xTaskCreate: invalid conversion from 'void (*)()' to 'TaskFunction_t {aka void (*)(void*)}'
azz-zza
Postby azz-zza » Wed Jul 01, 2020 10:24 pm
i can not figure out what am i doing incorrectly here. Please advise.
void publish_data() {
void setup () {
TaskHandle_t xHandle = NULL;
BaseType_t  xReturned = xTaskCreate(&publish_data, (const char*) "Task", 4048, 	(void*)	 1, NULL, &xHandle);
src/main.cpp: In function 'void setup()':
src/main.cpp:125:109: error: invalid conversion from 'void (*)()' to 'TaskFunction_t {aka void (*)(void*)}' [-fpermissive]
boarchuz
Re: xTaskCreate: invalid conversion from 'void (*)()' to 'TaskFunction_t {aka void (*)(void*)}'
Postby boarchuz » Thu Jul 02, 2020 2:18 am
void publish_data(void *you_need_this) {
azz-zza
Postby azz-zza » Thu Jul 02, 2020 4:44 am
ohhh.. (facepalm)....
Thank you so much.
and how do i call the createTask if i do not need any params passed to the procedure?
Postby ESP_Sprite » Thu Jul 02, 2020 9:03 am
Use NULL (any other value will technically work as well, as your task ignores it anyway) instead of the parameter.
azz-zza
Postby azz-zza » Thu Jul 02, 2020 12:46 pm
Thank you very much. Works perfectly.
The issue was not in the the xTaskCreate, but rather that callback procedure should have parameter.
Users browsing this forum: Majestic-12 [Bot] and 115 guests
