Good morning,
I am working on a ESP32-S3 microcontroller and I need to implement the following feature.
I have an external component that generates a 4000Hz Clock and sends datas on the Rising Edge of the Clock on another
line (Let's say DATA line).
I need to latch the DATA bits on the rising edges of the Clock using the ESP32-S3 but I don't want to do this using interrupts
on the CLK signal because the period is 250us. Every 250us, I would have an interrupt in my program and because I
have a lot of processes to do, I fear this might disturb the processes.
I see that this is typically what SPI in slave mode can do (Except the fact that there is no CS line in our case).
Using the SPI Slave driver, I wanted to get the datas on the DATA line on the rising edges of the CLOCK.
However, because I have no CS line, it seems that the :
err = spi_slave_transmit(SPI2_HOST, &Transaction, portMAX_DELAY);
never exits.
The driver does not seem to understand that a transaction occur.
So my question is the following. Is it possible to use the SPI driver in Slave mode without the use of a CS line ?
If the answer is no, is it possible to use the SPI in Slave mode without the driver and without the CS line and how ?
Do you have another idea please ?
Thank you for your help on the subject,
Best regards,
Thomas TRUILHE
ESP32-S3 : Use of SPI in slave mode without CS line. Is it possible ?
Re: ESP32-S3 : Use of SPI in slave mode without CS line. Is it possible ?
That api seems to expect transactions delineated by C's changes.However, because I have no CS line, it seems that the :
never exits.
Two options that come to mind:
- toggle the CS state on a fake pin by setting their pull-up and pull down configuration.
- check whether this is a limitation of the api or the chip peripheral. If it's the latter, use the peripheral without the IDF api
Note that the CS signal is also needed for (re-)synchronization, so that the slave can know when a transaction and also a byte starts. Without CS, a slave would have no defined way to synchronize to the bytes sent if it were to ever miss a clock on the bus (e.g. if the master starts sending before the slave has initialized its SPI hardware.)
So, it seems mandatory to have the CS line set in SPI Slave Mode.
Am I right ?
Reading the Esp32-S3, it seems that it is included in the workflow.
Best regards,
Thomas TRUILHE
Am I right ?
Best regards,
Thomas TRUILHE
According to the reference manual, in the register : Register 30.9. SPI_MISC_REG (For SPI3 Only) (0x0020)
It seems that all the bits :
SPI_CS0_DIS SPI CS0 pin enable bit. 1: disable CS0. 0: SPI_CS0 signal is from/to CS0 pin.
SPI_CS1_DIS SPI CS1 pin enable bit. 1: disable CS1. 0: SPI_CS1 signal is from/to CS1 pin.
SPI_CS2_DIS SPI CS2 pin enable bit. 1: disable CS2. 0: SPI_CS2 signal is from/to CS2 pin.
Can be set to disable the CSX pins. But how can I be sure that the SPI3 will work or not in this case ?
Has someone already tried to use the SPI3 without CS line please ?
Best regards,
Thomas TRUILHE
Best regards,
Thomas TRUILHE
Another question please, if I do not use the CS line.
Do you know if the SPI_WX_REG will be written when datas are received ?
I want to say, do I have the possibility to read these buffer manually ? Without the interruption trigger ?
Users browsing this forum: No registered users and 157 guests
