ESP-MDF Development workflow
Twinstar
Postby Twinstar » Tue Oct 20, 2020 5:41 pm
***UPDATE***
Compiling can be speed up with 'make -j', which uses all of my cores, neat!
Still unanswered:
Is there an IDE for esp-mdf with intelli-sense?
How do i add custom libraries such as the Adafruit_Neopixel https://learn.adafruit.com/adafruit-neo ... ibrary-use lib?
**OG Post**
Hey there,
i spend the last 2 days figuring out how to use the ESP-MDF Framework and i finally managed to flash one ESP32 WROOM with the get-started example.
It takes forever to compile and upload, everytime i change a thing, even when i just change the USB Port with
make menuconfig
. It compiles everything again. I use SublimeText3 to edit the source files. Than with the Ubuntu 20.04 bash i use
make flash
in the project folder to upload the code.
So i wonder how can i improve my workflow? I read Platform.io is great, but it does not support esp-mdf (yet). Any IDE suggestions with intellisens and build automation would be great!
Background:
I build a LED Mesh Network with ESP8266 and PainlessMesh, but this network was too unstable, the wifi code crashed the LED Code or vice versa. Even though i used the TaskScheduler...
So i switched to the ESP32 and esp-mesh, because this looked like a solid choice. I come from the Arduine IDE for developing small IoT applications. The Ubuntu command line approach feels just so much more complicated and taxing.
This is what i see every time.
esp-mdf/examples/get-started$ make flash
Toolchain path: /home/tobias/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
WARNING: Toolchain version is not supported: esp-2020r3
Expected to see version: esp-2020r2
Please check ESP-IDF setup instructions and update the toolchain, or proceed at your own risk.
WARNING: Compiler version is not supported: 8.4.0
Expected to see version(s): 8.2.0
Python requirements from /mnt/e/Nextcloud/Basteln/Cluster_Tube_Lights/esp-mdf/esp-idf/requirements.txt are satisfied.
App "get-started" version: v1.0-101-gb9865ed
CC build/bootloader/bootloader_support/src/bootloader_efuse_esp32.o
CC build/bootloader/bootloader_support/src/bootloader_flash.o
CC build/bootloader/bootloader_support/src/flash_qio_mode.o
CC build/bootloader/bootloader_support/src/bootloader_init.o
CC build/bootloader/bootloader_support/src/bootloader_mem.o
CC build/bootloader/bootloader_support/src/bootloader_utility.o
CC build/bootloader/bootloader_support/src/bootloader_common.o
CC build/bootloader/bootloader_support/src/bootloader_clock.o
CC build/bootloader/bootloader_support/src/bootloader_flash_config_esp32.o
CC build/bootloader/bootloader_support/src/flash_partitions.o
CC build/bootloader/bootloader_support/src/esp_image_format.o
CC build/bootloader/bootloader_support/src/flash_encrypt.o
CC build/bootloader/bootloader_support/src/bootloader_random.o
CC build/bootloader/bootloader_support/src/esp32/bootloader_sha.o
CC build/bootloader/bootloader_support/src/esp32/bootloader_esp32.o
CC build/bootloader/bootloader_support/src/esp32/flash_encrypt.o
AR build/bootloader/bootloader_support/libbootloader_support.a
CC build/bootloader/log/log.o
CC build/bootloader/log/log_noos.o
CC build/bootloader/log/log_buffers.o
AR build/bootloader/log/liblog.a
CC build/bootloader/spi_flash/esp32/spi_flash_rom_patch.o
AR build/bootloader/spi_flash/libspi_flash.a
CC build/bootloader/soc/src/cpu_util.o
CC build/bootloader/soc/src/lldesc.o
CC build/bootloader/soc/src/memory_layout_utils.o
CC build/bootloader/soc/src/compare_set.o
CC build/bootloader/soc/src/soc_include_legacy_warn.o
CC build/bootloader/soc/src/hal/spi_hal.o
CC build/bootloader/soc/src/hal/spi_slave_hal_iram.o
CC build/bootloader/soc/src/hal/timer_hal.o
CC build/bootloader/soc/src/hal/dac_hal.o
CC build/bootloader/soc/src/hal/mcpwm_hal.o
CC build/bootloader/soc/src/hal/spi_slave_hal.o
CC build/bootloader/soc/src/hal/adc_hal.o
CC build/bootloader/soc/src/hal/wdt_hal_iram.o
CC build/bootloader/soc/src/hal/spi_flash_hal_iram.o
CC build/bootloader/soc/src/hal/spi_flash_hal.o
CC build/bootloader/soc/src/hal/touch_sensor_hal.o
CC build/bootloader/soc/src/hal/spi_hal_iram.o
CC build/bootloader/soc/src/hal/soc_hal.o
CC build/bootloader/soc/src/hal/sdio_slave_hal.o
CC build/bootloader/soc/src/hal/ledc_hal_iram.o
CC build/bootloader/soc/src/hal/ledc_hal.o
CC build/bootloader/soc/src/hal/twai_hal.o
CC build/bootloader/soc/src/hal/gpio_hal.o
CC build/bootloader/soc/src/hal/spi_flash_hal_gpspi.o
CC build/bootloader/soc/src/hal/cpu_hal.o
CC build/bootloader/soc/src/esp32/touch_sensor_hal.o
CC build/bootloader/soc/src/esp32/brownout_hal.o
CC build/bootloader/soc/src/esp32/adc_hal.o
CC build/bootloader/soc/src/esp32/rtc_init.o
CC build/bootloader/soc/src/esp32/rtc_clk_init.o
CC build/bootloader/soc/src/esp32/rtc_sleep.o
CC build/bootloader/soc/src/esp32/rtc_time.o
CC build/bootloader/soc/src/esp32/rtc_clk.o
CC build/bootloader/soc/src/esp32/emac_hal.o
CC build/bootloader/soc/soc/esp32/spi_periph.o
AR build/bootloader/soc/libsoc.a
CC build/bootloader/main/bootloader_start.o
AR build/bootloader/main/libmain.a
CC build/bootloader/efuse/esp32/esp_efuse_table.o
CC build/bootloader/efuse/src/esp_efuse_utility.o
CC build/bootloader/efuse/src/esp_efuse_fields.o
CC build/bootloader/efuse/src/esp_efuse_api.o
CC build/bootloader/efuse/src/esp32/esp_efuse_api.o
CC build/bootloader/efuse/src/esp32/esp_efuse_utility.o
CC build/bootloader/efuse/src/esp32/esp_efuse_fields.o
AR build/bootloader/efuse/libefuse.a
LD build/bootloader/bootloader.elf
esptool.py v3.0-dev
Building partitions from /mnt/e/Nextcloud/Basteln/Cluster_Tube_Lights/esp-mdf/examples/get-started/partitions.csv...
