#define SCRATCH_BUFSIZE 8192
/* This example demonstrates how to create file server
* using esp_http_server. This file has only startup code.
* Look in file_server.c for the implementation */
char parsed[5][25];
char parse[100];
char size_ssid[35];
char ssid_get[30] = "ssid", pass_get[25] = "pass", conn_get[10] = "wifi";
char webpage[]= "<!DOCTYPE html>"
"<html>"
"<head>"
"<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\" /> "
"<link rel=\"stylesheet\" href=\"bootstrap.min.css\">"
"<div style=\"padding:20px;margin-top:50px;\" class=\"container\">"
" <form action=\"/index_html\">"
"<h2>Home Page</h2>"
"<p>This part is used to change the network that gateway will connect. Select the right SSID from drop-down selections and write password for this network. </p>"
"<h1>The XMLHttpRequest Object</h1>"
"<button type=\"button\" onclick=\"loadDoc()\">Get my CD collection</button>"
"<br><br>"
"<table id=\"demo\"></table>"
"<script src=\"bootstrap.min.js\"> </script>"
"<script>"
"alert(\"Entrou\");"
"function loadDoc() {"
"var xhttp = new XMLHttpRequest();"
"xhttp.onreadystatechange = function() {"
"if (this.readyState == 4 && this.status == 200) {"
" myFunction(this);"
"xhttp.open(\"GET\", \"cd_catalog.xml\", true);"
" xhttp.send();"
"function myFunction(xml) {"
"var i;"
"var xmlDoc = xml.responseXML;"
"var table=\"<tr><th>Artist</th><th>Title</th></tr>\";"
"var x = xmlDoc.getElementsByTagName(\"CD\");"
"for (i = 0; i <x.length; i++) {"
"table += \"<tr><td>\" +"
" x[i].getElementsByTagName(\"ARTIST\")[0].childNodes[0].nodeValue +"
"</td><td> +"
"x[i].getElementsByTagName(\"TITLE\")[0].childNodes[0].nodeValue +"
"</td></tr>;"
"document.getElementById(\"demo\").innerHTML = table;"
"</script>\n"
"</body>"
"</html>";
struct file_server_data
/* Base path of file storage */
char base_path[ESP_VFS_PATH_MAX + 1];
/* Scratch buffer for temporary storage during file transfer */
char scratch[SCRATCH_BUFSIZE];
static const char *TAG = "file_server";
static esp_err_t event_handler(void *ctx, system_event_t *event)
return ESP_OK;
/* Function to initialize SPIFFS */
static esp_err_t init_spiffs(void)
ESP_LOGI(TAG, "Initializing SPIFFS");
esp_vfs_spiffs_conf_t conf = {
.base_path = "/spiffs",
.partition_label = NULL,
.max_files = 5, // This decides the maximum number of files that can be created on the storage
.format_if_mount_failed = true};
esp_err_t ret = esp_vfs_spiffs_register(&conf);
if (ret != ESP_OK)
if (ret == ESP_FAIL)
ESP_LOGE(TAG, "Failed to mount or format filesystem");
else if (ret == ESP_ERR_NOT_FOUND)
ESP_LOGE(TAG, "Failed to find SPIFFS partition");
else
ESP_LOGE(TAG, "Failed to initialize SPIFFS (%s)", esp_err_to_name(ret));
return ESP_FAIL;
size_t total = 0, used = 0;
ret = esp_spiffs_info(NULL, &total, &used);
if (ret != ESP_OK)
ESP_LOGE(TAG, "Failed to get SPIFFS partition information (%s)", esp_err_to_name(ret));
return ESP_FAIL;
ESP_LOGI(TAG, "Partition size: total: %d, used: %d", total, used);
return ESP_OK;
uint16_t ap_num = MAX_APs;
wifi_ap_record_t ap_records[MAX_APs];
static esp_err_t http_resp_dir_html(httpd_req_t *req, const char *dirpath);
static esp_err_t index_html_get_handler(httpd_req_t *req)
httpd_resp_set_status(req, "307 Temporary Redirect");
httpd_resp_set_hdr(req, "Location", "/index_html");
httpd_resp_send(req, NULL, 0); // Response body can be empty
return ESP_OK;
static esp_err_t logo_get_handler(httpd_req_t *req)
extern const unsigned char logo_png_start[] asm("_binary_logo_png_start");
