Error squiggles not showing in v4.4.2
username
Postby username » Thu Aug 11, 2022 4:53 pm
I recently moved to a new pc. Installed VSC, and added ESP-IDF VS Code Extension. Install went smoothly.
I noticed that in my projects I no longer get those red squiggles on errors, nor does project files that contains the error show in red.
Is this a VSC issue, or ESP extension problem ?
I just installed v4.4.1 and everything works as it should, uninstalling that and then going to v4.4.2 It does not show errors. Neither does installing using the Master Branch. Only v4.4.1 works fine.
Here are two screenshot. One with v4.4.1 and the later with 4.4.2. Both using the blink example with a error.
Notice no squiggles or file in red using v4.4.2
ESP_Roland
Re: Error squiggles not showing in v4.4.2
Postby ESP_Roland » Tue Aug 16, 2022 6:37 am
username
Postby username » Tue Aug 16, 2022 8:33 am
I should have noted that I used ESP-IDF Tools Installer for Windows.
https://dl.espressif.com/dl/esp-idf/
And choose " espressif-ide-setup-espressif-ide-2.5.0-with-esp-idf-4.4 "
ESP_bignacio
Postby ESP_bignacio » Tue Aug 16, 2022 11:58 am
We've made some fixes in this PR ! Could you try this vsix installer
Related link: how to Install extension from vsix
username
Postby username » Tue Aug 16, 2022 3:39 pm
Gave it a try, but still has the same problem.
username
Postby username » Thu Aug 18, 2022 6:22 am
ESP-IDF VS Code Extension just got updated to 1.5.0. Things are working fine again.
Users browsing this forum: No registered users and 45 guests
