HTTPS OTA error: Passive OTA partition not found
RMandR
Postby RMandR » Sat Jul 20, 2019 3:40 pm
I have built and flashed my application using "make flash monitor" (windows 7, ESP_IDF 3.2).
The partition table is as below and I'm getting a "Passive OTA partition not found" after the call to
 esp_https_ota(&config)
What am I doing wrong?
Thanks in adance!
partition.csv
# Name,   Type, SubType, Offset,  Size, Flags
nvs,      data, nvs,     0x9000,  0x4000,
otadata,  data, ota,     0xd000,  0x2000,
phy_init, data, phy,     0xf000,  0x1000,
factory,  0,    0,       0x10000, 1M,
ota_0,    0,    ota_0,  0x110000, 1M,
ota_1,    0,    ota_1,  0x210000, 1M,
output:
I (4706) esp_https_ota: Starting OTA...
E (4706) esp_https_ota: Passive OTA partition not found
E (4706) HTTP_CLIENT: Firmware Upgrades Failed
RMandR
Re: HTTPS OTA error: Passive OTA partition not found
Postby RMandR » Mon Jul 22, 2019 1:27 pm
In case anyone else trips onto this: partition.csv is not read by default.
" choose “Custom partition table CSV” in menuconfig"
Ritesh
Contact:
Postby Ritesh » Mon Jul 22, 2019 7:01 pm
Thanks in adance!
partition.csv
output:
Which Partition table you have selected for OTA example? Because as per error it seems like you are facing issue due to wrong partition table selection that is why OTA is going to fail due to that reason.
Regards,
Ritesh Prajapati
lx393ale
Postby lx393ale » Mon May 11, 2020 2:06 pm
I'm facing with the same problem.
I'm using Platformio and I also have selected "two_partions_ota.csv" from menuconfig.
Can someone help me?
Users browsing this forum: Ukaton and 18 guests
