ESP32 debugging with Segger Jlink
Re: ESP32 debugging with Segger Jlink
ESP32 debugging with Segger JLink worked fine for me an Ubuntu 14.04 machine with the binaries provided. I just faced the issue with clock frequency which was later resolved.
you mean that "GDB debugging".Could you please first verify if you are able to debug from the command line, before using Eclipse? Please follow these instructions: https://docs.espressif.com/projects/esp ... index.html
could you please share the steps you have followed because am getting errors which you can check in this conversation.ESP32 debugging with Segger JLink worked fine for me an Ubuntu 14.04 machine with the binaries provided. I just faced the issue with clock frequency which was later resolved.
thanks
I built the openocd from source by following steps from https://docs.espressif.com/projects/esp ... linux.html
Then the command openocd -s . -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Thanks,
Karim
Thanks,
Karim
Hi,Karim1993 wrote: ↑Mon Nov 05, 2018 12:11 pmI built the openocd from source by following steps from https://docs.espressif.com/projects/esp ... linux.html
Thanks,
Karim
i followed the procedure which you have given in the link
Steps followed....
step 1-----> cd ~/esp
step 2-----> git clone --recursive https://github.com/espressif/openocd-esp32.git
step 3-----> sudo apt-get install make
sudo apt-get install libtool
sudo apt-get install pkg-config
sudo apt-get install autoconf
sudo apt-get install automake
sudo apt-get install texinfo
sudo apt-get install libusb-1.0
step 4-----> cd ~/esp/openocd-esp32
./bootstrap
./configure
make
step 5----->openocd -s . -f interface/jlink.cfg -f board/esp-wroom-32.cfg
this is what am getting
"Warn : Unexpected idcode after end of chain: 627 0x00000000
Error: double-check your JTAG setup (interface, speed, ...)
Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -irlen 2 -expected-id 0x00000000"
Error: auto0.tap: IR capture error; saw 0x0000 not 0x0001
cpu0: Current bits set: none
cpu1: Current bits set: none"
Correct me if I am wrong and any suggestions on where I am going wrong is welcome.
let me know how to solve this.
thanks
hi Ningappa BS
Are you able to debug with Openocd and JTAG ?
-Arun
-Arun
hello Ningappa
I am getting
$ bin/openocd.exe -s -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Open On-Chip Debugger 0.10.0-dev (2018-11-05-04:10)
Licensed under GNU GPL v2
For bug reports, read
embedded:startup.tcl:60: Error: Can't find board/esp-wroom-32.cfg
in procedure 'script'
at file "embedded:startup.tcl", line 60
I am getting
hi,
i am using olimax debugger, it is working.
thanks,
thanks,
Users browsing this forum: 7777777, Bing [Bot] and 126 guests
