I'm wondering why there are internal Hall sensor and Temperature sensor on ESP32?
Are these two sensors used by WiFi, Bluetooth or some other functions to adjust their settings or improve their performance?
Or should I be aware of the temperature and magnetic field of the environment which will damage or disturb ESP32?
Is ESP32 a fragile chip which should be used and monitored more carefully so there comes with these two internal sensors?
[Solved] Why there are internal Hall sensor and Temperature sensor in ESP32
Re: Why there are internal Hall sensor and Temperature sensor in ESP32
The temperature sensor is used by WiFi, to compensate the calbibration for increasing temperratures if it's used in e.g. a WiFi lightbulb. The Hall sensor is not intrinsically used for anything.
Thanks. ESP_Sprite
Users browsing this forum: Bing [Bot], tomy983 and 193 guests