CC build/app_trace/app_trace_util.o
CC build/app_trace/host_file_io.o
CC build/app_trace/app_trace.o
CC build/app_trace/heap_trace_tohost.o
CC build/app_trace/gcov/gcov_rtio.o
AR build/app_trace/libapp_trace.a
CC build/app_update/esp_ota_ops.o
CC build/app_update/esp_app_desc.o
AR build/app_update/libapp_update.a
CXX build/asio/asio/asio/src/asio.o
AR build/asio/libasio.a
CC build/bootloader_support/src/bootloader_efuse_esp32.o
CC build/bootloader_support/src/bootloader_flash.o
CC build/bootloader_support/src/flash_qio_mode.o
CC build/bootloader_support/src/bootloader_mem.o
CC build/bootloader_support/src/bootloader_utility.o
CC build/bootloader_support/src/bootloader_common.o
CC build/bootloader_support/src/bootloader_clock.o
CC build/bootloader_support/src/bootloader_flash_config_esp32.o
CC build/bootloader_support/src/flash_partitions.o
CC build/bootloader_support/src/esp_image_format.o
CC build/bootloader_support/src/flash_encrypt.o
CC build/bootloader_support/src/bootloader_random.o
CC build/bootloader_support/src/idf/bootloader_sha.o
AR build/bootloader_support/libbootloader_support.a
CC build/cbor/tinycbor/src/cborparser.o
CC build/cbor/tinycbor/src/cborvalidation.o
CC build/cbor/tinycbor/src/open_memstream.o
CC build/cbor/tinycbor/src/cborparser_dup_string.o
CC build/cbor/tinycbor/src/cborencoder.o
CC build/cbor/tinycbor/src/cborerrorstrings.o
CC build/cbor/tinycbor/src/cborpretty.o
CC build/cbor/tinycbor/src/cbortojson.o
CC build/cbor/tinycbor/src/cborpretty_stdio.o
CC build/cbor/tinycbor/src/cborencoder_close_container_checked.o
AR build/cbor/libcbor.a
CC build/coap/libcoap/src/address.o
CC build/coap/libcoap/src/async.o
CC build/coap/libcoap/src/block.o
CC build/coap/libcoap/src/coap_event.o
CC build/coap/libcoap/src/coap_hashkey.o
CC build/coap/libcoap/src/coap_session.o
CC build/coap/libcoap/src/coap_time.o
CC build/coap/port/coap_debug.o
CC build/coap/libcoap/src/encode.o
CC build/coap/libcoap/src/mem.o
CC build/coap/libcoap/src/net.o
CC build/coap/libcoap/src/option.o
CC build/coap/libcoap/src/pdu.o
CC build/coap/libcoap/src/resource.o
CC build/coap/libcoap/src/str.o
CC build/coap/libcoap/src/subscribe.o
CC build/coap/libcoap/src/uri.o
CC build/coap/port/coap_mbedtls.o
CC build/coap/libcoap/src/coap_io.o
CC build/coap/port/coap_notls.o
AR build/coap/libcoap.a
CC build/console/esp_console_repl.o
CC build/console/commands.o
AR build/console/libconsole.a
CXX build/cxx/cxx_guards.o
CXX build/cxx/cxx_exception_stubs.o
AR build/cxx/libcxx.a
CC build/driver/spi_common.o
CC build/driver/adc_common.o
CC build/driver/spi_master.o
CC build/driver/sigmadelta.o
CC build/driver/sdspi_transaction.o
CC build/driver/touch_sensor_common.o
CC build/driver/sdio_slave.o
CC build/driver/i2s.o
CC build/driver/periph_ctrl.o
CC build/driver/ledc.o
CC build/driver/uart.o
CC build/driver/twai.o
CC build/driver/sdspi_host.o
CC build/driver/gpio.o
CC build/driver/timer.o
CC build/driver/pcnt.o
CC build/driver/sdspi_crc.o
CC build/driver/sdmmc_host.o
CC build/driver/dac.o
CC build/driver/spi_bus_lock.o
CC build/driver/mcpwm.o
CC build/driver/sdmmc_transaction.o
CC build/driver/spi_slave.o
CC build/driver/rtc_io.o
CC build/driver/i2c.o
CC build/driver/rmt.o
CC build/driver/rtc_module.o
CC build/driver/esp32/touch_sensor.o
CC build/driver/esp32/adc.o
AR build/driver/libdriver.a
CC build/efuse/esp32/esp_efuse_table.o
CC build/efuse/src/esp_efuse_utility.o
CC build/efuse/src/esp_efuse_fields.o
CC build/efuse/src/esp_efuse_api.o
CC build/efuse/src/esp32/esp_efuse_api.o
CC build/efuse/src/esp32/esp_efuse_utility.o
CC build/efuse/src/esp32/esp_efuse_fields.o
AR build/efuse/libefuse.a
CC build/esp-tls/esp_tls.o
CC build/esp-tls/esp_tls_mbedtls.o
AR build/esp-tls/libesp-tls.a
CC build/esp32/sleep_modes.o
CC build/esp32/cpu_start.o
CC build/esp32/cache_sram_mmu.o
CC build/esp32/crosscore_int.o
CC build/esp32/pm_trace.o
CC build/esp32/spiram_psram.o
CC build/esp32/clk.o
CC build/esp32/spiram.o
CC build/esp32/cache_err_int.o
CC build/esp32/intr_alloc.o
CC build/esp32/system_api_esp32.o
CC build/esp32/pm_esp32.o
CC build/esp32/hw_random.o
CC build/esp32/dport_access.o
CC build/esp32/esp_himem.o
AR build/esp32/libesp32.a
CC build/esp_adc_cal/esp_adc_cal.o
AR build/esp_adc_cal/libesp_adc_cal.a
CC build/esp_common/src/task_wdt.o
CC build/esp_common/src/dbg_stubs.o
CC build/esp_common/src/int_wdt.o
CC build/esp_common/src/mac_addr.o
CC build/esp_common/src/freertos_hooks.o
CC build/esp_common/src/esp_err.o
CC build/esp_common/src/pm_locks.o
CC build/esp_common/src/esp_err_to_name.o
CC build/esp_common/src/stack_check.o
CC build/esp_common/src/brownout.o
AR build/esp_common/libesp_common.a
CC build/esp_eth/src/esp_eth_phy.o
CC build/esp_eth/src/esp_eth_phy_lan8720.o
