can anybody share code of reading data from uart by using uart interrupt method
ningappa BS
Re: can anybody share code of reading data from uart by using uart interrupt method
Postby ningappa BS » Wed May 16, 2018 5:28 am
i tried replacing 20 / portTICK_RATE_MS with portMAX_DELAY but by using this it is waiting infinite time in that reading function.
here am sharing my code
#define TXD_PIN 1
#define RXD_PIN 3
void init() {
uart_config_t uart_config = {
.baud_rate = 115200,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
uart_param_config(UART_NUM_0, &uart_config);
uart_set_pin(UART_NUM_0, TXD_PIN, RXD_PIN, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
uart_driver_install(UART_NUM_0, 1024, 1024, 0, NULL, 0);
void tx_task()
uint8_t *data = (uint8_t *) malloc(1024);
while (1) {
printf("hiiii\n");
int len = uart_read_bytes(UART_NUM_0, data, 1024,portMAX_DELAY);
printf("hello\n");
uart_write_bytes(UART_NUM_0, (const char *)data, len);
void app_main()
init();
xTaskCreate(tx_task, "uart_tx_task", 1024*2, NULL, 5, NULL);
ningappa BS
Postby ningappa BS » Wed May 16, 2018 11:57 am
ningappa BS wrote:i tried replacing 20 / portTICK_RATE_MS with portMAX_DELAY but by using this it is waiting infinite time in that reading function.
#define TXD_PIN 1
#define RXD_PIN 3
void init() {
void tx_task()
while (1) {
printf("hiiii\n");
printf("hello\n");
void app_main()
init();
Deouss
Postby Deouss » Wed May 16, 2018 4:19 pm
I am also interested in uart functions
Found reference to interrupt handler function
esp_err_t uart_isr_register(uart_port_tuart_num, void (*fn)(void *), void *arg, int intr_alloc_flags, uart_isr_handle_t *handle, )
register UART interrupt handler(ISR).
Note
UART ISR handler will be attached to the same CPU core that this function is running on.
Return
ESP_OK Success
ESP_FAIL Parameter error
Parameters
uart_num: UART_NUM_0, UART_NUM_1 or UART_NUM_2
fn: Interrupt handler function.
arg: parameter for handler function
intr_alloc_flags: Flags used to allocate the interrupt. One or multiple (ORred) ESP_INTR_FLAG_* values. See esp_intr_alloc.h for more info.
handle: Pointer to return handle. If non-NULL, a handle for the interrupt will be returned here.
from https://esp-idf.readthedocs.io/en/v2.0/ ... #functions
ESP_Angus
Postby ESP_Angus » Thu May 17, 2018 2:08 am
The docs you link here are for an older version of ESP-IDF, V2.0. In V3.0 (current stable release) the docs were rearranged, the equivalent docs page is now here:
http://esp-idf.readthedocs.io/en/v3.0/a ... /uart.html
To switch to the even newer master branch then you can use the version pop-up in the bottom left.
Are you sure the UART is receiving data correctly? Are all the pins configured and connected correctly? If you use the unmodified "UART echo" example, does this work?
Deouss
Postby Deouss » Thu May 17, 2018 3:52 am
Do you know if there is a PDF document of whole documentation?
ningappa BS
Postby ningappa BS » Thu May 17, 2018 5:10 am
yes am sure UART working correctly, data receiving properly and unmodified echo example is working.
in this doc there is no function sequence.
loboris
Postby loboris » Thu May 17, 2018 7:43 am
Deouss wrote: Do you know if there is a PDF document of whole documentation?
Click on Read the Docs (bottom left) and select Downloads PDF.
ningappa BS
Postby ningappa BS » Fri May 18, 2018 9:56 am
ya it is there, is it there any driver code for uart interrupt method.
loboris
Postby loboris » Fri May 18, 2018 2:01 pm
ningappa BS wrote:ya it is there, is it there any driver code for uart interrupt method.
You can adapt the uart driver from esp-idf if it does not suits your needs.
Users browsing this forum: No registered users and 88 guests
