on Windows 10, using Eclipse esp idf
if press the restart(en) button of ESP32,
Will see below error
Serial port COM3
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: https://github.com/espressif/esptool#troubleshooting
CMake Error at run_serial_tool.cmake:56 (message):
python
C:/Users/Jesse/Desktop/esp-idf/components/esptool_py/esptool/esptool.py
--chip esp32 failed
FAILED: CMakeFiles/flash
If not press the "restart" button of ESP32, error as shown below:
Serial port COM3
A fatal error occurred: Failed to connect to ESP32: Wrong boot mode detected (0x13)! The chip needs to be in download mode.
python
--chip esp32 failed
I review the doc, the cable may be the problem, but I have no idea how to test the output voltage and current.
Thanks.
Re: Failed to connect to ESP32: No serial data received
For a Wrover-Kit, I solved by installing ftdichip drivers.
https://ftdichip.com/Drivers/vcp-drivers/
I saw it in https://www.youtube.com/watch?v=t-gMQDGB-9g
Maybe you should install another drivers to communicate the USB port to your board.
Users browsing this forum: No registered users and 120 guests