extern const unsigned char logo_png_end[] asm("_binary_logo_png_end");
const size_t logo_png_size = (logo_png_end - logo_png_start);
httpd_resp_set_type(req, "image/png");
httpd_resp_send(req, (const char *)logo_png_start, logo_png_size);
return ESP_OK;
static esp_err_t bootstrap_css_get_handler(httpd_req_t *req)
extern const unsigned char bootstrap_css_start[] asm("_binary_bootstrap_min_css_start");
extern const unsigned char bootstrap_css_end[] asm("_binary_bootstrap_min_css_end");
const size_t bootcss_size = ((bootstrap_css_end-1) - bootstrap_css_start);
httpd_resp_set_hdr(req, "Location", "/bootstrap_min_css");
httpd_resp_send(req, (const char *)bootstrap_css_start, bootcss_size);
return ESP_OK;
static esp_err_t bootstrap_js_get_handler(httpd_req_t *req)
extern const unsigned char bootstrap_js_start[] asm("_binary_bootstrap_min_js_start");
extern const unsigned char bootstrap_js_end[] asm("_binary_bootstrap_min_js_end");
const size_t bootjs_size = ((bootstrap_js_end-1) - bootstrap_js_start);
httpd_resp_set_hdr(req, "Location", "/bootstrap_min_js");
httpd_resp_send(req, (const char *)bootstrap_js_start, bootjs_size);
return ESP_OK;
static esp_err_t cd_xml_get_handler(httpd_req_t *req)
extern const unsigned char cd_xml_start[] asm("_binary_cd_catalog_xml_start");
extern const unsigned char cd_xml_end[] asm("_binary_cd_catalog_xml_end");
const size_t cd_size = (cd_xml_end - cd_xml_start);
httpd_resp_send(req, (const char *)cd_xml_start, cd_size);
return ESP_OK;
static esp_err_t connect_get_handler(httpd_req_t *req)
char *token = strtok(parse, "?");
token = strtok(NULL, "?");
printf("after(?) token:%s \n", token);
if (!(strncmp("home", token, 4)))
if (!(strncmp("ssid", token, 4)))
strcpy(ssid_get, " ");
strcpy(pass_get, " ");
token = strtok(token, "&");
printf(" %s \t", token);
stpcpy(parsed[0], token + 5);
strcpy(ssid_get, parsed[0]);
printf("ssid detected! %s \n", ssid_get);
token = strtok(NULL, "&");
printf("%s \t", token);
stpcpy(parsed[1], token + 4);
strcpy(pass_get, parsed[1]);
printf("pass detected! %s \n", pass_get);
else if (!(strncmp("conn", token, 4)))
strcpy(conn_get, "");
stpcpy(parsed[0], token + 12);
strcpy(conn_get, parsed[0]);
printf("connection type detected! %s \n", conn_get);
else
printf("could not find any data! \n");
// httpd_resp_send_chunk(req, " alert('error!')/*displays error message*/",-1);
//httpd_resp_send_chunk(req, " SAVED!",-1);
// httpd_resp_send_chunk(req, " alert('changed values are saved!')/*displays error message*/",-1);
// printf ("new connection type : %s %s \n",parsed[0] ,parsed[1]);
printf("going to success\n");
return ESP_OK;
static char http_html_hdr[150];
sprintf(http_html_hdr,"HTTP/1.1 200 OK\r\nContent-Length: %u\r\nContent-type: text/html\r\nConnection: keep-alive\r\n\r\n",sizeof(webpage)-1);
httpd_resp_send(req,http_html_hdr,strlen(http_html_hdr));
vTaskDelay(5);
httpd_resp_send_chunk(req,webpage,strlen(webpage));
return ESP_OK;
#define IS_FILE_EXT(filename, ext) \
(strcasecmp(&filename[strlen(filename) - sizeof(ext) + 1], ext) == 0)
/* Set HTTP response content type according to file extension */
static esp_err_t set_content_type_from_file(httpd_req_t *req, const char *filename)
if (IS_FILE_EXT(filename, ".pdf"))
return httpd_resp_set_type(req, "application/pdf");
else if (IS_FILE_EXT(filename, ".html"))
return httpd_resp_set_type(req, "text/html");
else if (IS_FILE_EXT(filename, ".png"))
return httpd_resp_set_type(req, "image/png");
else if (IS_FILE_EXT(filename, ".jpeg"))
