dlna on esp32 DevKitC v4
potstip
Postby potstip » Sun Apr 19, 2020 4:16 pm
Hello;
I have esp32 DevKitC v4 board and i tryed to flash dlna sample to it but can not succeed.
In idf.py menuconfig screen the board is ESP32-LyraT selected. if i select custom board it ask me board.h which i can not have knowledge to do that.
Here is build log
_____________________________________________________
pitstop@pop-os:~/Desktop/esp/dlna$ make flash
Toolchain path: /home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: esp-2020r1
Compiler version: 8.2.0
Python requirements from /home/pitstop/Desktop/esp/esp-idf/requirements.txt are satisfied.
GENCONFIG
warning: the default selection ESP32_KORVO_DU1906_CODEC_TAS5805M (undefined) of <choice ESP32_KORVO_DU1906_DAC> (defined at /home/pitstop/Desktop/esp/esp-adf/components/audio_board/Kconfig.projbuild:27) is not contained in the choice
warning: the default selection SR_RUN_WM6_CORE1 (undefined) of <choice SR_RUN_WN6_CORE> (defined at /home/pitstop/Desktop/esp/esp-adf/components/esp-sr/Kconfig.projbuild:83) is not contained in the choice
warning: the default selection CONFIG_SR_MN1_MODEL_QUANT (undefined) of <choice SR_MN_MODEL_SEL> (defined at /home/pitstop/Desktop/esp/esp-adf/components/esp-sr/Kconfig.projbuild:100) is not contained in the choice
Loading defaults file /home/pitstop/Desktop/esp/dlna/sdkconfig.defaults...
/home/pitstop/Desktop/esp/dlna/sdkconfig.defaults:24 CONFIG_SPIRAM_SUPPORT was replaced with CONFIG_ESP32_SPIRAM_SUPPORT
/tmp/confgen_tmpBg3kqa:7 line was updated to CONFIG_FREERTOS_RUN_TIME_STATS_USING_CPU_CLK=n
Project is not inside a git repository, or git repository has no commits
will not use 'git describe' to determine PROJECT_VER.
App "dlna_example" version: 1
CC build/bootloader/bootloader_support/src/bootloader_efuse_esp32.o
CC build/bootloader/bootloader_support/src/bootloader_mem.o
CC build/bootloader/bootloader_support/src/flash_qio_mode.o
CC build/bootloader/bootloader_support/src/bootloader_flash.o
CC build/bootloader/bootloader_support/src/bootloader_init.o
CC build/bootloader/bootloader_support/src/bootloader_common.o
CC build/bootloader/bootloader_support/src/bootloader_clock.o
CC build/bootloader/bootloader_support/src/bootloader_random.o
CC build/bootloader/bootloader_support/src/bootloader_flash_config_esp32.o
CC build/bootloader/bootloader_support/src/flash_partitions.o
CC build/bootloader/bootloader_support/src/esp_image_format.o
CC build/bootloader/bootloader_support/src/flash_encrypt.o
CC build/bootloader/bootloader_support/src/bootloader_utility.o
CC build/bootloader/bootloader_support/src/esp32/bootloader_sha.o
CC build/bootloader/bootloader_support/src/esp32/bootloader_esp32.o
CC build/bootloader/bootloader_support/src/esp32/flash_encrypt.o
AR build/bootloader/bootloader_support/libbootloader_support.a
CC build/bootloader/log/log.o
CC build/bootloader/log/log_noos.o
CC build/bootloader/log/log_buffers.o
AR build/bootloader/log/liblog.a
CC build/bootloader/spi_flash/esp32/spi_flash_rom_patch.o
AR build/bootloader/spi_flash/libspi_flash.a
CC build/bootloader/soc/src/cpu_util.o
CC build/bootloader/soc/src/soc_include_legacy_warn.o
CC build/bootloader/soc/src/memory_layout_utils.o
CC build/bootloader/soc/src/lldesc.o
CC build/bootloader/soc/src/compare_set.o
CC build/bootloader/soc/src/hal/spi_slave_hal_iram.o
CC build/bootloader/soc/src/hal/mcpwm_hal.o
CC build/bootloader/soc/src/hal/can_hal.o
CC build/bootloader/soc/src/hal/spi_slave_hal.o
CC build/bootloader/soc/src/hal/timer_hal.o
CC build/bootloader/soc/src/hal/dac_hal.o
CC build/bootloader/soc/src/hal/adc_hal.o
CC build/bootloader/soc/src/hal/wdt_hal_iram.o
CC build/bootloader/soc/src/hal/spi_flash_hal_iram.o
CC build/bootloader/soc/src/hal/spi_flash_hal.o
CC build/bootloader/soc/src/hal/touch_sensor_hal.o
CC build/bootloader/soc/src/hal/spi_hal_iram.o
CC build/bootloader/soc/src/hal/soc_hal.o
CC build/bootloader/soc/src/hal/sdio_slave_hal.o
CC build/bootloader/soc/src/hal/i2s_hal.o
CC build/bootloader/soc/src/hal/ledc_hal_iram.o
CC build/bootloader/soc/src/hal/spi_hal.o
CC build/bootloader/soc/src/hal/ledc_hal.o
CC build/bootloader/soc/src/hal/gpio_hal.o
CC build/bootloader/soc/src/hal/spi_flash_hal_gpspi.o
CC build/bootloader/soc/src/hal/cpu_hal.o
CC build/bootloader/soc/src/esp32/touch_sensor_hal.o
CC build/bootloader/soc/src/esp32/brownout_hal.o
CC build/bootloader/soc/src/esp32/adc_hal.o
CC build/bootloader/soc/src/esp32/rtc_time.o
CC build/bootloader/soc/src/esp32/rtc_init.o
CC build/bootloader/soc/src/esp32/rtc_clk_init.o
CC build/bootloader/soc/src/esp32/rtc_sleep.o
CC build/bootloader/soc/src/esp32/rtc_clk.o
CC build/bootloader/soc/src/esp32/emac_hal.o
CC build/bootloader/soc/soc/esp32/spi_periph.o
AR build/bootloader/soc/libsoc.a
CC build/bootloader/main/bootloader_start.o
AR build/bootloader/main/libmain.a
CC build/bootloader/efuse/esp32/esp_efuse_table.o
CC build/bootloader/efuse/src/esp_efuse_utility.o
CC build/bootloader/efuse/src/esp_efuse_fields.o
CC build/bootloader/efuse/src/esp_efuse_api.o
CC build/bootloader/efuse/src/esp32/esp_efuse_api.o
CC build/bootloader/efuse/src/esp32/esp_efuse_utility.o
CC build/bootloader/efuse/src/esp32/esp_efuse_fields.o
AR build/bootloader/efuse/libefuse.a
LD build/bootloader/bootloader.elf
esptool.py v3.0-dev
Building partitions from /home/pitstop/Desktop/esp/dlna/partitions_dlna_example.csv...
