Hi!
Yesterday I had buried 4 ESP32 Development board...
The symptoms are - when board are connected to external power source to VIN & GND the board become really HOT. I can't even touch it... And then board become dead - the response is FLASH is not reachable ore something similar.
Diagnosis.
When the board powered from external power source (in my case 4S 18650 16.8V 7Ah with ability to support up to 20A) and connected to USB Type-C through USB hub for flashing, Type C are trying to charge notebook from USB. As far as it get not much wats from notebook perspective there is no any sign, that it trying to charge...
Warning: ESP32 become hot and dead when connected to power source and type-c
Re: Warning: ESP32 become hot and dead when connected to power source and type-c
Hi Dreamer_mos,
Thanks for the post. Would you please help share what board you are using? Could you help share the name of the board? Thanks.
Alvin
Alvin
Hi Alvin!
regular development board like this one - https://ru.aliexpress.com/item/32795678 ... lsrc=aw.ds
Hi,Dreamer_mos :
Can you take a picture to show your test enviroment? As you said, boards gets hot, are VCC & GND shorted?
Sorry for late answer.
Nope.. GND and VCC is not shorted.
incoming power: 16.8V 14A connected through DC-DC step down (With short protection) 16.8 -> 5V to VCC & GND.
What part of the board gets hot? the Esp32 Wroom or just the ams1117 regulator?
https://www.youtube.com/watch?v=OwAZqJ4wpJg
Check this video of the USB type-c connector. Maybe that is what happened.
