esp32 s3 无法连接wifi
Posted: Wed Mar 09, 2022 4:20 pm
by lgpww123
芯片是esp32 s3 ,idf是4.4,使用案例是wifi getting_started\softAP和station 都无法搜索到wifi或者连接wifi。
Re: esp32 s3 无法连接wifi
Posted: Tue May 10, 2022 8:07 am
by ESP_LJY
麻烦提供一下 ESP32S3 运行 log, 具体看下。
Posted: Fri Jun 24, 2022 12:52 am
by xhcyfc
ESP32只支持2.4G,你看一看你的网络是不是选了5G
Posted: Wed Feb 22, 2023 3:22 am
by jason.zhi
同样,esp32s3使用example,station的,以及websocket的example,还有tcp client的都是无法连接wifi
log如下:
I (327) sleep: Configure to isolate all GPIO pins in sleep state
I (334) sleep: Enable automatic switching of GPIO sleep configuration
I (341) cpu_start: Starting scheduler on PRO CPU.
I (404) pp: pp rom version: e7ae62f
I (404) net80211: net80211 rom version: e7ae62f
I (414) wifi:wifi driver task: 3fce55c8, prio:23, stack:6656, core=0
I (414) system_api: Base MAC address is not set
I (414) system_api: read default base MAC address from EFUSE
I (434) wifi:wifi firmware version: 7679c42
I (434) wifi:wifi certification version: v7.0
I (434) wifi:config NVS flash: enabled
I (434) wifi:config nano formating: disabled
I (434) wifi:Init data frame dynamic rx buffer num: 32
I (444) wifi:Init management frame dynamic rx buffer num: 32
I (444) wifi:Init management short buffer num: 32
I (444) wifi:Init dynamic tx buffer num: 32
I (454) wifi:Init static tx FG buffer num: 2
I (454) wifi:Init static rx buffer size: 1600
I (464) wifi:Init static rx buffer num: 10
I (464) wifi:Init dynamic rx buffer num: 32
I (474) wifi_init: rx ba win: 6
I (474) wifi_init: tcpip mbox: 32
I (474) wifi_init: udp mbox: 6
I (484) wifi_init: tcp mbox: 6
I (484) wifi_init: tcp tx win: 5744
I (484) wifi_init: tcp rx win: 5744
I (494) wifi_init: tcp mss: 1440
I (494) wifi_init: WiFi IRAM OP enabled
I (504) wifi_init: WiFi RX IRAM OP enabled
I (504) example_connect: Connecting to OpenWrt...
I (514) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12
I (564) wifi:mode : sta (f4:12:fa:e6:0f:2c)
I (564) wifi:enable tsf
I (564) example_connect: Waiting for IP(s)
I (2614) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1
Posted: Wed May 10, 2023 7:29 am
by ESP_LiuH
请检查是否开启了 5G 的网络并确认 SSID 名称是否与 2.4G 的相同。