CC build/adf_utils/json_utils.o
CC build/adf_utils/cloud_services/baidu_access_token.o
CC build/adf_utils/cloud_services/aws_sig_v4_signing.o
AR build/adf_utils/libadf_utils.a
CC build/app_trace/app_trace_util.o
CC build/app_trace/host_file_io.o
CC build/app_trace/app_trace.o
CC build/app_trace/heap_trace_tohost.o
CC build/app_trace/gcov/gcov_rtio.o
AR build/app_trace/libapp_trace.a
CC build/app_update/esp_ota_ops.o
CC build/app_update/esp_app_desc.o
AR build/app_update/libapp_update.a
CXX build/asio/asio/asio/src/asio.o
AR build/asio/libasio.a
CC build/audio_board/lyrat_v4_3/board.o
CC build/audio_board/lyrat_v4_3/board_pins_config.o
AR build/audio_board/libaudio_board.a
CC build/audio_hal/audio_hal.o
CC build/audio_hal/driver/es8388/headphone_detect.o
CC build/audio_hal/driver/es8388/es8388.o
CC build/audio_hal/driver/es8374/es8374.o
CC build/audio_hal/driver/es8311/es8311.o
CC build/audio_hal/driver/es7243/es7243.o
CC build/audio_hal/driver/zl38063/zl38063.o
CC build/audio_hal/driver/zl38063/api_lib/vproc_common.o
CC build/audio_hal/driver/zl38063/api_lib/vprocTwolf_access.o
CC build/audio_hal/driver/zl38063/example_apps/tw_hal_verify.o
CC build/audio_hal/driver/zl38063/example_apps/tw_ldcfg.o
CC build/audio_hal/driver/zl38063/example_apps/tw_spi_access.o
CC build/audio_hal/driver/zl38063/example_apps/tw_ldfw.o
CC build/audio_hal/driver/zl38063/example_apps/tw_ldfwcfg.o
CC build/audio_hal/driver/tas5805m/tas5805m.o
CC build/audio_hal/driver/es7148/es7148.o
AR build/audio_hal/libaudio_hal.a
CC build/audio_pipeline/audio_event_iface.o
CC build/audio_pipeline/ringbuf.o
CC build/audio_pipeline/audio_pipeline.o
CC build/audio_pipeline/audio_element.o
AR build/audio_pipeline/libaudio_pipeline.a
CC build/audio_sal/audio_url.o
CC build/audio_sal/audio_thread.o
CC build/audio_sal/audio_mem.o
CC build/audio_sal/audio_sys.o
AR build/audio_sal/libaudio_sal.a
CC build/audio_stream/i2s_stream.o
CC build/audio_stream/hls_playlist.o
CC build/audio_stream/fatfs_stream.o
CC build/audio_stream/raw_stream.o
CC build/audio_stream/spiffs_stream.o
CC build/audio_stream/algorithm_stream.o
CC build/audio_stream/tone_stream.o
CC build/audio_stream/http_stream.o
AR build/audio_stream/libaudio_stream.a
CC build/bluetooth_service/a2dp_stream.o
CC build/bluetooth_service/bt_keycontrol.o
CC build/bluetooth_service/bluetooth_service.o
CC build/bluetooth_service/hfp_stream.o
AR build/bluetooth_service/libbluetooth_service.a
CC build/bootloader_support/src/bootloader_efuse_esp32.o
CC build/bootloader_support/src/bootloader_mem.o
CC build/bootloader_support/src/flash_qio_mode.o
CC build/bootloader_support/src/bootloader_flash.o
CC build/bootloader_support/src/bootloader_common.o
CC build/bootloader_support/src/bootloader_clock.o
CC build/bootloader_support/src/bootloader_random.o
CC build/bootloader_support/src/bootloader_flash_config_esp32.o
CC build/bootloader_support/src/flash_partitions.o
CC build/bootloader_support/src/esp_image_format.o
CC build/bootloader_support/src/flash_encrypt.o
CC build/bootloader_support/src/bootloader_utility.o
CC build/bootloader_support/src/idf/bootloader_sha.o
AR build/bootloader_support/libbootloader_support.a
CC build/cbor/tinycbor/src/cborparser.o
CC build/cbor/tinycbor/src/cborvalidation.o
CC build/cbor/tinycbor/src/open_memstream.o
CC build/cbor/tinycbor/src/cborparser_dup_string.o
CC build/cbor/tinycbor/src/cborencoder.o
CC build/cbor/tinycbor/src/cborerrorstrings.o
CC build/cbor/tinycbor/src/cborpretty.o
CC build/cbor/tinycbor/src/cbortojson.o
CC build/cbor/tinycbor/src/cborpretty_stdio.o
CC build/cbor/tinycbor/src/cborencoder_close_container_checked.o
AR build/cbor/libcbor.a
CC build/coap/libcoap/src/address.o
CC build/coap/libcoap/src/async.o
CC build/coap/libcoap/src/block.o
CC build/coap/libcoap/src/coap_event.o
CC build/coap/libcoap/src/coap_hashkey.o
CC build/coap/libcoap/src/coap_session.o
CC build/coap/libcoap/src/coap_time.o
CC build/coap/port/coap_debug.o
CC build/coap/libcoap/src/encode.o
CC build/coap/libcoap/src/mem.o
CC build/coap/libcoap/src/net.o
CC build/coap/libcoap/src/option.o
CC build/coap/libcoap/src/pdu.o
CC build/coap/libcoap/src/resource.o
CC build/coap/libcoap/src/str.o
CC build/coap/libcoap/src/subscribe.o
CC build/coap/libcoap/src/uri.o
CC build/coap/port/coap_mbedtls.o
CC build/coap/libcoap/src/coap_io.o
CC build/coap/port/coap_notls.o
AR build/coap/libcoap.a
CC build/console/esp_console_repl.o
CC build/console/commands.o
AR build/console/libconsole.a
CXX build/cxx/cxx_guards.o
CXX build/cxx/cxx_exception_stubs.o
AR build/cxx/libcxx.a
CC build/display_service/display_service.o
CC build/display_service/led_indicator/led_indicator.o
CC build/display_service/led_bar/led_bar_is31x.o
CC build/display_service/led_bar/led_bar_ws2812.o
CC build/display_service/led_bar/led_bar_aw2013.o
/home/pitstop/Desktop/esp/esp-adf/components/display_service/led_bar/led_bar_aw2013.c: In function 'led_bar_aw2013_set_blink_time':
/home/pitstop/Desktop/esp/esp-adf/components/display_service/led_bar/led_bar_aw2013.c:238:5: warning: returning 'void *' from a function with return type 'esp_err_t' {aka 'int'} makes integer from pointer without a cast [-Wint-conversion]
     AUDIO_NULL_CHECK(TAG, handle, return NULL);
AR build/display_service/libdisplay_service.a
CC build/driver/adc_common.o
CC build/driver/spi_master.o
CC build/driver/dac.o
CC build/driver/sigmadelta.o
CC build/driver/touch_sensor_common.o
CC build/driver/sdio_slave.o
CC build/driver/i2c.o
CC build/driver/sdspi_transaction.o
CC build/driver/ledc.o
CC build/driver/uart.o
CC build/driver/spi_common.o
CC build/driver/sdspi_host.o
CC build/driver/gpio.o
CC build/driver/pcnt.o
CC build/driver/sdspi_crc.o
CC build/driver/rtc_io.o
CC build/driver/rmt.o
CC build/driver/spi_bus_lock.o
CC build/driver/mcpwm.o
CC build/driver/sdmmc_transaction.o
CC build/driver/can.o
CC build/driver/spi_slave.o
CC build/driver/i2s.o
CC build/driver/sdmmc_host.o
CC build/driver/timer.o
CC build/driver/periph_ctrl.o
CC build/driver/rtc_module.o
CC build/driver/esp32/touch_sensor.o
CC build/driver/esp32/adc.o
AR build/driver/libdriver.a
CC build/dueros_service/esp_audio_device_info.o
CC build/dueros_service/dueros_service.o