CC build/esp_eth/src/esp_eth_phy_ip101.o
CC build/esp_eth/src/esp_eth_mac_esp32.o
CC build/esp_eth/src/esp_eth_phy_rtl8201.o
CC build/esp_eth/src/esp_eth.o
CC build/esp_eth/src/esp_eth_phy_dp83848.o
CC build/esp_eth/src/esp_eth_netif_glue.o
AR build/esp_eth/libesp_eth.a
CC build/esp_event/default_event_loop.o
CC build/esp_event/event_send.o
CC build/esp_event/esp_event.o
CC build/esp_event/event_loop_legacy.o
CC build/esp_event/esp_event_private.o
AR build/esp_event/libesp_event.a
CC build/esp_gdbstub/src/packet.o
CC build/esp_gdbstub/src/gdbstub.o
CC build/esp_gdbstub/esp32/gdbstub_esp32.o
CC build/esp_gdbstub/xtensa/gdbstub_xtensa.o
AR build/esp_gdbstub/libesp_gdbstub.a
CC build/esp_hid/src/esp_hidh.o
CC build/esp_hid/src/esp_hid_common.o
CC build/esp_hid/src/ble_hidh.o
CC build/esp_hid/src/esp_hidd.o
CC build/esp_hid/src/ble_hidd.o
CC build/esp_hid/src/bt_hidh.o
AR build/esp_hid/libesp_hid.a
CC build/esp_http_client/esp_http_client.o
CC build/esp_http_client/lib/http_header.o
CC build/esp_http_client/lib/http_auth.o
CC build/esp_http_client/lib/http_utils.o
AR build/esp_http_client/libesp_http_client.a
CC build/esp_http_server/src/httpd_main.o
CC build/esp_http_server/src/httpd_txrx.o
CC build/esp_http_server/src/httpd_ws.o
CC build/esp_http_server/src/httpd_uri.o
CC build/esp_http_server/src/httpd_parse.o
CC build/esp_http_server/src/httpd_sess.o
CC build/esp_http_server/src/util/ctrl_sock.o
AR build/esp_http_server/libesp_http_server.a
CC build/esp_https_ota/src/esp_https_ota.o
AR build/esp_https_ota/libesp_https_ota.a
CC build/esp_ipc/ipc.o
AR build/esp_ipc/libesp_ipc.a
CC build/esp_local_ctrl/src/esp_local_ctrl_handler.o
CC build/esp_local_ctrl/src/esp_local_ctrl.o
CC build/esp_local_ctrl/proto-c/esp_local_ctrl.pb-c.o
AR build/esp_local_ctrl/libesp_local_ctrl.a
CC build/esp_netif/esp_netif_defaults.o
CC build/esp_netif/esp_netif_objects.o
CC build/esp_netif/esp_netif_handlers.o
CC build/esp_netif/lwip/esp_netif_lwip_ppp.o
CC build/esp_netif/lwip/esp_netif_sta_list.o
CC build/esp_netif/lwip/esp_netif_lwip.o
CC build/esp_netif/lwip/esp_netif_lwip_defaults.o
CC build/esp_netif/loopback/esp_netif_loopback.o
AR build/esp_netif/libesp_netif.a
CC build/esp_ringbuf/ringbuf.o
AR build/esp_ringbuf/libesp_ringbuf.a
CC build/esp_serial_slave_link/essl_sdio.o
CC build/esp_serial_slave_link/essl.o
AR build/esp_serial_slave_link/libesp_serial_slave_link.a
CC build/esp_system/panic.o
CC build/esp_system/system_api.o
CC build/esp_system/port/panic_handler.o
CC build/esp_system/port/esp32/reset_reason.o
AS build/esp_system/port/panic_handler_asm.o
AS build/esp_system/port/esp32/dport_panic_highint_hdl.o
AR build/esp_system/libesp_system.a
CC build/esp_timer/src/ets_timer_legacy.o
CC build/esp_timer/src/esp_timer_impl_lac.o
CC build/esp_timer/src/esp_timer.o
AR build/esp_timer/libesp_timer.a
CC build/esp_websocket_client/esp_websocket_client.o
AR build/esp_websocket_client/libesp_websocket_client.a
CC build/esp_wifi/src/lib_printf.o
CC build/esp_wifi/src/smartconfig.o
CC build/esp_wifi/src/wifi_default.o
CC build/esp_wifi/src/phy_init.o
CC build/esp_wifi/src/mesh_event.o
CC build/esp_wifi/src/smartconfig_ack.o
CC build/esp_wifi/src/coexist.o
CC build/esp_wifi/src/wifi_netif.o
CC build/esp_wifi/src/wifi_init.o
CC build/esp_wifi/esp32/esp_adapter.o
AR build/esp_wifi/libesp_wifi.a
CC build/espcoredump/src/core_dump_port.o
CC build/espcoredump/src/core_dump_flash.o
CC build/espcoredump/src/core_dump_common.o
CC build/espcoredump/src/core_dump_uart.o
CC build/espcoredump/src/core_dump_elf.o
AR build/espcoredump/libespcoredump.a
CC build/expat/expat/expat/lib/xmlparse.o
AR build/expat/libexpat.a
CC build/fatfs/diskio/diskio_wl.o
CC build/fatfs/diskio/diskio_rawflash.o
CC build/fatfs/diskio/diskio_sdmmc.o
CC build/fatfs/diskio/diskio.o
CC build/fatfs/vfs/vfs_fat_sdmmc.o
CC build/fatfs/vfs/vfs_fat_spiflash.o
CC build/fatfs/vfs/vfs_fat.o
CC build/fatfs/port/freertos/ffsystem.o
CC build/fatfs/src/ff.o
CC build/fatfs/src/ffunicode.o
AR build/fatfs/libfatfs.a
CC build/freemodbus/common/esp_modbus_master.o
CC build/freemodbus/common/esp_modbus_slave.o
CC build/freemodbus/modbus/mb_m.o
CC build/freemodbus/modbus/mb.o
CC build/freemodbus/modbus/ascii/mbascii.o
CC build/freemodbus/modbus/ascii/mbascii_m.o
CC build/freemodbus/modbus/functions/mbfuncholding.o
CC build/freemodbus/modbus/functions/mbfuncinput.o
CC build/freemodbus/modbus/functions/mbfuncinput_m.o
CC build/freemodbus/modbus/functions/mbfuncdisc.o
CC build/freemodbus/modbus/functions/mbfuncother.o
CC build/freemodbus/modbus/functions/mbfuncdisc_m.o
CC build/freemodbus/modbus/functions/mbfunccoils.o
CC build/freemodbus/modbus/functions/mbfunccoils_m.o
CC build/freemodbus/modbus/functions/mbfuncholding_m.o
