Module shutting down when wifi is used
artium
Postby artium » Sat Jul 20, 2019 8:56 am
I am using the following dev kit from geekworm which is based on WROVER.
http://www.raspberrypiwiki.com/index.ph ... R-i_DevKit
When I try simple examples from esp-idf, everything is working great.
I get problems when I try one of the Wifi examples, for example the "station" example here:
https://github.com/espressif/esp-idf/tr ... ed/station
The serial connection dies and it seems that the module is constantly restarting itself:
It is not an ordinary restart as usually the serial connection does not disconnect.
$ make monitor
Toolchain path: /home/artium/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a
Compiler version: 5.2.0
Python requirements from /home/artium/esp/esp-idf/requirements.txt are satisfied.
MONITOR
--- idf_monitor on /dev/ttyUSB0 115200 ---
ets Ju
�8 20L��Ғ�:57��Hrs�'�� (�]I=9_RESEU����:0x33BSPI_TMQ}1SH_Bϊ�j
c�˥�ͥ�: 0, *�]A鰕�5
ck�E���0x00,�E���0�0,d_���0x�,cs0E���0A0,hdE���0�0,wp_���0x�
m�V�"%=1 clo�-"���2
l�X����fff00L�len'SHloX���������len:6LM�H��+��0���‚�0,leK���‚j
loX����008040blen:��j
Y����0x4008��SH�I (28) boot: ESP-IDF v3.2.2 2nd stage bootloader
I (28) boot: compile time 03:08:54
I (32) boot: Enabling RNG early entropy source...
I (33) boot: SPI Speed : 40MHz
I (37) boot: SPI Mode : DIO
I (41) boot: SPI Flash Size : 4MB
I (45) boot: Partition Table:
I (49) boot: ## Label Usage Type ST Offset Length
I (56) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (63) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (71) boot: 2 factory factory app 00 00 00010000 00100000
I (78) boot: End of partition table
I (83) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x13fc0 ( 81856) map
I (120) esp_image: segment 1: paddr=0x00023fe8 vaddr=0x3ffb0000 size=0x02e8c ( 11916) load
I (125) esp_image: segment 2: paddr=0x00026e7c vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _WindowOverflow4 at /home/artium/esp/esp-idf/components/freertos/xtensa_vectors.S:1779
I (127) esp_image: segment 3: paddr=0x00027284 vaddr=0x40080400 size=0x08d8c ( 36236) load
I (151) esp_image: segment 4: paddr=0x00030018 vaddr=0x400d0018 size=0x62364 (402276) map
0x400d0018: _stext at ??:?
I (292) esp_image: segment 5: paddr=0x00092384 vaddr=0x4008918c size=0x06e20 ( 28192) load
0x4008918c: xEventGroupWaitBits at /home/artium/esp/esp-idf/components/freertos/event_groups.c:338
I (314) boot: Loaded app from partition at offset 0x10000
I (314) boot: Disabling RNG early entropy source...
I (314) cpu_start: Pro cpu up.
I (318) cpu_start: Starting app cpu, entry point is 0x40080ffc
0x40080ffc: call_start_cpu1 at /home/artium/esp/esp-idf/components/esp32/cpu_start.c:246
I (0) cpu_start: App cpu up.
I (328) heap_init: Initializing. RAM available for dynamic allocation:
I (335) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (341) heap_init: At 3FFB8D78 len 00027288 (156 KiB): DRAM
I (347) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (354) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (360) heap_init: At 4008FFAC len 00010054 (64 KiB): IRAM
I (366) cpu_start: Pro cpu start user code
I (49) cpu_start: Starting scheduler on PRO CPU.
I (135) wifi station: ESP_WIFI_MODE_STA
I (135) wifi: wifi driver task: 3ffc09c8, prio:23, stack:3584, core=0
I (135) wifi: wifi firmware version: 693c7b6
I (135) wifi: config NVS flash: enabled
I (145) wifi: config nano formating: disabled
I (145) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (155) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (195) wifi: Init dynamic tx buffer num: 32
I (195) wifi: Init data frame dynamic rx buffer num: 32
I (195) wifi: Init management frame dynamic rx buffer num: 32
I (195) wifi: Init management short buffer num: 32
I (205) wifi: Init static rx buffer size: 1600
I (205) wifi: Init static rx buffer num: 10
I (215) wifi: Init dynamic rx buffer num: 32
Exception in thread Thread-2:
File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
self.run()
File "/usr/lib/python2.7/threading.py", line 754, in run
self.__target(*self.__args, **self.__kwargs)
File "/home/artium/esp/esp-idf/tools/idf_monitor.py", line 130, in _run_outer
self.run()
File "/home/artium/esp/esp-idf/tools/idf_monitor.py", line 220, in run
data = self.serial.read(self.serial.in_waiting or 1)
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
I have read that this could be caused by power issues during wifi manual callibration, but this is a devkit with voltage regulator and capacitor and I suppose that they designed it for wifi usage, otherwise it would be pointless to use ESP32.
ESP_Sprite
Re: Module shutting down when wifi is used
Postby ESP_Sprite » Mon Jul 22, 2019 3:51 am
Check your USB lead then. A fair amount of cheaper (and some non-cheap) USB leads have thin cables, leading to voltage drop and brown-outs.
Ritesh
Contact:
Postby Ritesh » Mon Jul 22, 2019 7:27 pm
$ make monitor
MONITOR
ets Ju
c�˥�ͥ�: 0, *�]A鰕�5
m�V�"%=1 clo�-"���2
self.run()
self.run()
Are you using recommended power supply with that kit? Which rating of power supply you are using?
Because issue might be like power supply as mentioned by Sprite that defaukt example without wifi is working but with wifi is not working as it consumes some power when you are enabling radio as well.
Regards,
Ritesh Prajapati
Users browsing this forum: Baidu [Spider], Bing [Bot] and 31 guests