AR build/dueros_service/libdueros_service.a
CC build/efuse/esp32/esp_efuse_table.o
CC build/efuse/src/esp_efuse_utility.o
CC build/efuse/src/esp_efuse_fields.o
CC build/efuse/src/esp_efuse_api.o
CC build/efuse/src/esp32/esp_efuse_api.o
CC build/efuse/src/esp32/esp_efuse_utility.o
CC build/efuse/src/esp32/esp_efuse_fields.o
AR build/efuse/libefuse.a
CC build/esp-adf-libs/esp_codec/equalizer.o
CC build/esp-adf-libs/esp_codec/audio_alc.o
CC build/esp-adf-libs/esp_codec/filter_resample.o
CC build/esp-adf-libs/esp_codec/wav_encoder.o
CC build/esp-adf-libs/esp_codec/downmix.o
CC build/esp-adf-libs/esp_codec/audio_forge.o
CC build/esp-adf-libs/esp_codec/audio_sonic.o
CC build/esp-adf-libs/audio_misc/rec_eng_helper.o
AR build/esp-adf-libs/libesp-adf-libs.a
CC build/esp-sr/speech_command_recognition/mn_process_commands.o
AR build/esp-sr/libesp-sr.a
CC build/esp-tls/esp_tls.o
CC build/esp-tls/esp_tls_mbedtls.o
AR build/esp-tls/libesp-tls.a
CC build/esp32/sleep_modes.o
CC build/esp32/cpu_start.o
CC build/esp32/cache_sram_mmu.o
CC build/esp32/crosscore_int.o
CC build/esp32/pm_trace.o
CC build/esp32/spiram_psram.o
CC build/esp32/clk.o
CC build/esp32/spiram.o
CC build/esp32/cache_err_int.o
CC build/esp32/intr_alloc.o
CC build/esp32/system_api_esp32.o
CC build/esp32/pm_esp32.o
CC build/esp32/hw_random.o
CC build/esp32/dport_access.o
CC build/esp32/esp_himem.o
AR build/esp32/libesp32.a
CC build/esp_actions/dueros_action.o
CC build/esp_actions/display_action.o
CC build/esp_actions/player_action.o
CC build/esp_actions/recorder_action.o
CC build/esp_actions/wifi_action.o
AR build/esp_actions/libesp_actions.a
CC build/esp_adc_cal/esp_adc_cal.o
AR build/esp_adc_cal/libesp_adc_cal.a
CC build/esp_common/src/task_wdt.o
CC build/esp_common/src/dbg_stubs.o
CC build/esp_common/src/int_wdt.o
CC build/esp_common/src/mac_addr.o
CC build/esp_common/src/freertos_hooks.o
CC build/esp_common/src/ipc.o
CC build/esp_common/src/esp_err.o
CC build/esp_common/src/pm_locks.o
CC build/esp_common/src/esp_err_to_name.o
CC build/esp_common/src/stack_check.o
CC build/esp_common/src/brownout.o
AR build/esp_common/libesp_common.a
CC build/esp_dispatcher/periph_service.o
CC build/esp_dispatcher/audio_service.o
CC build/esp_dispatcher/esp_dispatcher.o
AR build/esp_dispatcher/libesp_dispatcher.a
CC build/esp_dlna/esp_dlna_cmr.o
CC build/esp_dlna/esp_dlna_rcs.o
CC build/esp_dlna/esp_dlna.o
CC build/esp_dlna/esp_dlna_avt.o
AR build/esp_dlna/libesp_dlna.a
CC build/esp_eth/src/esp_eth_phy.o
CC build/esp_eth/src/esp_eth_phy_lan8720.o
CC build/esp_eth/src/esp_eth_phy_ip101.o
CC build/esp_eth/src/esp_eth_mac_esp32.o
CC build/esp_eth/src/esp_eth.o
CC build/esp_eth/src/esp_eth_phy_dp83848.o
CC build/esp_eth/src/esp_eth_netif_glue.o
CC build/esp_eth/src/esp_eth_phy_rtl8201.o
AR build/esp_eth/libesp_eth.a
CC build/esp_event/event_loop_legacy.o
CC build/esp_event/default_event_loop.o
CC build/esp_event/event_send.o
CC build/esp_event/esp_event.o
CC build/esp_event/esp_event_private.o
AR build/esp_event/libesp_event.a
CC build/esp_gdbstub/src/packet.o
CC build/esp_gdbstub/src/gdbstub.o
CC build/esp_gdbstub/esp32/gdbstub_esp32.o
CC build/esp_gdbstub/xtensa/gdbstub_xtensa.o
AR build/esp_gdbstub/libesp_gdbstub.a
CC build/esp_http_client/esp_http_client.o
CC build/esp_http_client/lib/http_header.o
CC build/esp_http_client/lib/http_auth.o
CC build/esp_http_client/lib/http_utils.o
AR build/esp_http_client/libesp_http_client.a
CC build/esp_http_server/src/httpd_main.o
CC build/esp_http_server/src/httpd_txrx.o
CC build/esp_http_server/src/httpd_ws.o
CC build/esp_http_server/src/httpd_uri.o
CC build/esp_http_server/src/httpd_parse.o
CC build/esp_http_server/src/httpd_sess.o
CC build/esp_http_server/src/util/ctrl_sock.o
AR build/esp_http_server/libesp_http_server.a
CC build/esp_https_ota/src/esp_https_ota.o
AR build/esp_https_ota/libesp_https_ota.a
CC build/esp_local_ctrl/src/esp_local_ctrl_handler.o
CC build/esp_local_ctrl/src/esp_local_ctrl.o
CC build/esp_local_ctrl/proto-c/esp_local_ctrl.pb-c.o
AR build/esp_local_ctrl/libesp_local_ctrl.a
CC build/esp_netif/esp_netif_defaults.o
CC build/esp_netif/esp_netif_objects.o
CC build/esp_netif/esp_netif_handlers.o
CC build/esp_netif/lwip/esp_netif_lwip_ppp.o
CC build/esp_netif/lwip/esp_netif_sta_list.o
CC build/esp_netif/lwip/esp_netif_lwip.o
CC build/esp_netif/lwip/esp_netif_lwip_defaults.o
CC build/esp_netif/loopback/esp_netif_loopback.o
AR build/esp_netif/libesp_netif.a
CC build/esp_peripherals/periph_gpio_isr.o
CC build/esp_peripherals/periph_touch.o
CC build/esp_peripherals/periph_console.o
CC build/esp_peripherals/periph_spiffs.o
CC build/esp_peripherals/periph_is31fl3216.o
CC build/esp_peripherals/esp_peripherals.o
CC build/esp_peripherals/periph_led.o
CC build/esp_peripherals/periph_button.o
CC build/esp_peripherals/periph_wifi.o
CC build/esp_peripherals/periph_adc_button.o
CC build/esp_peripherals/periph_ws2812.o
CC build/esp_peripherals/periph_aw2013.o
CC build/esp_peripherals/periph_sdcard.o
CC build/esp_peripherals/lib/sdcard/sdcard.o
CC build/esp_peripherals/lib/button/button.o
CC build/esp_peripherals/lib/touch/touch.o
CC build/esp_peripherals/lib/blufi/wifibleconfig.o
CC build/esp_peripherals/lib/blufi/blufi_security.o
CC build/esp_peripherals/lib/adc_button/adc_button.o
CC build/esp_peripherals/lib/IS31FL3216/IS31FL3216.o
CC build/esp_peripherals/driver/i2c_bus/i2c_bus.o
CC build/esp_peripherals/lib/gpio_isr/gpio_isr.o
CC build/esp_peripherals/lib/aw2013/aw2013.o
AR build/esp_peripherals/libesp_peripherals.a
CC build/esp_ringbuf/ringbuf.o
AR build/esp_ringbuf/libesp_ringbuf.a
CC build/esp_serial_slave_link/essl_sdio.o
CC build/esp_serial_slave_link/essl.o
AR build/esp_serial_slave_link/libesp_serial_slave_link.a
CC build/esp_system/panic.o
CC build/esp_system/system_api.o
CC build/esp_system/port/panic_handler.o
CC build/esp_system/port/esp32/reset_reason.o
AS build/esp_system/port/panic_handler_asm.o
AS build/esp_system/port/esp32/dport_panic_highint_hdl.o
AR build/esp_system/libesp_system.a
CC build/esp_timer/src/esp_timer_impl_lac.o
CC build/esp_timer/src/ets_timer_legacy.o
CC build/esp_timer/src/esp_timer.o
AR build/esp_timer/libesp_timer.a
CC build/esp_websocket_client/esp_websocket_client.o
