Sending array by using wifi
nataly
Postby nataly » Wed May 11, 2022 10:05 pm
In this code I return string from the function readTemp().Now I'm asking what is I should use rather than c_str if I need to return unsigned char?
string readTemp() {
    return string(50);
void setup(){
    request->send_P(200, "text/plain", readTemp().c_str());
Now I need to deal with
unsigned char readTemp() {
    unsigned char a[5]={1,2,3,4,5};
    return (a);
void setup(){
    request->send_P(200, "text/plain", readTemp().c_str()); // here what should I use
                                                            // instead of c_str to sent  unsigned char array ?
Craige Hales
Re: Sending array by using wifi
Postby Craige Hales » Thu May 12, 2022 12:59 am
Does readTemp compile? It looks like it might try to return a pointer to a temporary on the stack as an 8-bit value.
Perhaps you want it to return unsigned char * and add static to the a[5].
And then you'll want to change the 5 to a 6 and add a null terminator so it can be a c string.
And then you might want to change the 1,2,3,4,5 to be ASCII codes; it isn't clear why you'd send binary data as text/plain, so maybe '1','2','3','4','5'.
Untested, but something like this.
unsigned char * readTemp() {
    static unsigned char a[6]={'1','2','3','4','5',0};
    return (a);
void setup(){
    request->send_P(200, "text/plain", readTemp());
Craige
lbernstone
Postby lbernstone » Thu May 12, 2022 1:52 am
I will assume you are talking about a ESPAsyncWebServer response. The documentation is at https://github.com/me-no-dev/ESPAsyncWebServer. There is a send() function for sending strings. I can't imagine why you would send a bare string like that, so I'll demonstrate wrapping some json.
uint8_t a[10] = {22, 23, 27, 18, 19, 20, 21, 25, 23, 22};
void handleTemp(AsyncWebServerRequest *request) {
    String json = "{ \"temp\" : [" + (String)a[0];
    for (int i=1;  i < sizeof(a); i++) {
        json += "," + (String)a[i];
    json += "] }";
    request->send(200, "application/json", json);
nataly
Postby nataly » Thu May 12, 2022 10:41 am
    return (a);
void setup(){
In this case I get on :invalid conversion from 'unsigned char*' to 'const char*' [-fpermissive]
nataly
Postby nataly » Thu May 12, 2022 10:50 am
    json += "] }";
Actually I'm trying to send this array "unsigned char "so this is just an attempt because I don't know how to do that. For this code how can I call handleTemp() in setup()
nataly
Postby nataly » Thu May 12, 2022 11:12 am
OK, in this way I can send array after define the array and json global :
unsigned char  a[10] = {22, 23, 27, 18, 19, 20, 21, 25, 23, 22};
String json;
in serup():
    json += "] }";
   // request->send(200, "application/json", json);
       server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send(200, "application/json",json);
NOW how can I deal with the value of this array in the receiver side? because now I receive it like this:
if(WiFi.status()== WL_CONNECTED ){
      temperature = httpGETRequest(serverNameTemp);
      Serial.println("Temperature: " + temperature );
Craige Hales
Postby Craige Hales » Thu May 12, 2022 11:40 am
either cast with (const char *)readtemp() or remove the unsigned keyword.
I think the other proposed solution using JSON may be better. What does it print? You should see the JSON string you constructed on the server.
Craige
nataly
Postby nataly » Thu May 12, 2022 11:48 am
[/quote]
Yes, I use json as @lbernstone suggested but now my problem how can deal with the values in receiver side? I need to make some processing on the received value array
Craige Hales
Postby Craige Hales » Thu May 12, 2022 1:34 pm
All the top google hits seem to use ArduinoJSON library.
https://randomnerdtutorials.com/decodin ... r-esp8266/
https://www.learnrobotics.org/blog/pars ... a-arduino/
The data you have,
1,2,3,4,5
is binary. JSON is a way to package the binary data as a printable string, and later turn the string back into binary data. There are many ways to do that; sprintf(...) is another way. JSON is a good choice, especially if you decide to add another sensor to the server's response. The new sensor might get a name like \"humidity\" instead of \"temp\" and the old receiver code will still work because it will only look for \"temp\" and still find it. New receiver code will also find the new value under humidity.
Craige
nataly
Postby nataly » Thu May 12, 2022 1:52 pm
I get output like this for this code
this is the output,
temperature =
{ "temp" : [22,23,27,18,19,20,21,25,23,22] }
but I need to reach to each value inside this received array, what is the change on
Users browsing this forum: No registered users and 137 guests
