I can't figure out why it is not using the correct python.[cmake] Diagnostic information:
[cmake] IDF_PYTHON_ENV_PATH: C:\ESP32\.espressif\python_env\idf4.3_py3.9_env\scripts
[cmake] Python interpreter used: C:\Python\Python39\python.exe
[cmake] Warning: python interpreter not running from IDF_PYTHON_ENV_PATH
VS Code CMake not using correct Python ENV
When I run CMake configure I Get this error:
Re: VS Code CMake not using correct Python ENV
Are you using CMake Tools extension ? Or are you using another extension?
If you are using Microsoft's CMake Tools extension, you might want to set an environment variable called PYTHON with
You can also try our official extension for Visual Studio Code here
C:\ESP32\.espressif\python_env\idf4.3_py3.9_env\Scripts\python.exe
Ah, I didn't realize that was coming from another extension. I did use the esp-idf extension to install but I think vs code suggested installing cmake tools as well.
I have two more issues:
1. Is after opening the project I get.
2. Is Opening the monitor fails with
The Project builds without issues so I'm not 100% sure what is going on here.Unable to resolve configuration with compilerPath "c:/esp32/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe". Using "cl.exe" instead.
Any help you can provide with these would be awesome!C:\ESP32\Projects\HRV-Main-Control>C:\ESP32\.espressif\python_env\idf4.3_py3.9_env\Scripts\python.exe C:\ESP32\esp-idf\tools\idf.py -p COM3 monitor
File "C:\ESP32\esp-idf\tools\idf.py", line 811, in <module>
main()
File "C:\ESP32\esp-idf\tools\idf.py", line 726, in main
checks_output = check_environment()
File "C:\ESP32\esp-idf\tools\idf.py", line 77, in check_environment
debug_print_idf_version()
File "C:\ESP32\esp-idf\tools\idf.py", line 132, in debug_print_idf_version
version = idf_version()
File "C:\ESP32\esp-idf\tools\idf_py_actions\tools.py", line 56, in idf_version
"--git-dir=%s" % os.path.join(os.environ["IDF_PATH"], '.git'),
File "C:\Python\Python39\lib\os.py", line 679, in __getitem__
raise KeyError(key) from None
KeyError: 'IDF_PATH'
main()
I am also having the same issues any support would be helpful
I had the same issue - I found the issue was I had the "Python" extension added in VS code. When I (disabled? uninstalled?) it - IDF builds then magically started doing the right thing.
I have the same issue.
It seems the system add homebrew python in PATH variable and get the python first.
Users browsing this forum: No registered users and 22 guests