CC build/freemodbus/modbus/functions/mbutils.o
CC build/freemodbus/modbus/rtu/mbrtu_m.o
CC build/freemodbus/modbus/rtu/mbcrc.o
CC build/freemodbus/modbus/rtu/mbrtu.o
CC build/freemodbus/modbus/tcp/mbtcp.o
CC build/freemodbus/serial_slave/modbus_controller/mbc_serial_slave.o
CC build/freemodbus/serial_master/modbus_controller/mbc_serial_master.o
CC build/freemodbus/port/portevent_m.o
CC build/freemodbus/port/portother_m.o
CC build/freemodbus/port/porttimer_m.o
CC build/freemodbus/port/portserial_m.o
CC build/freemodbus/port/portother.o
CC build/freemodbus/port/port.o
CC build/freemodbus/port/porttimer.o
CC build/freemodbus/port/portserial.o
CC build/freemodbus/port/portevent.o
AR build/freemodbus/libfreemodbus.a
CC build/freertos/queue.o
CC build/freertos/croutine.o
CC build/freertos/list.o
CC build/freertos/event_groups.o
CC build/freertos/tasks.o
CC build/freertos/timers.o
CC build/freertos/FreeRTOS-openocd.o
CC build/freertos/xtensa/xtensa_intr.o
CC build/freertos/xtensa/xtensa_init.o
CC build/freertos/xtensa/port.o
CC build/freertos/xtensa/xtensa_overlay_os_hook.o
AS build/freertos/xtensa/xtensa_intr_asm.o
AS build/freertos/xtensa/xtensa_context.o
AS build/freertos/xtensa/xtensa_vectors.o
AS build/freertos/xtensa/xtensa_vector_defaults.o
AS build/freertos/xtensa/portasm.o
AR build/freertos/libfreertos.a
CC build/heap/heap_caps_init.o
CC build/heap/heap_caps.o
CC build/heap/multi_heap.o
AR build/heap/libheap.a
CC build/libsodium/port/randombytes_esp32.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/generichash_blake2b.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_secretbox/crypto_secretbox_easy.o
CC build/libsodium/libsodium/src/libsodium/randombytes/randombytes.o
CC build/libsodium/libsodium/src/libsodium/sodium/utils.o
AR build/libsodium/liblibsodium.a
CC build/log/log.o
CC build/log/log_freertos.o
CC build/log/log_buffers.o
AR build/log/liblog.a
CC build/lwip/apps/dhcpserver/dhcpserver.o
CC build/lwip/apps/ping/ping.o
CC build/lwip/apps/ping/esp_ping.o
CC build/lwip/apps/ping/ping_sock.o
CC build/lwip/apps/sntp/sntp.o
CC build/lwip/lwip/src/api/netdb.o
CC build/lwip/lwip/src/api/api_lib.o
CC build/lwip/lwip/src/api/netifapi.o
CC build/lwip/lwip/src/api/tcpip.o
CC build/lwip/lwip/src/api/netbuf.o
CC build/lwip/lwip/src/api/if_api.o
CC build/lwip/lwip/src/api/err.o
CC build/lwip/lwip/src/api/api_msg.o
CC build/lwip/lwip/src/api/sockets.o
CC build/lwip/lwip/src/apps/sntp/sntp.o
CC build/lwip/lwip/src/apps/netbiosns/netbiosns.o
CC build/lwip/lwip/src/core/mem.o
CC build/lwip/lwip/src/core/inet_chksum.o
CC build/lwip/lwip/src/core/init.o
CC build/lwip/lwip/src/core/memp.o
CC build/lwip/lwip/src/core/sys.o
CC build/lwip/lwip/src/core/tcp.o
CC build/lwip/lwip/src/core/timeouts.o
CC build/lwip/lwip/src/core/altcp_alloc.o
CC build/lwip/lwip/src/core/dns.o
CC build/lwip/lwip/src/core/ip.o
CC build/lwip/lwip/src/core/raw.o
CC build/lwip/lwip/src/core/tcp_in.o
CC build/lwip/lwip/src/core/pbuf.o
CC build/lwip/lwip/src/core/netif.o
CC build/lwip/lwip/src/core/stats.o
CC build/lwip/lwip/src/core/altcp.o
CC build/lwip/lwip/src/core/def.o
CC build/lwip/lwip/src/core/altcp_tcp.o
CC build/lwip/lwip/src/core/udp.o
CC build/lwip/lwip/src/core/tcp_out.o
CC build/lwip/lwip/src/core/ipv4/ip4_napt.o
CC build/lwip/lwip/src/core/ipv4/ip4_frag.o
CC build/lwip/lwip/src/core/ipv4/dhcp.o
CC build/lwip/lwip/src/core/ipv4/etharp.o
CC build/lwip/lwip/src/core/ipv4/ip4_addr.o
CC build/lwip/lwip/src/core/ipv4/igmp.o
CC build/lwip/lwip/src/core/ipv4/ip4.o
CC build/lwip/lwip/src/core/ipv4/autoip.o
CC build/lwip/lwip/src/core/ipv4/icmp.o
CC build/lwip/lwip/src/core/ipv6/ip6_frag.o
CC build/lwip/lwip/src/core/ipv6/dhcp6.o
CC build/lwip/lwip/src/core/ipv6/inet6.o
CC build/lwip/lwip/src/core/ipv6/ip6_addr.o
CC build/lwip/lwip/src/core/ipv6/ip6.o
CC build/lwip/lwip/src/core/ipv6/nd6.o
CC build/lwip/lwip/src/core/ipv6/mld6.o
CC build/lwip/lwip/src/core/ipv6/ethip6.o
CC build/lwip/lwip/src/core/ipv6/icmp6.o
CC build/lwip/lwip/src/netif/slipif.o
CC build/lwip/lwip/src/netif/ethernet.o
CC build/lwip/lwip/src/netif/bridgeif_fdb.o
CC build/lwip/lwip/src/netif/zepif.o
CC build/lwip/lwip/src/netif/lowpan6.o
CC build/lwip/lwip/src/netif/lowpan6_ble.o
CC build/lwip/lwip/src/netif/lowpan6_common.o
CC build/lwip/lwip/src/netif/bridgeif.o
CC build/lwip/port/esp32/vfs_lwip.o
CC build/lwip/port/esp32/freertos/sys_arch.o
CC build/lwip/port/esp32/netif/wlanif.o
CC build/lwip/port/esp32/netif/dhcp_state.o
CC build/lwip/port/esp32/netif/ethernetif.o
CC build/lwip/port/esp32/debug/lwip_debug.o
AR build/lwip/liblwip.a
CC build/main/get_started.o
AR build/main/libmain.a
CC build/mbedtls/mbedtls/library/md4.o
CC build/mbedtls/mbedtls/library/ecp.o
