I would like to embed certain system files in my `firmware.bin` file to make sure the firmware and the files are always in sync. However, I do not want these files to be a part of the program code itself, meaning, I do not want them to be loaded into RAM, using up valuable memory. Instead, I would like to access them from the Flash partition when I need access to them.
I could not find anything in the documentation, so I am wondering if there actually is a way to do this.
Embed binary file in a way that is not loaded into memory
Re: Embed binary file in a way that is not loaded into memory
Most of the program code is not loaded into RAM.
https://docs.espressif.com/projects/esp ... inary-data
Thanks for the link. I saw that before but was not sure if all the code is actually loaded into memory or not.My assumption was that it is, but I'll have to look into it some more, I suppose.
Files included this way are available in the address space, but they don't use any RAM - they're mapped in DROM.
Yes, I ran some tests the other day and noticed that, which was very good news. Thank you.
Users browsing this forum: YaCy [Bot] and 148 guests
