x0001, unicast_addr: 0x0002
I (300332) FAST_PROV_SERVER_DEMO: flags: 0x00, iv_index: 0x00000000
I (300982) FAST_PROV_SERVER_DEMO: example_ble_mesh_config_server_cb, event = 0x00, opcode = 0x0000, addr: 0x0001
I (300982) FAST_PROV_SERVER_DEMO: Config Server get Config AppKey Add
I (301212) FAST_PROV_SERVER_DEMO: example_ble_mesh_custom_model_cb: Fast prov server receives msg, opcode 0xc002e5
I (301212) fast prov server recv: c3 03 04 00 00 04 00 c0 01 00 dd dd 81
I (301222) FAST_PROV_SERVER_DEMO: ESP_BLE_MESH_SET_FAST_PROV_INFO_COMP_EVT
I (301232) FAST_PROV_SERVER_DEMO: status_unicast: 0x00, status_net_idx: 0x00, status_match 0x00
I (301242) FAST_PROV_SERVER_DEMO: ESP_BLE_MESH_SET_FAST_PROV_ACTION_COMP_EVT, status_action 0x00
I (301262) FAST_PROV_SERVER_DEMO: ESP_BLE_MESH_MODEL_SEND_COMP_EVT, err_code 0
I (301262) FAST_PROV_SERVER: example_handle_fast_prov_status_send_comp_evt: opcode 0xc102e5
W (301272) FAST_PROV_SERVER: example_handle_fast_prov_status_send_comp_evt: Disable BLE Mesh Relay & GATT Proxy
W (301282) BT_APPL: bta_gattc_conn_cback() - cif=4 connected=0 conn_id=4 reason=0x0016
I (301292) FAST_PROV_SERVER_DEMO: ESP_BLE_MESH_NODE_PROXY_GATT_DISABLE_COMP_EVT
其他3台的device都停留在
Re: ble_mesh_fast_prov_server fast provision fail
Posted: Tue Jul 07, 2020 7:32 am
by Beibixian
楼主解决了吗,我也碰到了类似的问题