CC build/mbedtls/mbedtls/library/chachapoly.o
CC build/mbedtls/mbedtls/library/blowfish.o
CC build/mbedtls/mbedtls/library/x509.o
CC build/mbedtls/mbedtls/library/ssl_ticket.o
CC build/mbedtls/mbedtls/library/error.o
CC build/mbedtls/mbedtls/library/dhm.o
CC build/mbedtls/mbedtls/library/entropy_poll.o
CC build/mbedtls/mbedtls/library/cipher.o
CC build/mbedtls/mbedtls/library/version_features.o
CC build/mbedtls/mbedtls/library/pkcs5.o
CC build/mbedtls/mbedtls/library/nist_kw.o
CC build/mbedtls/mbedtls/library/ripemd160.o
CC build/mbedtls/mbedtls/library/rsa.o
CC build/mbedtls/mbedtls/library/hkdf.o
CC build/mbedtls/mbedtls/library/entropy.o
CC build/mbedtls/mbedtls/library/md_wrap.o
CC build/mbedtls/mbedtls/library/sha256.o
CC build/mbedtls/mbedtls/library/ssl_cache.o
CC build/mbedtls/mbedtls/library/pkwrite.o
CC build/mbedtls/mbedtls/library/ssl_cli.o
CC build/mbedtls/mbedtls/library/timing.o
CC build/mbedtls/mbedtls/library/asn1parse.o
CC build/mbedtls/mbedtls/library/padlock.o
CC build/mbedtls/mbedtls/library/pem.o
CC build/mbedtls/mbedtls/library/version.o
CC build/mbedtls/mbedtls/library/gcm.o
CC build/mbedtls/mbedtls/library/cmac.o
CC build/mbedtls/mbedtls/library/x509_create.o
CC build/mbedtls/mbedtls/library/md2.o
CC build/mbedtls/mbedtls/library/chacha20.o
CC build/mbedtls/mbedtls/library/sha1.o
CC build/mbedtls/mbedtls/library/ssl_srv.o
CC build/mbedtls/mbedtls/library/x509_crt.o
CC build/mbedtls/mbedtls/library/ecdh.o
CC build/mbedtls/mbedtls/library/aria.o
CC build/mbedtls/mbedtls/library/debug.o
CC build/mbedtls/mbedtls/library/ssl_tls.o
CC build/mbedtls/mbedtls/library/ecjpake.o
CC build/mbedtls/mbedtls/library/oid.o
CC build/mbedtls/mbedtls/library/asn1write.o
CC build/mbedtls/mbedtls/library/ecdsa.o
CC build/mbedtls/mbedtls/library/pkcs11.o
CC build/mbedtls/mbedtls/library/sha512.o
CC build/mbedtls/mbedtls/library/base64.o
CC build/mbedtls/mbedtls/library/xtea.o
CC build/mbedtls/mbedtls/library/aes.o
CC build/mbedtls/mbedtls/library/rsa_internal.o
CC build/mbedtls/mbedtls/library/cipher_wrap.o
CC build/mbedtls/mbedtls/library/arc4.o
CC build/mbedtls/mbedtls/library/bignum.o
CC build/mbedtls/mbedtls/library/aesni.o
CC build/mbedtls/mbedtls/library/threading.o
CC build/mbedtls/mbedtls/library/x509_crl.o
CC build/mbedtls/mbedtls/library/camellia.o
CC build/mbedtls/mbedtls/library/ssl_ciphersuites.o
CC build/mbedtls/mbedtls/library/certs.o
CC build/mbedtls/mbedtls/library/md5.o
CC build/mbedtls/mbedtls/library/ssl_cookie.o
CC build/mbedtls/mbedtls/library/havege.o
CC build/mbedtls/mbedtls/library/platform_util.o
CC build/mbedtls/mbedtls/library/poly1305.o
CC build/mbedtls/mbedtls/library/memory_buffer_alloc.o
CC build/mbedtls/mbedtls/library/hmac_drbg.o
CC build/mbedtls/mbedtls/library/des.o
CC build/mbedtls/mbedtls/library/x509write_csr.o
CC build/mbedtls/mbedtls/library/pk.o
CC build/mbedtls/mbedtls/library/platform.o
CC build/mbedtls/mbedtls/library/ctr_drbg.o
CC build/mbedtls/mbedtls/library/x509write_crt.o
CC build/mbedtls/mbedtls/library/pk_wrap.o
CC build/mbedtls/mbedtls/library/ecp_curves.o
CC build/mbedtls/mbedtls/library/pkcs12.o
CC build/mbedtls/mbedtls/library/ccm.o
CC build/mbedtls/mbedtls/library/md.o
CC build/mbedtls/mbedtls/library/pkparse.o
CC build/mbedtls/mbedtls/library/x509_csr.o
CC build/mbedtls/port/mbedtls_debug.o
CC build/mbedtls/port/esp_timing.o
CC build/mbedtls/port/esp_hardware.o
CC build/mbedtls/port/esp_sha.o
CC build/mbedtls/port/esp_bignum.o
CC build/mbedtls/port/net_sockets.o
CC build/mbedtls/port/esp_aes_xts.o
CC build/mbedtls/port/esp_mem.o
CC build/mbedtls/port/esp32/esp_sha1.o
CC build/mbedtls/port/esp32/esp_sha256.o
CC build/mbedtls/port/esp32/sha.o
CC build/mbedtls/port/esp32/aes.o
CC build/mbedtls/port/esp32/bignum.o
CC build/mbedtls/port/esp32/esp_sha512.o
CC build/mbedtls/esp_crt_bundle/esp_crt_bundle.o
EMBED build/mbedtls/x509_crt_bundle.bin.o
AR build/mbedtls/libmbedtls.a
CC build/mcommon/mdf_event_loop.o
CC build/mcommon/mdf_err_to_name.o
CC build/mcommon/mdf_info_store.o
CC build/mcommon/mdf_mem.o
AR build/mcommon/libmcommon.a
CC build/mconfig/mconfig_security.o
CC build/mconfig/mconfig_queue.o
CC build/mconfig/mconfig_blufi.o
CC build/mconfig/mconfig_chain.o
AR build/mconfig/libmconfig.a
CC build/mdebug/mdebug_log.o
CC build/mdebug/mdebug_espnow.o
CC build/mdebug/mdebug_console.o
CC build/mdebug/mdebug_cmd.o
CC build/mdebug/mdebug_flash.o
AR build/mdebug/libmdebug.a
CC build/mdns/mdns_console.o
CC build/mdns/mdns_networking.o
CC build/mdns/mdns.o
AR build/mdns/libmdns.a
CC build/mespnow/mespnow.o
AR build/mespnow/libmespnow.a
CC build/miniz/miniz.o
CC build/miniz/miniz_tinfl.o
CC build/miniz/miniz_tdef.o
AR build/miniz/libminiz.a
CC build/mlink/mlink_notice.o
