connected wifi stations
imtiaz
Postby imtiaz » Thu Mar 23, 2017 7:08 pm
Hi All,
Does anyone know an easy way to figure out the IP addresses of all connected stations on the esp32? When a station connects or disconnects I only get the mac address. I know I can then get the IP from the mac address with a another call but is there another API call to get a list of connected station IP's?
Imtiaz
kolban
Re: connected wifi stations
Postby kolban » Thu Mar 23, 2017 7:16 pm
Well hmmm .... that was harder than it should have been. From my study, I believed that the answer was the tcpip_adapter component but after a search I could'nt find any docs in the web site on that component. Has it been accidently missed from the inclusion in the web based docs?
The answer to your question though can be technically found here ...
https://github.com/espressif/esp-idf/bl ... ter.h#L423
The API you are likely going to want to use is called:
tcpip_adapter_get_sta_list()
imtiaz
Postby imtiaz » Thu Mar 23, 2017 7:23 pm
Hi Kolban,
Thanks a bunch. I'll give it a go now .
Imtiaz
imtiaz
Postby imtiaz » Thu Mar 23, 2017 7:56 pm
Hi Kolban ,
I tried it it doesnt work .
void printStationLists(void)
	wifi_sta_list_t wifi_sta_list;
	tcpip_adapter_sta_list_t tcp_sta_list;
	if(tcpip_adapter_get_sta_list(&wifi_sta_list, &tcp_sta_list) == ESP_OK)
		for(uint8_t i = 0; i<4 ; i++)
			TRACE_D("Mac : %d , STA IP : %d\n",tcp_sta_list.sta[i].mac[0] ,tcp_sta_list.sta[i].ip.addr);
			TRACE_D("Num: %d , Mac : %d\n",wifi_sta_list.num,wifi_sta_list.sta[i].mac[0]);
	else
		TRACE_E("Cant get sta list\n");
Station IP comes out at 0 even if I have two stations connected.
I (149840) wifi: n:1 0, o:1 0, ap:1 1, sta:255 255, prof:1
I (149840) wifi: station: 90:68:c3:5b:f7:66 join, AID=2, n, 20
D (149841) event: SYSTEM_EVENT_AP_STACONNECTED, mac:90:68:c3:5b:f7:66, aid:2
OTA esp32.core Image Running
Mac : 194 , STA IP : 0
Num: 1 , Mac : 194
Mac : 0 , STA IP : 0
Num: 1 , Mac : 251
Num: 1 , Mac : 132
Num: 1 , Mac : 251
Num: 1 , Mac : 194
    Num: 1 , Mac : 251
    Num: 1 , Mac : 132
    Num: 1 , Mac : 251
    imtiaz
    Postby imtiaz » Thu Mar 23, 2017 8:34 pm
    This works
    @Inputs:
    @Outputs:
    @Comments:
    		ip4_addr_t addr;
    		wifi_sta_list_t staList;
    		esp_wifi_ap_get_sta_list(&staList);
        	for(uint8_t i = 0 ; i<staList.num ; i++)
    			if(dhcp_search_ip_on_mac(staList.sta[i].mac , &addr))
    				TRACE_D("IP = %d\n",addr.addr);
    			else
    heyinling
    Postby heyinling » Tue Mar 28, 2017 1:08 pm
    HI,
    I have got the following code work. You can try this.
    esp_wifi_ap_get_sta_list(&wifi_sta_list);
    tcpip_adapter_get_sta_list(&wifi_sta_list, &tcpip_adapter_sta_list);
    for (i=0; i<wifi_sta_list.num; i++){
        printf("StaInfo:"MACSTR","IPSTR"",MAC2STR(wifi_sta_list.sta[i].mac),IP2STR(&tcpip_adapter_sta_list.sta[i].ip));
    Users browsing this forum: Bing [Bot] and 44 guests
