path to component includes
StefanHri
Postby StefanHri » Sat Jan 25, 2020 6:08 pm
I want to use some of the provided by esp-idf components in my project, e.g., cbor.
When i include the header file
#include "cbor.h"
in my application file in order to use the cbor API and compile
idf.py buil
I get
fatal error: cbor.h: No such file or directory
 #include "cbor.h"
How to make the components header files visible to my application code?
Thank you
ESP_krzychb
Contact:
Re: path to component includes
Postby ESP_krzychb » Sun Jan 26, 2020 1:21 pm
StefanHri wrote: How to make the components header files visible to my application code?
Hi StefanHri,
All esp-idf components should be already visible, given you have successfully completed Get Started instructions to compile "hello_world" example (I would use it to test if your include works).
Do you see "cbor" component in your "esp-idf/components" directory? I believe this component has been added to the master branch in August last year, so if you are using "stable" version of ESP-IDF (v3.3.1), it is not there.
chegewara
Postby chegewara » Sun Jan 26, 2020 9:29 pm
https://docs.espressif.com/projects/esp ... quirements
add REQUIRES cbor or PRIV_REQUIRES cbor
Users browsing this forum: Bing [Bot], vpascucci and 214 guests