AR build/esp_websocket_client/libesp_websocket_client.a
CC build/esp_wifi/src/lib_printf.o
CC build/esp_wifi/src/smartconfig.o
CC build/esp_wifi/src/wifi_default.o
CC build/esp_wifi/src/wifi_netif.o
CC build/esp_wifi/src/phy_init.o
CC build/esp_wifi/src/mesh_event.o
CC build/esp_wifi/src/smartconfig_ack.o
CC build/esp_wifi/src/coexist.o
CC build/esp_wifi/src/wifi_init.o
CC build/esp_wifi/esp32/esp_adapter.o
AR build/esp_wifi/libesp_wifi.a
CC build/espcoredump/src/core_dump_port.o
CC build/espcoredump/src/core_dump_flash.o
CC build/espcoredump/src/core_dump_common.o
CC build/espcoredump/src/core_dump_uart.o
CC build/espcoredump/src/core_dump_elf.o
AR build/espcoredump/libespcoredump.a
CC build/expat/expat/expat/lib/xmlparse.o
AR build/expat/libexpat.a
CC build/fatfs/diskio/diskio_wl.o
CC build/fatfs/diskio/diskio_rawflash.o
CC build/fatfs/diskio/diskio_sdmmc.o
CC build/fatfs/diskio/diskio.o
CC build/fatfs/vfs/vfs_fat_sdmmc.o
CC build/fatfs/vfs/vfs_fat_spiflash.o
CC build/fatfs/vfs/vfs_fat.o
CC build/fatfs/port/freertos/ffsystem.o
CC build/fatfs/src/ff.o
CC build/fatfs/src/ffunicode.o
AR build/fatfs/libfatfs.a
CC build/freemodbus/common/esp_modbus_master.o
CC build/freemodbus/common/esp_modbus_slave.o
CC build/freemodbus/modbus/mb_m.o
CC build/freemodbus/modbus/mb.o
CC build/freemodbus/modbus/ascii/mbascii.o
CC build/freemodbus/modbus/ascii/mbascii_m.o
CC build/freemodbus/modbus/functions/mbutils.o
CC build/freemodbus/modbus/functions/mbfuncinput_m.o
CC build/freemodbus/modbus/functions/mbfuncholding.o
CC build/freemodbus/modbus/functions/mbfuncdisc.o
CC build/freemodbus/modbus/functions/mbfuncother.o
CC build/freemodbus/modbus/functions/mbfuncdisc_m.o
CC build/freemodbus/modbus/functions/mbfuncinput.o
CC build/freemodbus/modbus/functions/mbfunccoils.o
CC build/freemodbus/modbus/functions/mbfunccoils_m.o
CC build/freemodbus/modbus/functions/mbfuncholding_m.o
CC build/freemodbus/modbus/rtu/mbcrc.o
CC build/freemodbus/modbus/rtu/mbrtu_m.o
CC build/freemodbus/modbus/rtu/mbrtu.o
CC build/freemodbus/modbus/tcp/mbtcp.o
CC build/freemodbus/serial_slave/modbus_controller/mbc_serial_slave.o
CC build/freemodbus/serial_master/modbus_controller/mbc_serial_master.o
CC build/freemodbus/port/portother_m.o
CC build/freemodbus/port/porttimer_m.o
CC build/freemodbus/port/portevent.o
CC build/freemodbus/port/portserial_m.o
CC build/freemodbus/port/portother.o
CC build/freemodbus/port/port.o
CC build/freemodbus/port/porttimer.o
CC build/freemodbus/port/portserial.o
CC build/freemodbus/port/portevent_m.o
AR build/freemodbus/libfreemodbus.a
CC build/freertos/queue.o
CC build/freertos/croutine.o
CC build/freertos/list.o
CC build/freertos/event_groups.o
CC build/freertos/tasks.o
CC build/freertos/timers.o
CC build/freertos/FreeRTOS-openocd.o
CC build/freertos/xtensa/xtensa_intr.o
CC build/freertos/xtensa/xtensa_init.o
CC build/freertos/xtensa/port.o
CC build/freertos/xtensa/xtensa_overlay_os_hook.o
AS build/freertos/xtensa/xtensa_intr_asm.o
AS build/freertos/xtensa/xtensa_context.o
AS build/freertos/xtensa/xtensa_vectors.o
AS build/freertos/xtensa/xtensa_vector_defaults.o
AS build/freertos/xtensa/portasm.o
AR build/freertos/libfreertos.a
CC build/heap/heap_caps_init.o
CC build/heap/heap_caps.o
CC build/heap/multi_heap.o
AR build/heap/libheap.a
CC build/input_key_service/input_key_service.o
AR build/input_key_service/libinput_key_service.a
CC build/libsodium/port/randombytes_esp32.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/generichash_blake2b.o
CC build/libsodium/libsodium/src/libsodium/crypto_generichash/blake2b/ref/blake2b-ref.o
CC build/libsodium/libsodium/src/libsodium/crypto_secretbox/crypto_secretbox_easy.o
CC build/libsodium/libsodium/src/libsodium/randombytes/randombytes.o
CC build/libsodium/libsodium/src/libsodium/sodium/utils.o
AR build/libsodium/liblibsodium.a
CC build/log/log.o
CC build/log/log_freertos.o
CC build/log/log_buffers.o
AR build/log/liblog.a
CC build/lwip/apps/dhcpserver/dhcpserver.o
CC build/lwip/apps/ping/ping.o
CC build/lwip/apps/ping/esp_ping.o
CC build/lwip/apps/ping/ping_sock.o
CC build/lwip/apps/sntp/sntp.o
CC build/lwip/lwip/src/api/netdb.o
CC build/lwip/lwip/src/api/api_lib.o
CC build/lwip/lwip/src/api/netifapi.o
CC build/lwip/lwip/src/api/tcpip.o
CC build/lwip/lwip/src/api/netbuf.o
CC build/lwip/lwip/src/api/if_api.o
CC build/lwip/lwip/src/api/err.o
CC build/lwip/lwip/src/api/api_msg.o
CC build/lwip/lwip/src/api/sockets.o
CC build/lwip/lwip/src/apps/sntp/sntp.o
CC build/lwip/lwip/src/apps/netbiosns/netbiosns.o
CC build/lwip/lwip/src/core/mem.o
CC build/lwip/lwip/src/core/inet_chksum.o
CC build/lwip/lwip/src/core/init.o
CC build/lwip/lwip/src/core/memp.o
CC build/lwip/lwip/src/core/sys.o
CC build/lwip/lwip/src/core/tcp_in.o
CC build/lwip/lwip/src/core/timeouts.o
CC build/lwip/lwip/src/core/altcp_alloc.o
CC build/lwip/lwip/src/core/dns.o
CC build/lwip/lwip/src/core/ip.o
CC build/lwip/lwip/src/core/raw.o
CC build/lwip/lwip/src/core/tcp.o
CC build/lwip/lwip/src/core/pbuf.o
CC build/lwip/lwip/src/core/netif.o
CC build/lwip/lwip/src/core/stats.o
CC build/lwip/lwip/src/core/altcp.o
CC build/lwip/lwip/src/core/def.o
CC build/lwip/lwip/src/core/altcp_tcp.o
CC build/lwip/lwip/src/core/udp.o
CC build/lwip/lwip/src/core/tcp_out.o
CC build/lwip/lwip/src/core/ipv4/ip4_frag.o
CC build/lwip/lwip/src/core/ipv4/dhcp.o
CC build/lwip/lwip/src/core/ipv4/etharp.o
CC build/lwip/lwip/src/core/ipv4/ip4_addr.o
CC build/lwip/lwip/src/core/ipv4/igmp.o
CC build/lwip/lwip/src/core/ipv4/ip4.o
CC build/lwip/lwip/src/core/ipv4/autoip.o
CC build/lwip/lwip/src/core/ipv4/icmp.o
CC build/lwip/lwip/src/core/ipv6/ip6_frag.o
CC build/lwip/lwip/src/core/ipv6/dhcp6.o
CC build/lwip/lwip/src/core/ipv6/inet6.o
CC build/lwip/lwip/src/core/ipv6/ip6_addr.o
CC build/lwip/lwip/src/core/ipv6/ip6.o
CC build/lwip/lwip/src/core/ipv6/nd6.o
CC build/lwip/lwip/src/core/ipv6/mld6.o
CC build/lwip/lwip/src/core/ipv6/ethip6.o
CC build/lwip/lwip/src/core/ipv6/icmp6.o
CC build/lwip/lwip/src/netif/slipif.o
CC build/lwip/lwip/src/netif/ethernet.o
CC build/lwip/lwip/src/netif/bridgeif_fdb.o
CC build/lwip/lwip/src/netif/zepif.o
CC build/lwip/lwip/src/netif/lowpan6.o
CC build/lwip/lwip/src/netif/lowpan6_ble.o
