I am using eclipse to debug the ESP32 and its working great.
My problem is when I try to use spiffs.
I have included the line
spiffs_create_partition_image(my_partition ./data FLASH_IN_PROJECT )
in the base project CMakeLists.txt and I also have a folder data in the base project folder.
I keep getting the error Failed to create SPIFFS image for partition 'my_partition' and also Check project configuration if using the correct partition table file.
Any ideas?
Thanks.
Eclipse spiffs
Re: Eclipse spiffs
Hi.
I have changed the sdkconfig to use a custom partition table csv and have included a partitions.csv file in the project base directory.
When I build the project using eclipse the output shows the new partition table.
Then I debug the project openOCD flashes the project and it runs okay but I can see from the bootup messages that the partition table has not been changed to the new one.
Questions:
1) Can openOCD flash a new partition table. How can this be done from eclipse?
2) I changed the flash size in sdkconfig to 4Meg but the boot messages when debugging the project say the binary image header is set to 2048K
Many Thanks,
MPC
Questions:
Many Thanks,
MPC
Re: Eclipse spiffs
Found how to use eclipse with spiffs.
You have to add the following two lines to the debug configuration, Startup
mon program_esp ${workspace_loc:Spiffs/build/partition_table/partition-table.bin} 0x8000 verify
mon program_esp ${workspace_loc:Spiffs/build/storage.bin} 0x110000 verify
Where Spiffs is your project name and storage.bin is the binary file created by the following line added to your CMakeLists.txt
spiffs_create_partition_image(storage ../spiffs_image FLASH_IN_PROJECT)
partition-table.bin is created from your partitions_example.csv provided you have changed the sdkconfig to use a custom partition table.
Enjoy.....
Enjoy.....
Re: Eclipse spiffs
I have hit your original problem: "Failed to create SPIFFS image for partition 'storage'. "
In theory this project is building fine for other people so I'm not 100% sure what could be wrong in my settings (vsCode).
We do have a partitions.csv
and our ./main/CMakeLists.txt has the create partition line.
But I'm still hitting the "Failed to create SPIFFS image for partition 'storage'. " failure.
Can you clarify the config you needed for to work?
Thanks!
# Name, Type, SubType, Offset, Size, Flags
# Note: if you have increased the bootloader size, make sure to update the offsets to avoid overlap
nvs, data, nvs, 0x9000, 0x6000,
phy_init, data, phy, 0xf000, 0x1000,
factory, app, factory, 0x10000, 1M,
storage, data, spiffs, , 0xF0000,
spiffs_create_partition_image(storage ../data FLASH_IN_PROJECT)
idf.py build
Thanks!
Re: Eclipse spiffs
I solved my own problem...
The .gitignore was excluding the sdkconfig. We verified this by running `idf.py menuconfig` and the partitions were not setup to us the particions.csv. Once we corrected that it built fine.
Users browsing this forum: No registered users and 69 guests
