Wifi signal power.
Wifi signal power.
Is it possible to check what is the power of WiFi signal?
Re: Wifi signal power.
You mean you want to measure TX power in dbm? If yes then you can check it into make menuconfig for WiFi TX power with default settings as 20 dbm.
Let me know if you are thinking for different one.
Regards,
Ritesh Prajapati
Ritesh Prajapati
I use the function named esp_wifi_get_max_tx_power and it is all i have been needed.
So, Just want to know that using that API, You are able to get maximum TX Power. Correct?
Regards,
Ritesh Prajapati
Ritesh Prajapati
Great. So, Do you need any further help regarding same or is it done?
Regards,
Ritesh Prajapati
Ritesh Prajapati
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: jernst and 115 guests
