examples/peripherals/pcnt/main/pcnt_example_main.c Bug
warren
Postby warren » Tue Mar 03, 2020 2:28 am
In the following code found at:
https://github.com/espressif/esp-idf/bl ... ple_main.c
the following lines are erroneous:
            if (evt.status & PCNT_EVT_THRES_1) {
                printf("THRES1 EVT\n");
            if (evt.status & PCNT_EVT_THRES_0) {
                printf("THRES0 EVT\n");
            if (evt.status & PCNT_EVT_L_LIM) {
                printf("L_LIM EVT\n");
            if (evt.status & PCNT_EVT_H_LIM) {
                printf("H_LIM EVT\n");
            if (evt.status & PCNT_EVT_ZERO) {
                printf("ZERO EVT\n");
The names PCNT_EVT_THRES_1 and company are enum values which do not match the bit values in that status word. They are declared as follows:
typedef enum {
    PCNT_EVT_L_LIM = 0,             /*!< PCNT watch point event: Minimum counter value */
    PCNT_EVT_H_LIM = 1,             /*!< PCNT watch point event: Maximum counter value */
    PCNT_EVT_THRES_0 = 2,           /*!< PCNT watch point event: threshold0 value event */
    PCNT_EVT_THRES_1 = 3,           /*!< PCNT watch point event: threshold1 value event */
    PCNT_EVT_ZERO = 4,              /*!< PCNT watch point event: counter value zero event */
    PCNT_EVT_MAX
} pcnt_evt_type_t;
The following homebrewed values work as intended:
#define EvtMask_thres1_lat  0b00000100
#define EvtMask_thres0_lat  0b00001000
#define EvtMask_l_lim_lat   0b00010000
#define EvtMask_h_lim_lat   0b00100000
#define EvtMask_zero_lat    0b01000000
#define EvtMask_cnt_mode    0b00000011
ESP_houwenxiang
Re: examples/peripherals/pcnt/main/pcnt_example_main.c Bug
Postby ESP_houwenxiang » Tue Mar 03, 2020 2:40 am
What version of IDF are you using?
https://github.com/espressif/esp-idf/bl ... nt_types.h
wookooho
warren
Postby warren » Tue Mar 03, 2020 7:44 pm
This is the example you have online at github, from the master branch:
Warren
warren
Postby warren » Sat Mar 07, 2020 12:57 pm
I found some macros ending in the _M suffix (like PCNT_STATUS_THRES0_M), which seem to be the correct mask values to use.
if (evt.status & PCNT_STATUS_THRES0_M) {
Users browsing this forum: No registered users and 75 guests
