Critical Code section
kilobyte_ch
Postby kilobyte_ch » Wed Apr 19, 2017 2:20 pm
Hello
I need a critical code section inside my esp-idf project. Cricital means that during a short time the timing should be 100% reproducable. I'm using nop's to time it. But I see big variations when WiFi is turned on or other tasks are running. No surprise. But I'm asking how can I disable "everything" to get this short section reproducable and then turn everything on again?
f.h-f.s.
Re: Critical Code section
Postby f.h-f.s. » Wed Apr 19, 2017 2:53 pm
portMUX_TYPE myMutex = portMUX_INITIALIZER_UNLOCKED;
taskENTER_CRITICAL(&myMutex);
//critical section
taskEXIT_CRITICAL(&myMutex);
from FreeRTOS/task.h & FreeRTOS/portmacro.h
or
uint32_t volatile register ilevel = XTOS_DISABLE_ALL_INTERRUPTS;
//critical section
XTOS_RESTORE_INTLEVEL(ilevel);
from xtruntime.h
You can read the cpu ticks with
uint32_t r;
asm volatile("rsr %0, ccount" : "=r"(r));//read special register cpu tick count
urbanze
Postby urbanze » Mon Jul 09, 2018 11:14 am
//critical section
from xtruntime.h
This critical section disable mutual cpu acess? I need to prevent both core to acess same "line in code" with more fast way possible... (Without method of freertos like semphr)
michprev
Postby michprev » Mon Jul 09, 2018 12:42 pm
urbanze wrote:
//critical section
from xtruntime.h
This one only disables C callable interrupts (level 3 or lower) on the current core.
You will have to go for
//critical section
taskENTER_CRITICAL disables C callable interrupts (on the current core) and locks the mutex by the current core.
ESP_Sprite
Postby ESP_Sprite » Tue Jul 10, 2018 2:19 am
Note that it's very hard to guarantee 100% precise CPU timings: you always run the risk of the other CPU, a DMA access, a lingering value in the CPU load/store unit or something else delaying a memory fetch and delaying your code. What issue exactly are you trying to solve? Chances are very large that there's a better solution than doing NOP delaying.
Users browsing this forum: ESP_igrr and 51 guests