CC build/lwip/lwip/src/netif/lowpan6_common.o
CC build/lwip/lwip/src/netif/bridgeif.o
CC build/lwip/port/esp32/vfs_lwip.o
CC build/lwip/port/esp32/freertos/sys_arch.o
CC build/lwip/port/esp32/netif/wlanif.o
CC build/lwip/port/esp32/netif/dhcp_state.o
CC build/lwip/port/esp32/netif/ethernetif.o
CC build/lwip/port/esp32/debug/lwip_debug.o
AR build/lwip/liblwip.a
CC build/main/dlna_example.o
In file included from /home/pitstop/Desktop/esp/dlna/main/dlna_example.c:14:
/home/pitstop/Desktop/esp/esp-idf/components/esp_event/include/esp_event_loop.h:2:2: warning: #warning "esp_event_loop.h is deprecated, please include esp_event.h instead" [-Wcpp]
/home/pitstop/Desktop/esp/dlna/main/dlna_example.c: In function 'app_main':
/home/pitstop/Desktop/esp/dlna/main/dlna_example.c:263:5: warning: 'tcpip_adapter_init' is deprecated [-Wdeprecated-declarations]
     tcpip_adapter_init();
In file included from /home/pitstop/Desktop/esp/esp-idf/components/esp_netif/include/esp_netif.h:35,
                 from /home/pitstop/Desktop/esp/esp-idf/components/esp_event/include/esp_event_legacy.h:22,
                 from /home/pitstop/Desktop/esp/esp-idf/components/esp_event/include/esp_event.h:26,
                 from /home/pitstop/Desktop/esp/esp-idf/components/esp_wifi/include/esp_wifi.h:64,
                 from /home/pitstop/Desktop/esp/dlna/main/dlna_example.c:13:
/home/pitstop/Desktop/esp/esp-idf/components/tcpip_adapter/include/tcpip_adapter.h:34:6: note: declared here
 void tcpip_adapter_init(void)  __attribute__ ((deprecated));
AR build/main/libmain.a
CC build/mbedtls/mbedtls/library/ecp.o
CC build/mbedtls/mbedtls/library/chachapoly.o
CC build/mbedtls/mbedtls/library/blowfish.o
CC build/mbedtls/mbedtls/library/x509.o
CC build/mbedtls/mbedtls/library/ecp_curves.o
CC build/mbedtls/mbedtls/library/cipher.o
CC build/mbedtls/mbedtls/library/ssl_ticket.o
CC build/mbedtls/mbedtls/library/pk.o
CC build/mbedtls/mbedtls/library/entropy_poll.o
CC build/mbedtls/mbedtls/library/x509write_csr.o
CC build/mbedtls/mbedtls/library/version_features.o
CC build/mbedtls/mbedtls/library/havege.o
CC build/mbedtls/mbedtls/library/nist_kw.o
CC build/mbedtls/mbedtls/library/dhm.o
CC build/mbedtls/mbedtls/library/rsa.o
CC build/mbedtls/mbedtls/library/md4.o
CC build/mbedtls/mbedtls/library/ssl_cache.o
CC build/mbedtls/mbedtls/library/md_wrap.o
CC build/mbedtls/mbedtls/library/error.o
CC build/mbedtls/mbedtls/library/x509_crl.o
CC build/mbedtls/mbedtls/library/pkwrite.o
CC build/mbedtls/mbedtls/library/ssl_cli.o
CC build/mbedtls/mbedtls/library/timing.o
CC build/mbedtls/mbedtls/library/asn1parse.o
CC build/mbedtls/mbedtls/library/padlock.o
CC build/mbedtls/mbedtls/library/x509_crt.o
CC build/mbedtls/mbedtls/library/version.o
CC build/mbedtls/mbedtls/library/gcm.o
CC build/mbedtls/mbedtls/library/memory_buffer_alloc.o
CC build/mbedtls/mbedtls/library/cipher_wrap.o
CC build/mbedtls/mbedtls/library/md2.o
CC build/mbedtls/mbedtls/library/ecdsa.o
CC build/mbedtls/mbedtls/library/ssl_srv.o
CC build/mbedtls/mbedtls/library/aes.o
CC build/mbedtls/mbedtls/library/ecdh.o
CC build/mbedtls/mbedtls/library/asn1write.o
CC build/mbedtls/mbedtls/library/aria.o
CC build/mbedtls/mbedtls/library/chacha20.o
CC build/mbedtls/mbedtls/library/sha256.o
CC build/mbedtls/mbedtls/library/x509_create.o
CC build/mbedtls/mbedtls/library/ecjpake.o
CC build/mbedtls/mbedtls/library/pkcs11.o
CC build/mbedtls/mbedtls/library/sha512.o
CC build/mbedtls/mbedtls/library/base64.o
CC build/mbedtls/mbedtls/library/xtea.o
CC build/mbedtls/mbedtls/library/aesni.o
CC build/mbedtls/mbedtls/library/ripemd160.o
CC build/mbedtls/mbedtls/library/x509write_crt.o
CC build/mbedtls/mbedtls/library/arc4.o
CC build/mbedtls/mbedtls/library/bignum.o
CC build/mbedtls/mbedtls/library/pkparse.o
CC build/mbedtls/mbedtls/library/ssl_tls.o
CC build/mbedtls/mbedtls/library/debug.o
CC build/mbedtls/mbedtls/library/threading.o
CC build/mbedtls/mbedtls/library/md.o
CC build/mbedtls/mbedtls/library/camellia.o
CC build/mbedtls/mbedtls/library/cmac.o
CC build/mbedtls/mbedtls/library/hkdf.o
CC build/mbedtls/mbedtls/library/ssl_ciphersuites.o
CC build/mbedtls/mbedtls/library/certs.o
CC build/mbedtls/mbedtls/library/md5.o
CC build/mbedtls/mbedtls/library/ssl_cookie.o
CC build/mbedtls/mbedtls/library/poly1305.o
CC build/mbedtls/mbedtls/library/sha1.o
CC build/mbedtls/mbedtls/library/hmac_drbg.o
CC build/mbedtls/mbedtls/library/des.o
CC build/mbedtls/mbedtls/library/platform.o
CC build/mbedtls/mbedtls/library/ctr_drbg.o
CC build/mbedtls/mbedtls/library/pk_wrap.o
CC build/mbedtls/mbedtls/library/entropy.o
CC build/mbedtls/mbedtls/library/pkcs12.o
CC build/mbedtls/mbedtls/library/pem.o
CC build/mbedtls/mbedtls/library/ccm.o
CC build/mbedtls/mbedtls/library/pkcs5.o
CC build/mbedtls/mbedtls/library/rsa_internal.o
CC build/mbedtls/mbedtls/library/platform_util.o
CC build/mbedtls/mbedtls/library/x509_csr.o
CC build/mbedtls/mbedtls/library/oid.o
CC build/mbedtls/port/mbedtls_debug.o
CC build/mbedtls/port/esp_timing.o
CC build/mbedtls/port/esp_hardware.o
CC build/mbedtls/port/esp_sha.o
CC build/mbedtls/port/esp_bignum.o
CC build/mbedtls/port/net_sockets.o
CC build/mbedtls/port/esp_aes_xts.o
CC build/mbedtls/port/esp_mem.o
CC build/mbedtls/port/esp32/esp_sha1.o
CC build/mbedtls/port/esp32/esp_sha256.o
CC build/mbedtls/port/esp32/sha.o
CC build/mbedtls/port/esp32/aes.o
CC build/mbedtls/port/esp32/bignum.o
CC build/mbedtls/port/esp32/esp_sha512.o
CC build/mbedtls/esp_crt_bundle/esp_crt_bundle.o
EMBED build/mbedtls/x509_crt_bundle.bin.o
AR build/mbedtls/libmbedtls.a
CC build/mdns/mdns_console.o
CC build/mdns/mdns_networking.o
CC build/mdns/mdns.o
AR build/mdns/libmdns.a
CC build/mqtt/esp-mqtt/mqtt_client.o
CC build/mqtt/esp-mqtt/lib/mqtt_outbox.o
CC build/mqtt/esp-mqtt/lib/mqtt_msg.o
CC build/mqtt/esp-mqtt/lib/platform_esp32_idf.o
AR build/mqtt/libmqtt.a
CC build/newlib/heap.o
CC build/newlib/time.o
CC build/newlib/termios.o
CC build/newlib/syscalls.o
CC build/newlib/syscall_table.o
CC build/newlib/abort.o
CC build/newlib/reent_init.o
CC build/newlib/locks.o
CC build/newlib/random.o
CC build/newlib/pthread.o
AR build/newlib/libnewlib.a
CC build/nghttp/nghttp2/lib/nghttp2_http.o
