您好我有一个关于数据传输的问题想咨询
您好我有一个关于数据传输的问题想咨询
有任何关于 这几种函数的 使用方法的例子吗 esp_mesh_send() esp_mesh_recv() esp_mesh_recv_toDS
Re: 您好我有一个关于数据传输的问题想咨询
就是MESH中的所有设备需要通过HTTP 方式来进行云平台激活 若将所有设备的ID发到根节点进行转发的话 列如平台中心跳之类的操作进行就很麻烦 且本身已经使用了MQTT
为啥MESH中会出现一些不是输出的LOG参数 有办法消除他吗 但是我不想禁止我自己打印的LOG
I (114829) mesh: [scan]new scanning time:1500ms
I (141449) mesh: 4397<assoc>parent layer:1, channel:13, rssi:-4, assoc:3, rssi threshold<-78,-82,-85>
I (266379) mesh: 4397<assoc>parent layer:1, channel:13, rssi:-4, assoc:3, rssi threshold<-78,-82,-85>
I (349649) mesh: 1891<arm>parent monitor, my layer:2(cap:16)(node), interval:11659ms, retries:1<>
I (361589) mesh: 4433<active>parent layer:1(node), channel:13, rssi:-4, assoc:3(cnx rssi threshold:-120)my_assoc:0
I (363089) mesh: 5177<scan>parent layer:1, rssi:-7, assoc:3(cnx rssi threshold:-120)
I (363089) mesh: [SCAN][ch:13]AP:3, other(ID:0, RD:0), MAP:3, idle:0, candidate:3, root:1, topMAP:0[c:2,i:2][2c:30:33:f6:66:cc]<weak>
I (363099) mesh: 6563[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85>
I (363099) mesh: 616[monitor]no change, parent:24:6f:28:95:00:3d, rssi:-7
I (363109) mesh: 1891<arm>parent monitor, my layer:2(cap:16)(node), interval:8527ms, retries:2<>
I (371849) mesh: 4433<active>parent layer:1(node), channel:13, rssi:-4, assoc:3(cnx rssi threshold:-120)my_assoc:0
I (373349) mesh: 5177<scan>parent layer:1, rssi:-6, assoc:3(cnx rssi threshold:-120)
I (373349) mesh: [SCAN][ch:13]AP:3, other(ID:0, RD:0), MAP:3, idle:0, candidate:3, root:1, topMAP:2[c:0,i:2][2c:30:33:f6:66:cc]<weak>
I (373359) mesh: 6563[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85>
I (373369) mesh: 616[monitor]no change, parent:24:6f:28:95:00:3d, rssi:-6
I (373369) mesh: 1891<arm>parent monitor, my layer:2(cap:16)(node), interval:7497ms, retries:3<>
I (381059) mesh: 4433<active>parent layer:1(node), channel:13, rssi:-4, assoc:3(cnx rssi threshold:-120)my_assoc:0
I (382559) mesh: 5177<scan>parent layer:1, rssi:-7, assoc:3(cnx rssi threshold:-120)
I (382559) mesh: [SCAN][ch:13]AP:3, other(ID:0, RD:0), MAP:3, idle:0, candidate:3, root:1, topMAP:0[c:2,i:2][2c:30:33:f6:66:cc]<weak>
I (382569) mesh: 6563[weak]try rssi_threshold:-120, backoff times:0, max:5<-78,-82,-85>
I (382579) mesh: 616[monitor]no change, parent:24:6f:28:95:00:3d, rssi:-7
I (382579) mesh: 1891<arm>parent monitor, my layer:2(cap:16)(node), interval:366275ms, retries:3<>
I (391299) mesh: 4397<assoc>parent layer:1, channel:13, rssi:-4, assoc:3, rssi threshold<-78,-82,-85>
Users browsing this forum: No registered users and 33 guests
