I've installed the expressif extensions from the Marketplace into Visual Studio and am trying to build one of the examples. I'm getting the following error: Windows requires a prebuilt mconf-idf for your platform on the PATH, or an MSYS2 version of gcc on the PATH to build mconf-idf.
How do I correct this?
Re: Windows requires a prebuilt mconf-idf
Could you provide more information such as:
- ESP-IDF version
- IDF tools installer version
- Are you building using VS Code IDF extension commands, or directly on command line?
- Provide a copy of the error log
- gunar.kroeger
I was able to reproduce this issue.
building blink example with idf 4.0 in VS Code using the ESP-IDF: Build your project command
⚠️ CMake Error at C:/Users/gunar.kroeger/esp-idf/tools/cmake/kconfig.cmake:28 (message):
MSYS2 version of gcc on the PATH to build mconf-idf. Consult the setup
docs for ESP-IDF on Windows.
C:/Users/gunar.kroeger/esp-idf/tools/cmake/build.cmake:160 (__kconfig_init)
C:/Users/gunar.kroeger/esp-idf/tools/cmake/idf.cmake:43 (__build_init)
C:/Users/gunar.kroeger/esp-idf/tools/cmake/project.cmake:7 (include)
CMakeLists.txt:5 (include)
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
- gunar.kroeger
going through the ESP_IDF: Configure ESP_IDF extension solves the issue
Users browsing this forum: No registered users and 21 guests
