Web Socket Server
filipESP
Web Socket Server
Postby filipESP » Fri Dec 06, 2019 11:08 am
I need to know if is possible to create a WebSocket Server on ESP WROOM. In IDF there is only WebSocketClient implementation.
I found some code in github for Arduino ESP32.
https://github.com/Links2004/arduinoWebSockets
Is any way to use it as IDF library?
Jakobsen
Re: Web Socket Server
Postby Jakobsen » Fri Dec 06, 2019 7:21 pm
Hi PilipESP
I use this componet from Blake Felt - Code high quality and a nice and clean bare metal implementation
https://github.com/Molorius/esp32-websocket
/Jorgen
Analog Digital IC designer / DevOps @ Merus Audio, Copenhagen, Denmark.
We do novel and best in class Audio amplifiers for consumer products.
Programmed assembler for C-64 back in 1980's, learned some electronics - hacking since then
StefanRvO
Postby StefanRvO » Sun Dec 08, 2019 11:46 am
I am using mongoose(https://github.com/cesanta/mongoose) in my project (see here for how i use it: (https://gitlab.com/StefanRvO/light-equa ... r_module.c).
Libwebsockets (https://github.com/warmcat/libwebsockets) should also be working as far as i know, but i found it a bit more difficult to use than mongoose.
Ritesh
Contact:
Postby Ritesh » Sun Dec 08, 2019 6:22 pm
Did you try to port libwebsocket Library for ESP32? Because we have tried it earlier and faced some compilation issues with ESP32 IDF.
Let us know if anyone has tried and used it for ESP32 Target.
Regards,
Ritesh Prajapati
filipESP
Postby filipESP » Mon Dec 09, 2019 6:39 pm
Hi PilipESP
/Jorgen
Could you tell me how to log into the server and is it possible to create something like dashboard?
filipESP
Postby filipESP » Tue Dec 10, 2019 12:15 pm
OK, i got it!
Thank U very much.
StefanRvO
Postby StefanRvO » Mon Dec 30, 2019 1:48 am
I belive i got it working some time ago (~a year). I can't really remember what i did to make it work. I concluded that it would take to long to rewrite my webcode to use libwebsockets instead of mongoose, so i didn't use more than about a week on it, but i do think i got their demo running at the time (https://github.com/warmcat/lws-esp32-factory)
Ritesh
Contact:
Postby Ritesh » Mon Dec 30, 2019 8:30 am
Thanks.
We have refereed same at out end and moved further for same. So, We have taken reference of master branch in which libwebsocket example is ported with few fixes and same for transport related changes.
Regards,
Ritesh Prajapati
filipESP
Postby filipESP » Tue Mar 24, 2020 12:49 pm
Hi PilipESP
/Jorgen
Hello again Jakobsen.
Did you tested your code in terms of serving any jpg, svg, png file?
Jakobsen
Postby Jakobsen » Tue Mar 24, 2020 9:22 pm
No - But
I use it for raw date - amplifier status, audio samples to be displayed on canvas etc. Do not see why it would not work for image data on a specific format as well.
/j
Users browsing this forum: Bing [Bot], User4356 and 57 guests