return httpd_resp_set_type(req, "image/jpeg");
else if (IS_FILE_EXT(filename, ".xml"))
return httpd_resp_set_type(req, "text/xml");
else if (IS_FILE_EXT(filename, ".css"))
return httpd_resp_set_type(req, "text/css");
else if (IS_FILE_EXT(filename, ".js"))
return httpd_resp_set_type(req, "application/javascript");
/* This is a limited set only */
/* For any other type always set as plain text */
return httpd_resp_set_type(req, "text/plain");
/* Copies the full path into destination buffer and returns
* pointer to path (skipping the preceding base path) */
static const char *get_path_from_uri(char *dest, const char *base_path, const char *uri, size_t destsize)
const size_t base_pathlen = strlen(base_path);
size_t pathlen = strlen(uri);
const char *quest = strchr(uri, '?');
if (quest)
pathlen = MIN(pathlen, quest - uri);
const char *hash = strchr(uri, '#');
if (hash)
pathlen = MIN(pathlen, hash - uri);
if (base_pathlen + pathlen + 1 > destsize)
/* Full path string won't fit into destination buffer */
return NULL;
/* Construct full path (base + path) */
strcpy(dest, base_path);
strlcpy(dest + base_pathlen, uri, pathlen + 1);
/* Return pointer to path, skipping the base */
return dest + base_pathlen;
/* Handler to download a file kept on the server */
static esp_err_t webserver_get_handler(httpd_req_t *req)
char filepath[FILE_PATH_MAX];
FILE *fd = NULL;
struct stat file_stat;
for (int a = 0; a < 5; a++)
strcpy(parsed[a], "");
ESP_LOGI(TAG, " storage ssid: %s pass: %s ", ssid_get, pass_get);
const char *filename = get_path_from_uri(filepath, ((struct file_server_data *)req->user_ctx)->base_path,
req->uri, sizeof(filepath));
printf("uri %s \n", req->uri);
strcpy(parse, req->uri); // calling strcpy function
printf("parse>>>> %s , filename: %s\n", parse, filename);
if (!filename)
ESP_LOGE(TAG, "Filename is too long");
/* Respond with 500 Internal Server Error */
httpd_resp_send_err(req, HTTPD_500_INTERNAL_SERVER_ERROR, "Filename too long");
return ESP_FAIL;
printf("\n \n %s \n \n",filename);
/* If name has trailing '/', respond with directory contents */
if (filename[strlen(filename) - 1] == '/')
return http_resp_dir_html(req, filepath);
if (stat(filepath, &file_stat) == -1)
/* If file not present on SPIFFS check if URI
* corresponds to one of the hardcoded paths */
if (strcmp(filename, "/logo.png") == 0)
ESP_LOGI(TAG, "logo!");
return logo_get_handler(req);
else if (strcmp(filename, "/bootstrap.min.css") == 0)
ESP_LOGI(TAG, "bootstrap.css!");
return bootstrap_css_get_handler(req);
else if (strcmp(filename, "/bootstrap.min.js") == 0)
ESP_LOGI(TAG, "bootstrap.js!");
return bootstrap_js_get_handler(req);
else if (strcmp(filename, "/cd_catalog.xml") == 0)
ESP_LOGI(TAG, "cd.xml!");
return cd_xml_get_handler(req);
ESP_LOGE(TAG, "Failed to stat file : %s", filepath);
/* Respond with 404 Not Found */
httpd_resp_send_err(req, HTTPD_404_NOT_FOUND, "File does not exist");
return ESP_FAIL;
fd = fopen(filepath, "r");
if (!fd)
ESP_LOGE(TAG, "Failed to read existing file : %s", filepath);
httpd_resp_send_err(req, HTTPD_500_INTERNAL_SERVER_ERROR, "Failed to read existing file");
return ESP_FAIL;
ESP_LOGI(TAG, "Sending file : %s (%ld bytes)...", filename, file_stat.st_size);
set_content_type_from_file(req, filename);
/* Retrieve the pointer to scratch buffer for temporary storage */
char *chunk = ((struct file_server_data *)req->user_ctx)->scratch;
size_t chunksize;
do
/* Read file in chunks into the scratch buffer */