CC build/mlink/mlink_utils.o
CC build/mlink/mlink_sniffer.o
CC build/mlink/mlink_ble.o
CC build/mlink/mlink_espnow.o
CC build/mlink/mlink_trigger.o
CC build/mlink/mlink_json.o
CC build/mlink/mlink_httpd.o
CC build/mlink/mlink_handle.o
AR build/mlink/libmlink.a
CC build/mqtt/esp-mqtt/mqtt_client.o
CC build/mqtt/esp-mqtt/lib/mqtt_outbox.o
CC build/mqtt/esp-mqtt/lib/mqtt_msg.o
CC build/mqtt/esp-mqtt/lib/platform_esp32_idf.o
AR build/mqtt/libmqtt.a
CC build/mupgrade/mupgrade_node.o
CC build/mupgrade/mupgrade_root.o
CC build/mupgrade/mupgrade_check.o
AR build/mupgrade/libmupgrade.a
CC build/mwifi/mwifi.o
AR build/mwifi/libmwifi.a
CC build/newlib/heap.o
CC build/newlib/time.o
CC build/newlib/reent_init.o
CC build/newlib/termios.o
CC build/newlib/syscalls.o
CC build/newlib/syscall_table.o
CC build/newlib/abort.o
CC build/newlib/locks.o
CC build/newlib/random.o
CC build/newlib/pthread.o
AR build/newlib/libnewlib.a
CC build/nghttp/nghttp2/lib/nghttp2_http.o
CC build/nghttp/nghttp2/lib/nghttp2_outbound_item.o
CC build/nghttp/nghttp2/lib/nghttp2_hd_huffman.o
CC build/nghttp/nghttp2/lib/nghttp2_rcbuf.o
CC build/nghttp/nghttp2/lib/nghttp2_session.o
CC build/nghttp/nghttp2/lib/nghttp2_stream.o
CC build/nghttp/nghttp2/lib/nghttp2_hd.o
CC build/nghttp/nghttp2/lib/nghttp2_helper.o
CC build/nghttp/nghttp2/lib/nghttp2_frame.o
CC build/nghttp/nghttp2/lib/nghttp2_submit.o
CC build/nghttp/nghttp2/lib/nghttp2_pq.o
CC build/nghttp/nghttp2/lib/nghttp2_queue.o
CC build/nghttp/port/http_parser.o
AR build/nghttp/libnghttp.a
CXX build/nvs_flash/src/nvs_ops.o
CXX build/nvs_flash/src/nvs_page.o
CXX build/nvs_flash/src/nvs_item_hash_list.o
CXX build/nvs_flash/src/nvs_handle_simple.o
CXX build/nvs_flash/src/nvs_storage.o
CXX build/nvs_flash/src/nvs_api.o
CXX build/nvs_flash/src/nvs_partition_manager.o
AR build/nvs_flash/libnvs_flash.a
CC build/openssl/library/ssl_cert.o
CC build/openssl/library/ssl_methods.o
CC build/openssl/library/ssl_pkey.o
CC build/openssl/library/ssl_x509.o
CC build/openssl/library/ssl_lib.o
CC build/openssl/library/ssl_stack.o
CC build/openssl/platform/ssl_pm.o
CC build/openssl/platform/ssl_port.o
AR build/openssl/libopenssl.a
CC build/perfmon/xtensa_perfmon_access.o
CC build/perfmon/xtensa_perfmon_apis.o
AR build/perfmon/libperfmon.a
CC build/protobuf-c/protobuf-c/protobuf-c/protobuf-c.o
AR build/protobuf-c/libprotobuf-c.a
CC build/protocomm/src/common/protocomm.o
CC build/protocomm/src/security/security0.o
CC build/protocomm/src/security/security1.o
CC build/protocomm/proto-c/sec1.pb-c.o
CC build/protocomm/proto-c/session.pb-c.o
CC build/protocomm/proto-c/constants.pb-c.o
CC build/protocomm/proto-c/sec0.pb-c.o
CC build/protocomm/src/transports/protocomm_console.o
CC build/protocomm/src/transports/protocomm_httpd.o
AR build/protocomm/libprotocomm.a
CC build/pthread/pthread_local_storage.o
CC build/pthread/pthread_cond_var.o
CC build/pthread/pthread.o
AR build/pthread/libpthread.a
CC build/sdmmc/sdmmc_init.o
CC build/sdmmc/sdmmc_io.o
CC build/sdmmc/sdmmc_common.o
CC build/sdmmc/sdmmc_mmc.o
CC build/sdmmc/sdmmc_cmd.o
CC build/sdmmc/sdmmc_sd.o
AR build/sdmmc/libsdmmc.a
CC build/soc/src/cpu_util.o
CC build/soc/src/lldesc.o
CC build/soc/src/memory_layout_utils.o
CC build/soc/src/compare_set.o
CC build/soc/src/soc_include_legacy_warn.o
CC build/soc/src/hal/spi_hal.o
CC build/soc/src/hal/spi_slave_hal_iram.o
CC build/soc/src/hal/timer_hal.o
CC build/soc/src/hal/dac_hal.o
CC build/soc/src/hal/mcpwm_hal.o
CC build/soc/src/hal/spi_slave_hal.o
CC build/soc/src/hal/rtc_io_hal.o
CC build/soc/src/hal/i2c_hal_iram.o
CC build/soc/src/hal/i2c_hal.o
CC build/soc/src/hal/adc_hal.o
CC build/soc/src/hal/wdt_hal_iram.o
CC build/soc/src/hal/spi_flash_hal_iram.o
CC build/soc/src/hal/uart_hal_iram.o
CC build/soc/src/hal/spi_flash_hal.o
CC build/soc/src/hal/sigmadelta_hal.o
CC build/soc/src/hal/uart_hal.o
CC build/soc/src/hal/touch_sensor_hal.o
CC build/soc/src/hal/spi_hal_iram.o
CC build/soc/src/hal/soc_hal.o
CC build/soc/src/hal/sdio_slave_hal.o
CC build/soc/src/hal/i2s_hal.o
CC build/soc/src/hal/ledc_hal_iram.o
CC build/soc/src/hal/ledc_hal.o
CC build/soc/src/hal/twai_hal.o
CC build/soc/src/hal/mpu_hal.o
CC build/soc/src/hal/gpio_hal.o
CC build/soc/src/hal/spi_flash_hal_gpspi.o
CC build/soc/src/hal/cpu_hal.o
CC build/soc/src/hal/pcnt_hal.o
CC build/soc/src/esp32/rtc_pm.o
CC build/soc/src/esp32/touch_sensor_hal.o
CC build/soc/src/esp32/brownout_hal.o
CC build/soc/src/esp32/adc_hal.o
CC build/soc/src/esp32/rtc_wdt.o
CC build/soc/src/esp32/soc_memory_layout.o
CC build/soc/src/esp32/rtc_init.o
CC build/soc/src/esp32/rtc_clk_init.o
CC build/soc/src/esp32/rtc_sleep.o
CC build/soc/src/esp32/rtc_time.o
CC build/soc/src/esp32/rtc_clk.o
CC build/soc/src/esp32/emac_hal.o