CC build/nghttp/nghttp2/lib/nghttp2_hd_huffman.o
CC build/nghttp/nghttp2/lib/nghttp2_rcbuf.o
CC build/nghttp/nghttp2/lib/nghttp2_hd.o
CC build/nghttp/nghttp2/lib/nghttp2_outbound_item.o
CC build/nghttp/nghttp2/lib/nghttp2_session.o
CC build/nghttp/nghttp2/lib/nghttp2_stream.o
CC build/nghttp/nghttp2/lib/nghttp2_helper.o
CC build/nghttp/nghttp2/lib/nghttp2_frame.o
CC build/nghttp/nghttp2/lib/nghttp2_pq.o
CC build/nghttp/nghttp2/lib/nghttp2_queue.o
CC build/nghttp/nghttp2/lib/nghttp2_submit.o
CC build/nghttp/port/http_parser.o
AR build/nghttp/libnghttp.a
CXX build/nvs_flash/src/nvs_ops.o
CXX build/nvs_flash/src/nvs_item_hash_list.o
CXX build/nvs_flash/src/nvs_handle_simple.o
CXX build/nvs_flash/src/nvs_api.o
CXX build/nvs_flash/src/nvs_storage.o
CXX build/nvs_flash/src/nvs_page.o
CXX build/nvs_flash/src/nvs_partition_manager.o
AR build/nvs_flash/libnvs_flash.a
CC build/openssl/library/ssl_cert.o
CC build/openssl/library/ssl_methods.o
CC build/openssl/library/ssl_pkey.o
CC build/openssl/library/ssl_x509.o
CC build/openssl/library/ssl_lib.o
CC build/openssl/library/ssl_stack.o
CC build/openssl/platform/ssl_pm.o
CC build/openssl/platform/ssl_port.o
AR build/openssl/libopenssl.a
CC build/perfmon/xtensa_perfmon_access.o
CC build/perfmon/xtensa_perfmon_apis.o
AR build/perfmon/libperfmon.a
CC build/playlist/playlist.o
CC build/playlist/playlist_operator/partition_list.o
CC build/playlist/playlist_operator/dram_list.o
CC build/playlist/playlist_operator/flash_list.o
CC build/playlist/playlist_operator/sdcard_list.o
CC build/playlist/sdcard_scan/sdcard_scan.o
AR build/playlist/libplaylist.a
CC build/protobuf-c/protobuf-c/protobuf-c/protobuf-c.o
AR build/protobuf-c/libprotobuf-c.a
CC build/protocomm/src/common/protocomm.o
CC build/protocomm/src/security/security0.o
CC build/protocomm/src/security/security1.o
CC build/protocomm/proto-c/sec1.pb-c.o
CC build/protocomm/proto-c/session.pb-c.o
CC build/protocomm/proto-c/constants.pb-c.o
CC build/protocomm/proto-c/sec0.pb-c.o
CC build/protocomm/src/transports/protocomm_console.o
CC build/protocomm/src/transports/protocomm_httpd.o
AR build/protocomm/libprotocomm.a
CC build/pthread/pthread_local_storage.o
CC build/pthread/pthread_cond_var.o
CC build/pthread/pthread.o
AR build/pthread/libpthread.a
CC build/sdmmc/sdmmc_init.o
CC build/sdmmc/sdmmc_io.o
CC build/sdmmc/sdmmc_common.o
CC build/sdmmc/sdmmc_mmc.o
CC build/sdmmc/sdmmc_cmd.o
CC build/sdmmc/sdmmc_sd.o
AR build/sdmmc/libsdmmc.a
CC build/soc/src/cpu_util.o
CC build/soc/src/soc_include_legacy_warn.o
CC build/soc/src/memory_layout_utils.o
CC build/soc/src/lldesc.o
CC build/soc/src/compare_set.o
CC build/soc/src/hal/spi_slave_hal_iram.o
CC build/soc/src/hal/mcpwm_hal.o
CC build/soc/src/hal/can_hal.o
CC build/soc/src/hal/spi_slave_hal.o
CC build/soc/src/hal/i2c_hal.o
CC build/soc/src/hal/rtc_io_hal.o
CC build/soc/src/hal/i2c_hal_iram.o
CC build/soc/src/hal/timer_hal.o
CC build/soc/src/hal/dac_hal.o
CC build/soc/src/hal/adc_hal.o
CC build/soc/src/hal/wdt_hal_iram.o
CC build/soc/src/hal/spi_flash_hal_iram.o
CC build/soc/src/hal/uart_hal_iram.o
CC build/soc/src/hal/spi_flash_hal.o
CC build/soc/src/hal/sigmadelta_hal.o
CC build/soc/src/hal/uart_hal.o
CC build/soc/src/hal/touch_sensor_hal.o
CC build/soc/src/hal/spi_hal_iram.o
CC build/soc/src/hal/soc_hal.o
CC build/soc/src/hal/sdio_slave_hal.o
CC build/soc/src/hal/i2s_hal.o
CC build/soc/src/hal/ledc_hal_iram.o
CC build/soc/src/hal/spi_hal.o
CC build/soc/src/hal/ledc_hal.o
CC build/soc/src/hal/mpu_hal.o
CC build/soc/src/hal/gpio_hal.o
CC build/soc/src/hal/spi_flash_hal_gpspi.o
CC build/soc/src/hal/cpu_hal.o
CC build/soc/src/hal/pcnt_hal.o
CC build/soc/src/esp32/rtc_pm.o
CC build/soc/src/esp32/touch_sensor_hal.o
CC build/soc/src/esp32/brownout_hal.o
CC build/soc/src/esp32/adc_hal.o
CC build/soc/src/esp32/rtc_wdt.o
CC build/soc/src/esp32/soc_memory_layout.o
CC build/soc/src/esp32/rtc_time.o
CC build/soc/src/esp32/rtc_init.o
CC build/soc/src/esp32/rtc_clk_init.o
CC build/soc/src/esp32/rtc_sleep.o
CC build/soc/src/esp32/rtc_clk.o
CC build/soc/src/esp32/emac_hal.o
CC build/soc/soc/esp32/dac_periph.o
CC build/soc/soc/esp32/rtc_io_periph.o
CC build/soc/soc/esp32/touch_sensor_periph.o
CC build/soc/soc/esp32/interrupts.o
CC build/soc/soc/esp32/i2s_periph.o
CC build/soc/soc/esp32/adc_periph.o
CC build/soc/soc/esp32/sdmmc_periph.o
CC build/soc/soc/esp32/uart_periph.o
CC build/soc/soc/esp32/sdio_slave_periph.o
CC build/soc/soc/esp32/spi_periph.o
CC build/soc/soc/esp32/ledc_periph.o
CC build/soc/soc/esp32/i2c_periph.o
CC build/soc/soc/esp32/gpio_periph.o
AR build/soc/libsoc.a
CC build/spi_flash/spi_flash_os_func_noos.o
CC build/spi_flash/flash_mmap.o
CC build/spi_flash/spi_flash_chip_drivers.o
CC build/spi_flash/partition.o
CC build/spi_flash/spi_flash_os_func_app.o
CC build/spi_flash/spi_flash_chip_generic.o
CC build/spi_flash/spi_flash_chip_gd.o
CC build/spi_flash/cache_utils.o
CC build/spi_flash/esp_flash_api.o
CC build/spi_flash/spi_flash_chip_issi.o
CC build/spi_flash/flash_ops.o
CC build/spi_flash/spi_flash_chip_mxic.o
CC build/spi_flash/memspi_host_driver.o
CC build/spi_flash/esp_flash_spi_init.o
CC build/spi_flash/esp32/flash_ops_esp32.o
CC build/spi_flash/esp32/spi_flash_rom_patch.o
AR build/spi_flash/libspi_flash.a
CC build/spiffs/spiffs_api.o
CC build/spiffs/esp_spiffs.o
CC build/spiffs/spiffs/src/spiffs_cache.o
CC build/spiffs/spiffs/src/spiffs_gc.o
CC build/spiffs/spiffs/src/spiffs_nucleus.o
CC build/spiffs/spiffs/src/spiffs_check.o
CC build/spiffs/spiffs/src/spiffs_hydrogen.o
AR build/spiffs/libspiffs.a
CC build/tcp_transport/transport_ws.o
CC build/tcp_transport/transport_utils.o
CC build/tcp_transport/transport.o
CC build/tcp_transport/transport_tcp.o
CC build/tcp_transport/transport_ssl.o
AR build/tcp_transport/libtcp_transport.a
CC build/tcpip_adapter/tcpip_adapter_compat.o
AR build/tcpip_adapter/libtcpip_adapter.a
CC build/ulp/ulp.o
CC build/ulp/ulp_macro.o
AR build/ulp/libulp.a
CC build/unity/unity/src/unity.o
CC build/unity/unity_runner.o
CC build/unity/unity_port_esp32.o
AR build/unity/libunity.a
CC build/vfs/vfs_uart.o
CC build/vfs/vfs.o
CC build/vfs/vfs_semihost.o
AR build/vfs/libvfs.a
CXX build/wear_levelling/wear_levelling.o
