ESP32-Ethernet Kit
ESP32-Ethernet Kit
Is the ESP32-Ethernet Kit V1 supported in the Arduino IDE/Framework? I don't seem to be able to find that board.
Sid
Sid
Re: ESP32-Ethernet Kit
You can just use the ESP32 Dev Module. The gpio assignments are well documented at https://docs.espressif.com/projects/esp ... allocation
I will give that a try
Thank you, Sid
Thank you, Sid
Using the ESP32-DevKit as the board selection in Arduino I am now trying to use the ETH_TLK110 example sketch. At the beginning of the sketch are a number of definitions for the Ethernet PHY. Referring to the ESP32-Ethernet Kit "Getting started" guide I see the GPIO definitions for the "MDC" and "MDIO" connections. However, there are other definitions that I cannot find any reference to in the guide:
Could someone help me get those definitions correct please.
With the above setting, when I upload the sketch to the hardware I see the following:
#define ETH_ADDR 31
#define ETH_POWER_PIN 17
#define ETH_MDC_PIN 23
#define ETH_MDIO_PIN 18
#define ETH_TYPE ETH_PHY_TLK110
E (1028) esp.emac: emac_esp32_init(354): reset timeout
E (1028) esp_eth: esp_eth_driver_install(221): init mac failed
I don't know what the phy address is, that is specific to the phy device, but it seems likely that the example is correct. The power pin (reset) is gpio 5. gpio17 is used by psram on a wrover.
I changed the definitions with slightly different result:
Now I see:
I don't understand why this is such a mystery, it is an Espressif board after all.
#define ETH_ADDR 31
#define ETH_POWER_PIN 5
E (138) ip101: ip101_pwrctl(295): power up timeout
E (138) ip101: ip101_init(358): power control failed
E (138) esp_eth: esp_eth_driver_install(222): init phy failed
Yes, it is an Espressif board, and if you use the recommended example at https://github.com/espressif/esp-idf/tr ... rnet/basic it would work out of the box.
But, there's more than one way to set it up
Looking at the example, they do not set the refclk source. I think you should be sourcing from the phy, so
I don't have one with me (although I do have one somewhere in deep storage), so I can't actually test it myself. If that doesn't do it, try setting the address to 0 or 1. The pins all look correct.
ETH.begin(ETH_ADDR, ETH_POWER_PIN, ETH_MDC_PIN, ETH_MDIO_PIN, ETH_TYPE, ETH_CLOCK_GPIO0_IN);
I did find an Espressif example for this board in the IDF repository, "eth2ap". It does exactly what I want
Users browsing this forum: Google [Bot] and 129 guests