CC build/soc/soc/esp32/dac_periph.o
CC build/soc/soc/esp32/rtc_io_periph.o
CC build/soc/soc/esp32/touch_sensor_periph.o
CC build/soc/soc/esp32/interrupts.o
CC build/soc/soc/esp32/i2c_periph.o
CC build/soc/soc/esp32/adc_periph.o
CC build/soc/soc/esp32/sdmmc_periph.o
CC build/soc/soc/esp32/uart_periph.o
CC build/soc/soc/esp32/sdio_slave_periph.o
CC build/soc/soc/esp32/spi_periph.o
CC build/soc/soc/esp32/ledc_periph.o
CC build/soc/soc/esp32/i2s_periph.o
CC build/soc/soc/esp32/gpio_periph.o
AR build/soc/libsoc.a
CC build/spi_flash/spi_flash_os_func_app.o
CC build/spi_flash/flash_mmap.o
CC build/spi_flash/spi_flash_chip_drivers.o
CC build/spi_flash/partition.o
CC build/spi_flash/spi_flash_chip_generic.o
CC build/spi_flash/spi_flash_os_func_noos.o
CC build/spi_flash/spi_flash_chip_gd.o
CC build/spi_flash/cache_utils.o
CC build/spi_flash/esp_flash_api.o
CC build/spi_flash/spi_flash_chip_issi.o
CC build/spi_flash/flash_ops.o
CC build/spi_flash/spi_flash_chip_mxic.o
CC build/spi_flash/memspi_host_driver.o
CC build/spi_flash/esp_flash_spi_init.o
CC build/spi_flash/esp32/flash_ops_esp32.o
CC build/spi_flash/esp32/spi_flash_rom_patch.o
AR build/spi_flash/libspi_flash.a
CC build/spiffs/spiffs_api.o
CC build/spiffs/esp_spiffs.o
CC build/spiffs/spiffs/src/spiffs_cache.o
CC build/spiffs/spiffs/src/spiffs_gc.o
CC build/spiffs/spiffs/src/spiffs_nucleus.o
CC build/spiffs/spiffs/src/spiffs_check.o
CC build/spiffs/spiffs/src/spiffs_hydrogen.o
AR build/spiffs/libspiffs.a
CC build/tcp_transport/transport_ws.o
CC build/tcp_transport/transport_utils.o
CC build/tcp_transport/transport_ssl.o
CC build/tcp_transport/transport.o
CC build/tcp_transport/transport_tcp.o
AR build/tcp_transport/libtcp_transport.a
CC build/tcpip_adapter/tcpip_adapter_compat.o
AR build/tcpip_adapter/libtcpip_adapter.a
CC build/ulp/ulp.o
CC build/ulp/ulp_macro.o
AR build/ulp/libulp.a
CC build/unity/unity/src/unity.o
CC build/unity/unity_runner.o
CC build/unity/unity_port_esp32.o
AR build/unity/libunity.a
CC build/vfs/vfs_uart.o
CC build/vfs/vfs_semihost.o
CC build/vfs/vfs.o
AR build/vfs/libvfs.a
CXX build/wear_levelling/wear_levelling.o
CXX build/wear_levelling/WL_Flash.o
CXX build/wear_levelling/WL_Ext_Safe.o
CXX build/wear_levelling/SPI_Flash.o
CXX build/wear_levelling/Partition.o
CXX build/wear_levelling/WL_Ext_Perf.o
AR build/wear_levelling/libwear_levelling.a
CC build/wifi_provisioning/src/manager.o
CC build/wifi_provisioning/src/scheme_console.o
CC build/wifi_provisioning/src/scheme_softap.o
CC build/wifi_provisioning/src/wifi_scan.o
CC build/wifi_provisioning/src/handlers.o
CC build/wifi_provisioning/src/wifi_config.o
CC build/wifi_provisioning/proto-c/wifi_constants.pb-c.o
CC build/wifi_provisioning/proto-c/wifi_config.pb-c.o
CC build/wifi_provisioning/proto-c/wifi_scan.pb-c.o
AR build/wifi_provisioning/libwifi_provisioning.a
CC build/wpa_supplicant/port/os_xtensa.o
CC build/wpa_supplicant/src/ap/wpa_auth_ie.o
CC build/wpa_supplicant/src/ap/ieee802_1x.o
CC build/wpa_supplicant/src/ap/wpa_auth.o
CC build/wpa_supplicant/src/ap/ap_config.o
CC build/wpa_supplicant/src/common/sae.o
CC build/wpa_supplicant/src/common/dpp.o
CC build/wpa_supplicant/src/common/wpa_common.o
CC build/wpa_supplicant/src/crypto/aes-internal-enc.o
CC build/wpa_supplicant/src/crypto/sha256-internal.o
CC build/wpa_supplicant/src/crypto/md5-internal.o
CC build/wpa_supplicant/src/crypto/aes-internal.o
CC build/wpa_supplicant/src/crypto/sha1.o
CC build/wpa_supplicant/src/crypto/aes-internal-dec.o
CC build/wpa_supplicant/src/crypto/crypto_internal.o
CC build/wpa_supplicant/src/crypto/aes-unwrap.o
CC build/wpa_supplicant/src/crypto/ccmp.o
CC build/wpa_supplicant/src/crypto/sha256-kdf.o
CC build/wpa_supplicant/src/crypto/crypto_internal-rsa.o
CC build/wpa_supplicant/src/crypto/tls_mbedtls.o
CC build/wpa_supplicant/src/crypto/aes-siv.o
CC build/wpa_supplicant/src/crypto/des-internal.o
CC build/wpa_supplicant/src/crypto/sha1-tlsprf.o
CC build/wpa_supplicant/src/crypto/crypto_ops.o
CC build/wpa_supplicant/src/crypto/dh_group5.o
CC build/wpa_supplicant/src/crypto/aes-omac1.o
CC build/wpa_supplicant/src/crypto/crypto_internal-cipher.o
CC build/wpa_supplicant/src/crypto/crypto_mbedtls.o
CC build/wpa_supplicant/src/crypto/aes-wrap.o
CC build/wpa_supplicant/src/crypto/sha1-internal.o
CC build/wpa_supplicant/src/crypto/md4-internal.o
CC build/wpa_supplicant/src/crypto/dh_groups.o
CC build/wpa_supplicant/src/crypto/crypto_mbedtls-bignum.o
CC build/wpa_supplicant/src/crypto/sha256.o
CC build/wpa_supplicant/src/crypto/rc4.o
CC build/wpa_supplicant/src/crypto/md5.o
CC build/wpa_supplicant/src/crypto/aes-cbc.o
CC build/wpa_supplicant/src/crypto/aes-ccm.o
CC build/wpa_supplicant/src/crypto/sha1-pbkdf2.o