CXX build/wear_levelling/WL_Flash.o
CXX build/wear_levelling/WL_Ext_Safe.o
CXX build/wear_levelling/SPI_Flash.o
CXX build/wear_levelling/Partition.o
CXX build/wear_levelling/WL_Ext_Perf.o
AR build/wear_levelling/libwear_levelling.a
CC build/wifi_provisioning/src/manager.o
CC build/wifi_provisioning/src/scheme_console.o
CC build/wifi_provisioning/src/scheme_softap.o
CC build/wifi_provisioning/src/wifi_scan.o
CC build/wifi_provisioning/src/handlers.o
CC build/wifi_provisioning/src/wifi_config.o
CC build/wifi_provisioning/proto-c/wifi_constants.pb-c.o
CC build/wifi_provisioning/proto-c/wifi_config.pb-c.o
CC build/wifi_provisioning/proto-c/wifi_scan.pb-c.o
AR build/wifi_provisioning/libwifi_provisioning.a
CC build/wifi_service/src/wifi_service.o
CC build/wifi_service/src/esp_wifi_setting.o
CC build/wifi_service/smart_config/smart_config.o
CC build/wifi_service/airkiss_config/airkiss_config.o
In file included from /home/pitstop/Desktop/esp/esp-adf/components/wifi_service/airkiss_config/airkiss_config.c:30:
CC build/wifi_service/blufi_config/blufi_security.o
CC build/wifi_service/blufi_config/blufi_config.o
AR build/wifi_service/libwifi_service.a
CC build/wpa_supplicant/port/os_xtensa.o
CC build/wpa_supplicant/src/ap/wpa_auth_ie.o
CC build/wpa_supplicant/src/ap/ieee802_1x.o
CC build/wpa_supplicant/src/ap/wpa_auth.o
CC build/wpa_supplicant/src/ap/ap_config.o
CC build/wpa_supplicant/src/common/sae.o
CC build/wpa_supplicant/src/common/wpa_common.o
CC build/wpa_supplicant/src/crypto/dh_groups.o
CC build/wpa_supplicant/src/crypto/aes-internal-enc.o
CC build/wpa_supplicant/src/crypto/sha256-internal.o
CC build/wpa_supplicant/src/crypto/aes-wrap.o
CC build/wpa_supplicant/src/crypto/md5-internal.o
CC build/wpa_supplicant/src/crypto/aes-internal.o
CC build/wpa_supplicant/src/crypto/sha1.o
CC build/wpa_supplicant/src/crypto/aes-internal-dec.o
CC build/wpa_supplicant/src/crypto/aes-unwrap.o
CC build/wpa_supplicant/src/crypto/ccmp.o
CC build/wpa_supplicant/src/crypto/crypto_internal-rsa.o
CC build/wpa_supplicant/src/crypto/des-internal.o
CC build/wpa_supplicant/src/crypto/crypto_ops.o
CC build/wpa_supplicant/src/crypto/dh_group5.o
CC build/wpa_supplicant/src/crypto/aes-omac1.o
CC build/wpa_supplicant/src/crypto/crypto_internal-cipher.o
CC build/wpa_supplicant/src/crypto/crypto_mbedtls.o
CC build/wpa_supplicant/src/crypto/sha1-internal.o
CC build/wpa_supplicant/src/crypto/md4-internal.o
CC build/wpa_supplicant/src/crypto/crypto_internal.o
CC build/wpa_supplicant/src/crypto/sha256.o
CC build/wpa_supplicant/src/crypto/md5.o
CC build/wpa_supplicant/src/crypto/aes-cbc.o
CC build/wpa_supplicant/src/crypto/crypto_internal-modexp.o
CC build/wpa_supplicant/src/crypto/aes-ccm.o
CC build/wpa_supplicant/src/crypto/sha1-pbkdf2.o
CC build/wpa_supplicant/src/crypto/rc4.o
CC build/wpa_supplicant/src/crypto/sha256-tlsprf.o
CC build/wpa_supplicant/src/crypto/ms_funcs.o
CC build/wpa_supplicant/src/crypto/bignum.o
CC build/wpa_supplicant/src/eap_peer/eap.o
CC build/wpa_supplicant/src/eap_peer/eap_common.o
CC build/wpa_supplicant/src/eap_peer/mschapv2.o
CC build/wpa_supplicant/src/eap_peer/eap_tls.o
CC build/wpa_supplicant/src/eap_peer/eap_tls_common.o
CC build/wpa_supplicant/src/eap_peer/eap_ttls.o
CC build/wpa_supplicant/src/eap_peer/eap_peap.o
CC build/wpa_supplicant/src/eap_peer/eap_mschapv2.o
CC build/wpa_supplicant/src/eap_peer/eap_peap_common.o
CC build/wpa_supplicant/src/rsn_supp/pmksa_cache.o
CC build/wpa_supplicant/src/rsn_supp/wpa_ie.o
CC build/wpa_supplicant/src/rsn_supp/wpa.o
CC build/wpa_supplicant/src/tls/tlsv1_server.o
CC build/wpa_supplicant/src/tls/x509v3.o
CC build/wpa_supplicant/src/tls/tlsv1_cred.o
CC build/wpa_supplicant/src/tls/tlsv1_client_read.o
CC build/wpa_supplicant/src/tls/tlsv1_client.o
CC build/wpa_supplicant/src/tls/rsa.o
CC build/wpa_supplicant/src/tls/tlsv1_client_write.o
CC build/wpa_supplicant/src/tls/asn1.o
CC build/wpa_supplicant/src/tls/tlsv1_server_read.o
CC build/wpa_supplicant/src/tls/pkcs8.o
CC build/wpa_supplicant/src/tls/pkcs1.o
CC build/wpa_supplicant/src/tls/pkcs5.o
CC build/wpa_supplicant/src/tls/tlsv1_record.o
CC build/wpa_supplicant/src/tls/bignum.o
CC build/wpa_supplicant/src/tls/tlsv1_server_write.o
CC build/wpa_supplicant/src/tls/tlsv1_common.o
CC build/wpa_supplicant/src/tls/tls_internal.o
CC build/wpa_supplicant/src/utils/wpa_debug.o
CC build/wpa_supplicant/src/utils/common.o
CC build/wpa_supplicant/src/utils/wpabuf.o
CC build/wpa_supplicant/src/utils/base64.o
CC build/wpa_supplicant/src/utils/ext_password.o
CC build/wpa_supplicant/src/utils/uuid.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpas_glue.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wps.o
CC build/wpa_supplicant/src/esp_supplicant/esp_hostap.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpa3.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpa2.o
CC build/wpa_supplicant/src/esp_supplicant/esp_wpa_main.o
CC build/wpa_supplicant/src/wps/wps_attr_process.o
CC build/wpa_supplicant/src/wps/wps_validate.o
CC build/wpa_supplicant/src/wps/wps_attr_parse.o
CC build/wpa_supplicant/src/wps/wps_dev_attr.o
CC build/wpa_supplicant/src/wps/wps.o
CC build/wpa_supplicant/src/wps/wps_common.o
CC build/wpa_supplicant/src/wps/wps_registrar.o
CC build/wpa_supplicant/src/wps/wps_attr_build.o
CC build/wpa_supplicant/src/wps/wps_enrollee.o
AR build/wpa_supplicant/libwpa_supplicant.a
CC build/xtensa/stdatomic.o
CC build/xtensa/debug_helpers.o
CC build/xtensa/expression_with_stack_xtensa.o
CC build/xtensa/trax.o
CC build/xtensa/esp32/trax_init.o
AR build/xtensa/libxtensa.a
Generating esp32.project.ld
LD build/dlna_example.elf
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/pitstop/Desktop/esp/esp-adf/components/esp-adf-libs/esp_ssdp/lib/libesp_ssdp.a(esp_ssdp.o):(.literal.ssdp_response+0x30): undefined reference to `lwip_sendto_r'
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/pitstop/Desktop/esp/esp-adf/components/esp-adf-libs/esp_ssdp/lib/libesp_ssdp.a(esp_ssdp.o):(.literal.ssdp_create_sock+0x20): undefined reference to `lwip_setsockopt_r'
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/pitstop/Desktop/esp/esp-adf/components/esp-adf-libs/esp_ssdp/lib/libesp_ssdp.a(esp_ssdp.o):(.literal.ssdp_create_sock+0x28): undefined reference to `lwip_bind_r'
