VS Code Blink Debug Problems
Posted: Fri Apr 09, 2021 6:43 am
by vpascucci
Hello everyone,
I am using VS Code and trying to follow this guide:
https://github.com/espressif/vscode-esp ... bugging.md
in order to debug the blink example.
I am using an ESP32-WROOM board, and as a JTAG debugger I am using a digilent-hs2. Building, flashing and monitoring works fine, however debugging ("Launch" configuration) Seems to have some kind of issue.
I created the project by running ESP-IDF: Show example projects and selecting the "blink" project. I then set the correct target and openOCD config files by running ESP-IDF: Device configuration. The launch configuration looks like this:
launch.json:
// Use IntelliSense to learn about possible attributes.
// Hover to view descriptions of existing attributes.
// For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
"version": "0.2.0",
"configurations": [
"type": "espidf",
"name": "Launch",
"request": "launch"
however the following happens when I start the "Launch" configuration:
- the debug window shows the following:
Debug adapter -> Extension: DEBUG_ADAPTER_STARTED
Debug adapter -> Extension: DEBUG_ADAPTER_READY2CONNECT
Debug Adapter initialized
Debug Adapter is running
- the terminal starts the "monitor" task (I didn't expect that) and shows the following:
Windows PowerShell
Copyright (C) 2009 Microsoft Corporation. All rights reserved.
PS C:\Users\vpascucci\Desktop\esp32_blink_vscode\blink2> C:\esp\.espressif\python_env\idf4.2_py3.8_env\Scripts\python.exe C:\esp\esp-idf\tools\idf.py -p COM13 monitor
Executing action: monitor
Running idf_monitor in directory c:\users\vpascucci\desktop\esp32_blink_vscode\blink2
Executing "C:\esp\.espressif\python_env\idf4.2_py3.8_env\Scripts\python.exe C:\esp\esp-idf\tools/idf_monitor.py -p COM13 -b 115200 --toolchain-prefix xtensa-esp32-elf- c:\users\vpascucci\desktop\esp32_blink_vscode\blink2\build\blink.elf -m 'C:\esp\.espressif\python_env\idf4.2_py3.8_env\Scripts\python.exe' 'C:\esp\esp-idf\tools\idf.py' '-p' 'COM13'"...
←[0;33m--- WARNING: GDB cannot open serial ports accessed as COMx←[0m
←[0;33m--- Using \\.\COM13 instead...←[0m
--- idf_monitor on \\.\COM13 115200 ---
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:4
load:0x3fff0034,len:7012
load:0x40078000,len:13212
load:0x40080400,len:4568
0x40080400: _init at ??:?
entry 0x400806f4
I (29) boot: ESP-IDF v4.2 2nd stage bootloader
I (29) boot: compile time 08:22:58
I (29) boot: chip revision: 1
I (31) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (39) boot.esp32: SPI Speed : 40MHz
I (43) boot.esp32: SPI Mode : DIO
I (48) boot.esp32: SPI Flash Size : 2MB
I (52) boot: Enabling RNG early entropy source...
I (58) boot: Partition Table:
I (61) boot: ## Label Usage Type ST Offset Length
I (69) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (76) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (83) boot: 2 factory factory app 00 00 00010000 00100000
I (91) boot: End of partition table
I (95) boot_comm: chip revision: 1, min. application chip revision: 0
I (102) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x05ae0 ( 23264) map
I (120) esp_image: segment 1: paddr=0x00015b08 vaddr=0x3ffb0000 size=0x0206c ( 8300) load
I (124) esp_image: segment 2: paddr=0x00017b7c vaddr=0x40080000 size=0x00404 ( 1028) load
0x40080000: _WindowOverflow4 at C:/esp/esp-idf/components/freertos/xtensa/xtensa_vectors.S:1730
I (130) esp_image: segment 3: paddr=0x00017f88 vaddr=0x40080404 size=0x08090 ( 32912) load
I (152) esp_image: segment 4: paddr=0x00020020 vaddr=0x400d0020 size=0x12e40 ( 77376) map
0x400d0020: _stext at ??:?
I (182) esp_image: segment 5: paddr=0x00032e68 vaddr=0x40088494 size=0x01a1c ( 6684) load
0x40088494: rtc_init at C:/esp/esp-idf/components/soc/src/esp32/rtc_init.c:51
I (191) boot: Loaded app from partition at offset 0x10000
I (191) boot: Disabling RNG early entropy source...
I (192) cpu_start: Pro cpu up.
I (195) cpu_start: Application information:
I (200) cpu_start: Project name: blink
I (205) cpu_start: App version: 1
I (209) cpu_start: Compile time: Apr 9 2021 08:21:39
I (215) cpu_start: ELF file SHA256: 2a0873531652dd5b...
I (221) cpu_start: ESP-IDF: v4.2
I (226) cpu_start: Starting app cpu, entry point is 0x400815c0
0x400815c0: call_start_cpu1 at C:/esp/esp-idf/components/esp32/cpu_start.c:287
I (0) cpu_start: App cpu up.
I (237) heap_init: Initializing. RAM available for dynamic allocation:
I (243) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (249) heap_init: At 3FFB28A0 len 0002D760 (181 KiB): DRAM
I (256) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (262) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (268) heap_init: At 40089EB0 len 00016150 (88 KiB): IRAM
I (275) cpu_start: Pro cpu start user code
I (293) spi_flash: detected chip: generic
I (294) spi_flash: flash io: dio
W (294) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (304) cpu_start: Starting scheduler on PRO CPU.
Turning off the LED
Turning on the LED
Turning off the LED
Turning on the LED
Turning off the LED
Turning on the LED
This seems to suggest that the program, which should be halted at the first instruction in app_main() is in fact running
- The output shows the following:
2021-04-09 08:26:33,794 - Debug Adapter (main) - CRITICAL - Debug adapter -> Extension: DEBUG_ADAPTER_STARTED
2021-04-09 08:26:33,802 - Debug Adapter (main) - CRITICAL - Debug adapter -> Extension: DEBUG_ADAPTER_READY2CONNECT
If I then press the "continue" arrow in the debug window nothing happens, and I cannot halt the process any more (which probably wasn't halted in the first place, as we discussed.
I should note that I also set up the same project to work with the "Native Debug" extension, and there, with same buard, debugger and general settings I can debug and step the code just fine. Any idea of what I might be doing wrong?
Thank you
Re: VS Code Blink Debug Problems
Posted: Fri Apr 16, 2021 2:39 pm
by ESP_bignacio
Maybe you can try disabling launching the monitor by setting `idf.launchMonitorOnDebugSession` to false and try again.