CC build/wpa_supplicant/src/crypto/sha256-prf.o
CC build/wpa_supplicant/src/crypto/bignum.o
CC build/wpa_supplicant/src/crypto/crypto_internal-modexp.o
CC build/wpa_supplicant/src/crypto/sha384-tlsprf.o
CC build/wpa_supplicant/src/crypto/sha256-tlsprf.o
CC build/wpa_supplicant/src/crypto/ms_funcs.o
CC build/wpa_supplicant/src/crypto/crypto_mbedtls-ec.o
CC build/wpa_supplicant/src/crypto/aes-ctr.o
CC build/wpa_supplicant/src/eap_peer/eap.o
CC build/wpa_supplicant/src/eap_peer/eap_common.o
CC build/wpa_supplicant/src/eap_peer/mschapv2.o
CC build/wpa_supplicant/src/eap_peer/eap_tls.o
CC build/wpa_supplicant/src/eap_peer/eap_tls_common.o
CC build/wpa_supplicant/src/eap_peer/eap_ttls.o
CC build/wpa_supplicant/src/eap_peer/eap_peap.o
CC build/wpa_supplicant/src/eap_peer/eap_mschapv2.o
CC build/wpa_supplicant/src/eap_peer/eap_peap_common.o
CC build/wpa_supplicant/src/rsn_supp/pmksa_cache.o
CC build/wpa_supplicant/src/rsn_supp/wpa_ie.o
CC build/wpa_supplicant/src/rsn_supp/wpa.o
CC build/wpa_supplicant/src/utils/wpa_debug.o
CC build/wpa_supplicant/src/utils/common.o
CC build/wpa_supplicant/src/utils/base64.o
CC build/wpa_supplicant/src/utils/ext_password.o
CC build/wpa_supplicant/src/utils/wpabuf.o
CC build/wpa_supplicant/src/utils/json.o
CC build/wpa_supplicant/src/utils/uuid.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpas_glue.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wps.o
CC build/wpa_supplicant/src/esp_supplicant/esp_hostap.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpa3.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpa2.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpa_main.o
CC build/wpa_supplicant/src/wps/wps_attr_process.o
CC build/wpa_supplicant/src/wps/wps_validate.o
CC build/wpa_supplicant/src/wps/wps_attr_parse.o
CC build/wpa_supplicant/src/wps/wps_dev_attr.o
CC build/wpa_supplicant/src/wps/wps.o
CC build/wpa_supplicant/src/wps/wps_common.o
CC build/wpa_supplicant/src/wps/wps_registrar.o
CC build/wpa_supplicant/src/wps/wps_attr_build.o
CC build/wpa_supplicant/src/wps/wps_enrollee.o
AR build/wpa_supplicant/libwpa_supplicant.a
CC build/xtensa/stdatomic.o
CC build/xtensa/debug_helpers.o
CC build/xtensa/expression_with_stack_xtensa.o
CC build/xtensa/trax.o
CC build/xtensa/esp32/trax_init.o
AR build/xtensa/libxtensa.a
Generating esp32.project.ld
LD build/get-started.elf
esptool.py v3.0-dev
Flashing binaries to serial port '/dev/ttyS8' (app at offset 0x10000)...
esptool.py v3.0-dev
Serial port /dev/ttyS8
Connecting........_____....._____....._____....._____....._____....._____....._____
make: *** [/mnt/e/Nextcloud/Basteln/Cluster_Tube_Lights/esp-mdf/esp-idf/components/esptool_py/Makefile.projbuild:105: flash] Error 2
best regards!
Re: ESP-MDF Development workflow
Postby ESP_Sprite » Wed Oct 21, 2020 2:42 am
If any, you can use e.g. 'make flash ESPPORT=/dev/ttyUSB1' to flash to a certain port without needing to run 'make menuconfig'. That should stop the entire project from recompiling. Moreover, if you run 'make -j', the process likely speeds up as the process will use multiple cores.
Twinstar
Postby Twinstar » Wed Oct 21, 2020 9:11 pm
Thanks, using 'make -j14' speeds it more than 10 times up!
Setting the ESPPORT variable, is neat.
Can you tell me how i add external Librarys such as the famous Adafruit_Neopixel lib?
Postby ESP_Sprite » Thu Oct 22, 2020 2:21 am
Ideally, you would find such a library pre-packaged as an ESP-IDF component; if so, you can just create a components/ directory in your project and drop the component subdirectory there. If not, you'd probably want to package the library as a component yourself.
philipp_u
Postby philipp_u » Thu Oct 22, 2020 10:44 am
To answer your unanswered questions:
1) Yes there is an ide with intellisense, i personally use VisualStudio Code with the Espressif IDF Extension. It has the typical stuff like build, flash, monitor, ... and supports the mdf framework out of the box.
2) There are libraries for neopixel on github https://github.com/search?q=neopixel+idf, i tried npixel but couldnt get it to work with my setup, but neopixelbus-idf did (with lots of tinkering since its written in c++ and there are some compatibility issued with the code ) viewtopic.php?f=21&t=9102&start=10
o.copleston
Contact:
Postby o.copleston » Thu Oct 22, 2020 4:09 pm
Hi Twinstar,
You can use Arduino as an ESP-IDF component, this would then allow you to import any Arduino libraries of your choosing. Bear in mind that the Arduino component only works with ESP-IDF-v3.3.2, V1 release of ESP-MDF and V2 Release of ESP-ADF.
This is similar to the tech stack we use for Wave
Developer at SquidSoup
Person on Twitter | Instagram
Users browsing this forum: No registered users and 35 guests