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/pitstop/Desktop/esp/esp-adf/components/esp-adf-libs/esp_ssdp/lib/libesp_ssdp.a(esp_ssdp.o):(.literal.ssdp_read_sock+0xc): undefined reference to `lwip_recvfrom_r'
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/pitstop/Desktop/esp/esp-adf/components/esp-adf-libs/esp_ssdp/lib/libesp_ssdp.a(esp_ssdp.o): in function `ssdp_response':
/home/michael/work/esp/esp-adf-libs-source/esp_ssdp/esp_ssdp.c:387: undefined reference to `lwip_sendto_r'
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/pitstop/Desktop/esp/esp-adf/components/esp-adf-libs/esp_ssdp/lib/libesp_ssdp.a(esp_ssdp.o): in function `ssdp_create_sock':
/home/michael/work/esp/esp-adf-libs-source/esp_ssdp/esp_ssdp.c:235: undefined reference to `lwip_setsockopt_r'
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/michael/work/esp/esp-adf-libs-source/esp_ssdp/esp_ssdp.c:246: undefined reference to `lwip_bind_r'
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/michael/work/esp/esp-adf-libs-source/esp_ssdp/esp_ssdp.c:252: undefined reference to `lwip_setsockopt_r'
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/pitstop/Desktop/esp/esp-adf/components/esp-adf-libs/esp_ssdp/lib/libesp_ssdp.a(esp_ssdp.o): in function `recvfrom':
/home/michael/work/esp/esp-adf-internal/esp-idf/components/lwip/lwip/src/include/lwip/sockets.h:585: undefined reference to `lwip_recvfrom_r'
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/pitstop/Desktop/esp/esp-adf/components/esp-adf-libs/esp_ssdp/lib/libesp_ssdp.a(esp_ssdp.o): in function `setsockopt':
/home/michael/work/esp/esp-adf-internal/esp-idf/components/lwip/lwip/src/include/lwip/sockets.h:571: undefined reference to `lwip_setsockopt_r'
/home/pitstop/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/pitstop/Desktop/esp/esp-adf/components/esp-adf-libs/esp_ssdp/lib/libesp_ssdp.a(esp_ssdp.o): in function `ssdp_send_multicast':
/home/michael/work/esp/esp-adf-libs-source/esp_ssdp/esp_ssdp.c:342: undefined reference to `lwip_sendto_r'
collect2: error: ld returned 1 exit status
make: *** [/home/pitstop/Desktop/esp/esp-idf/make/project.mk:564: /home/pitstop/Desktop/esp/dlna/build/dlna_example.elf] Error 1
pitstop@pop-os:~/Desktop/esp/dlna$ make flash monitor
___________________________________________________________________
potstip
Re: dlna on esp32 DevKitC v4
Postby potstip » Mon Apr 20, 2020 7:17 am
Well i moved to idf 3.3.1 and succesfully flash devkit board but it does not working as upnp renderer. Even it does not connect to wifi network. i edit my ssid and pass in the sdkconfig file.
ESP_Vikram
Postby ESP_Vikram » Tue Apr 21, 2020 9:06 am
Did you forget
git submodule update --init --recursive
in your esp-idf directory?
potstip
Postby potstip » Wed Apr 29, 2020 10:55 am
ı succesfully run code in development board but it is so buggy and slow
ESP_Vikram
Postby ESP_Vikram » Wed Apr 29, 2020 12:10 pm
Hello again,
Please describe exact issues you are facing with logs and maybe with recording if possible.
This will help to target the exact issue.
Thanks,
Vikram
potstip
Postby potstip » Wed Apr 29, 2020 10:11 pm
Hello Vikram;
I made a video about how i install the firmware succesfully on dev board.
https://youtu.be/V6Cu0fi0yK0
But the problem is firmware itself.
even ES8388 dac on it support 24bit 96 Khz songs.
The board not playing songs over 16 bit 44.1Khz. It fails to play second song after start playing first song so i have to reset board each time. The board itself (firmware) is not communicate successfully with software players.
Each simple player actions (move next song, forward ) fails.
I used many different softwares the best performer is audirvana.
Audirvana
universal medi server
All same.
Br...
Erkan
ESP_Vikram
Postby ESP_Vikram » Thu Apr 30, 2020 5:18 am
Please find replies inline.
Was expecting a video on DLNA playing. (To see audio issues with song change, audio stutters etc. :| )
For now you can use 16bit/48K/Stereo for which es8388 is configured for. (Audios generally are 16bit/44.1K/Stereo. So, it makes sense to stick with above setup)
It should not be difficult to change it later if you want high bit depth and sampling rate supported by it.
Please share the console logs for the same to analyse. Also, are there any changes which you did in the example?
Though it should not be app or software specific, can you also check with HiFi Cast app?
Thanks.
potstip
Postby potstip » Thu Apr 30, 2020 1:28 pm
Hello;
ESP32 - Universal Media Server Interaction
https://youtu.be/_DeUeuDLSv0
Audirvana ESP32 interaction - trying to play song
https://youtu.be/uGBImOYlIP4
Hi-Fi cast ESP32 interaction - trying to play song
https://youtu.be/OiDfUI1f8qU
I only try to play 16bit 44.1Khz wave files and one 16 bit 44.1 Khz mp3 file.
Main issues as follows;
- Play only first song, try to play second song failed. No response. So song change ro response in general. It only response one time when i stop first song instead of direct click play on second song.
- Tiss noise when changing song
- Tiss noise when try to up volume
ESP_Vikram
Postby ESP_Vikram » Thu Apr 30, 2020 4:35 pm
That tiss sound looks like a crash.
Can you please clone the latest ADF master (
git pull --rebase
) and check?
I just tried and get smooth experience.
I am able to change songs pretty smoothly.
With latest version, if you still face tiss issue, please share console logs as well.
Thanks.
potstip
Postby potstip » Thu Apr 30, 2020 8:12 pm
Hello;
I build firmware with ESP-ADF Release v2.0 instead of direct cloning esp-adf.git.
these here below simply works
git clone https://github.com/espressif/esp-adf.git esp-adf-v2.0
cd esp-adf-v2.0/
git checkout v2.0
Now it is smooth as you said. But i saw some sound drops at the time of playing songs. it is much more noticable when playing over wifi (phone) and less on cable connected pc. It could be an isssue of lack of buffer. It could be much more problem on higer bitrate files.
to listen phone sample https://drive.google.com/open?id=1_UJbB ... bunVrEKCfP
Any comment or solution to this?
Users browsing this forum: No registered users and 82 guests
