Good morning,
I am using Bluedroid BLE stack in order to do BLE with an Esp32S3 chip and everything is ok.
The stack runs normally, I have no problems with it.
Now, I would like to enable Wifi in SoftAP mode when the chip starts in order to have the possibility
to upgrade the firmware via OTA.
Unfortunately, when I enable Wifi in SoftAP mode, the firmware does no manage to run the BLE stack anymore.
I get errors when the stack is executed.
Do you have any idea about what can happen please ??
Best regards,
Thomas TRUILHE
Esp32S3 : How to enable Wifi and BLE at the same time ?
Re: Esp32S3 : How to enable Wifi and BLE at the same time ?
it seams that it is a problem of memory,
when I initialise the bluedroid controller the error code is 0x101 out of memory.
Maybe the Wifi stack takes to much of internal memory ?
Excuse me, how can I know the amount of internal memory needed by the Bluedroid controller ?
And the amount of internal memory needed by the Wifi stack/driver ?
Can you confirm me that there elements are located into internal memory ?
Or can I use external memory ?
Best regards,
Thomas TRUILHE
Best regards,
Thomas TRUILHE
You can get an approximation of the dynamic RAM use by using the heap information API before + after starting the Bluetooth or WiFi stack.Excuse me, how can I know the amount of internal memory needed by the Bluedroid controller ?
You should be able to set CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST by setting Bluedroid menuconfig item "BT/BLE will first malloc the memory from the PSRAM" to reduce use of internal RAM.Or can I use external memory ?
Also, the NimBLE stack is reported to require less RAM than Bluedroid.
Users browsing this forum: No registered users and 201 guests
