I (6295) mesh: 3356<scan>self-organized is disabled, users shall read out scan results by themselves.
I (6295) mesh_main: <MESH_EVENT_SCAN_DONE>number:29
W (6305) mesh_main: <MESH>[17]ESPM_711500, layer:1/5, assoc:0/6, 0, 4c:11:ae:71:15:01, channel:8, rssi:-46, ID<77:77:77:77:77:77><IE Encrypted>
W (6315) mesh_main: <PARENT>ESPM_711500, layer:1/5, assoc:0/6, 0, 4c:11:ae:71:15:01, channel:8, rssi:-46 ssid:77:77:77:77:77:77
I (6325) wifi: mode : sta (4c:11:ae:71:0d:6c) + softAP (4c:11:ae:71:0d:6d)
I (6335) wifi: Total power save buffer number: 16
I (6335) mesh: [IO]disable self-organizing<reconnect>
I (6355) wifi: Total power save buffer number: 16
I (6355) mesh_main: unknown id:2
I (6355) mesh: [MANUAL]connect to parent:ESPM_711500, 4c:11:ae:71:15:01[layer:1], ID:77:77:77:77:77:77<connect>
I (6725) mesh_main: <MESH_EVENT_PARENT_DISCONNECTED>reason:201,ssid:ESPM_711500,bssid:00:00:00:00:00:00
I (6725) mesh: [wifi]disconnected reason:201(), continuous:1/max:12, non-root, vote(,stopped)<><>
I (7095) mesh_main: <MESH_EVENT_PARENT_DISCONNECTED>reason:201,ssid:ESPM_711500,bssid:00:00:00:00:00:00
I (7095) mesh: [wifi]disconnected reason:201(), continuous:2/max:12, non-root, vote(,stopped)<><>
I (7465) mesh_main: <MESH_EVENT_PARENT_DISCONNECTED>reason:201,ssid:ESPM_711500,bssid:00:00:00:00:00:00
父节点显示已经连接上,I (6355) mesh: [MANUAL]connect to parent:ESPM_711500, 4c:11:ae:71:15:01[layer:1], ID:77:77:77:77:77:77<connect>但是还是不断连续收到201 错误事件 原因是。。。。? mesh 组网,采用人工自己寻父节点挂上,不太稳定,有时可以连接上,有时又不行
按照官网的mesh 人工组网例子manual_networking,出现持续201错误
Re: 按照官网的mesh 人工组网例子manual_networking,出现持续201错误
1. 201 是 WIFI_REASON_NO_AP_FOUND, 找不到父节点的 AP, 你可以查看一下与父节点之间的信号强度
2. 人工组网的方式你用在哪一种场景中? 一般情况使用自组就可以了 参考:https://github.com/espressif/esp-mdf
