hello esp32 modbus slave communication is working as blocked, which stops the program completely if no data comes from the master. i want help me fix this problem.
thanks everyone.
"// The cycle below will be terminated when parameter holdingRegParams.dataChan0
// incremented each access cycle reaches the CHAN_DATA_MAX_VAL value.
for (; holding_reg_params.holding_data0 <MB_CHAN_DATA_MAX_VAL;) (
// Check for read / write events of Modbus master for certain events
mb_event_group_t event = mbc_slave_check_event (MB_READ_WRITE_MASK);
const char * rw_str = (event & MB_READ_MASK)? "READ": "WRITE";
// Filter events and process them accordingly
ESP32 MODBUS SLAVE BLOCKING
- Contact:
Re: ESP32 MODBUS SLAVE BLOCKING
Hi @erhansari,
Hope I understand you correctly. You want to do something else when your main task with modbus cycle is waiting for master data. Is this correct? In the modbus slave example the whole cycle of getting data is located in main task. So, if the holding_reg_params.holding_data0 reaches the maximum limit we exit the cycle and task is deleted. This is the functionality of original example to show how to init Modbus, get updated data over the Modbus then complete the communication. For your case you could put the code in the main() function into separated function like `slave_operation_func()`, create the task for modbus communication and execute this as a task function:
In this case the modbus code will start in separated task. When the modbus task reaches the maximum parameter value it will exit from cycle the destroy slave and delete the task but the main task will continue the application cycle.
The code is attached. Let me know if you have any issues.
static void slave_operation_func(void *arg)
// The modbus code, place here
TaskHandle_t hask_handle;
void app_main(void)
// Starts slave operation task
xTaskCreate(slave_operation_func, "slave_task", 8192, NULL, 20, &task_handle);
// Do here whatever you need
// .... application cycle
- mb_slave.zip
- modified modbus slave project
- (7.43 KiB) Downloaded 271 times
Users browsing this forum: Bing [Bot] and 142 guests