chunksize = fread(chunk, 1, SCRATCH_BUFSIZE, fd);
/* Send the buffer contents as HTTP response chunk */
if (httpd_resp_send_chunk(req, chunk, chunksize) != ESP_OK)
fclose(fd);
ESP_LOGE(TAG, "File sending failed!");
/* Abort sending file */
httpd_resp_sendstr_chunk(req, NULL);
httpd_resp_send_err(req, HTTPD_500_INTERNAL_SERVER_ERROR, "Failed to send file");
return ESP_FAIL;
/* Keep looping till the whole file is sent */
} while (chunksize != 0);
/* Close file after sending complete */
fclose(fd);
ESP_LOGI(TAG, "File sending complete");
/* Respond with an empty chunk to signal HTTP response completion */
httpd_resp_send_chunk(req, NULL, 0);
return ESP_OK;
/* Function to start the file server */
esp_err_t start_file_server(const char *base_path)
static struct file_server_data *server_data = NULL;
/* Validate file storage base path */
if (!base_path || strcmp(base_path, "/spiffs") != 0)
ESP_LOGE(TAG, "File server presently supports only '/spiffs' as base path");
return ESP_ERR_INVALID_ARG;
if (server_data)
ESP_LOGE(TAG, "File server already started");
return ESP_ERR_INVALID_STATE;
/* Allocate memory for server data */
server_data = calloc(1, sizeof(struct file_server_data));
if (!server_data)
ESP_LOGE(TAG, "Failed to allocate memory for server data");
return ESP_ERR_NO_MEM;
strlcpy(server_data->base_path, base_path,
sizeof(server_data->base_path));
httpd_handle_t server = NULL;
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
/* Use the URI wildcard matching function in order to
* allow the same handler to respond to multiple different
* target URIs which match the wildcard scheme */
config.uri_match_fn = httpd_uri_match_wildcard;
ESP_LOGI(TAG, "Starting HTTP Server");
if (httpd_start(&server, &config) != ESP_OK)
ESP_LOGE(TAG, "Failed to start file server!");
return ESP_FAIL;
/* URI handler for getting uploaded files */
httpd_uri_t file_server = {
.uri = "/*", // Match all URIs of type /path/to/file
.method = HTTP_GET,
.handler = webserver_get_handler,
.user_ctx = server_data // Pass server data as context
httpd_register_uri_handler(server, &file_server);
return ESP_OK;
void app_main(void)
ESP_ERROR_CHECK(nvs_flash_init());
tcpip_adapter_init();
// initialize the wifi event handler
ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL));
// configure, initialize and start the wifi driver
wifi_init_config_t wifi_config = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&wifi_config));
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA));
wifi_config_t ap_config = {
.ap = {
.ssid = AP_SSID,
.password = AP_PASSWORD,
.ssid_hidden = 0, // Access point in ssid sini wifi scanlarda gizlemek için kullanılan parametre
ap_config.ap.authmode = WIFI_AUTH_OPEN;
ap_config.ap.ssid_len = 0;
ap_config.ap.max_connection = AP_MAX_CONN;
ap_config.ap.channel = AP_CHANNEL;
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &ap_config));
wifi_config_t sta_config = {
.sta = {
.ssid = STA_SSID,
.password = STA_PASSWORD},
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &sta_config));
ESP_ERROR_CHECK(esp_wifi_start()); //STA
printf("Starting access point, SSID=%s\n", "Test_Transmitter");
ESP_ERROR_CHECK(esp_wifi_connect()); //AP
/* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
* Read "Establishing Wi-Fi or Ethernet Connection" section in
* examples/protocols/README.md for more information about this function.
/* Initialize file storage */
ESP_ERROR_CHECK(init_spiffs());
ESP_ERROR_CHECK(start_file_server("/spiffs"));
