How to set STATIC pairing PIN in bt_spp_vfs_acceptor ?
ht_main1
Postby ht_main1 » Wed May 20, 2020 8:18 am
I ran the example code for BT SPP from esp-idfv4.0 example code ? i just want to know how do i set the STATIC PIN for pairing BT ?
In the code it generate random pairing key.
in advance
Bushi1e
Re: How to set STATIC pairing PIN in bt_spp_vfs_acceptor ?
Postby Bushi1e » Wed May 20, 2020 10:52 am
To disconnect from the paired Bluetooth device, press and hold the Power/pairing button on your speaker for one prepaid gift balance.
chegewara
Postby chegewara » Wed May 20, 2020 12:29 pm
https://github.com/espressif/esp-idf/bl ... #L102-L108
You have also change option in menuconfig, disable Secure simple pairing (or enable).
ht_main1
Postby ht_main1 » Wed May 20, 2020 7:18 pm
Secure simple pairing (disabling this throws error for esp_bt_gap_set_pin )
i added the code from link as below,
is it right ?
    case ESP_SPP_INIT_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_INIT_EVT");
        esp_bt_dev_set_device_name("bt_server");
	esp_bt_pin_type_t pin_type = ESP_BT_PIN_TYPE_FIXED;
	esp_bt_pin_code_t pin_code;
	pin_code[0] = '0';
	pin_code[1] = '0';
	pin_code[2] = '0';
	pin_code[3] = '0';
	esp_bt_gap_set_pin(pin_type, 4, pin_code);
        esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE);
        esp_spp_start_srv(sec_mask,role_slave, 0, SPP_SERVER_NAME);
        break;
chegewara
Postby chegewara » Thu May 21, 2020 9:03 am
I have bt classic project i finished 2 days ago and now checked to make sure. You have to disable
to make use of static pin code.
https://github.com/espressif/esp-idf/is ... -443575348
ht_main1
Postby ht_main1 » Sat May 23, 2020 6:22 pm
Thanks that solved it, i had to manual insert following code, i was getting error on compilations,
#define CONFIG_CLASSIC_BT_ENABLED 1
#define CONFIG_BT_SPP_ENABLED 1
i found from this comment https://github.com/platformio/platform ... -475671300
Thanks @chegewara you always provide right and accurate information.
Keep doing best work. Take care
chegewara
Postby chegewara » Sun May 24, 2020 11:16 am
Thats strange, because those flags are already there:
https://github.com/espressif/esp-idf/bl ... g.defaults
Maybe try to use idf.py defconfig.
ht_main1 wrote: Thanks @chegewara you always provide right and accurate information.
Users browsing this forum: No registered users and 25 guests
